Old 02-04-2018, 04:43 PM   #169
Agreed that it is unnecessary and your mileage will suck big time. Disagree that you are creating any level of "extra wear". The ideal cruising revs for these cars is in the 3,000 to 3,500 range. You still have the power to accelerate quickly, there is no risk of lugging and it is right in the range to get the best mileage.
Originally Posted by ermax View Post
The auto “lugs” in your eyes then. I guess Subaru should have collaborated with you before writing the shifting logic. I know the difference in wear is minimal. But why turn 4500 in the neighborhood just because it is within specs? This is driving 101.
Anyways, this conversation is redundant at this point.
Where the hell did I say anything about driving 4500 through the neighborhood? In fact I said it isn't necessary. I understood the point was about extra wear. It has changed?
Obviously the lugging applies to MTs since the AT will always be in the right RPMs for the speed unless somebody is in manual mode.
The only reason that the conversation is redundant is because you want to change the goals. You insisted that there was extra wear. I said there is not. End of fucking story.
Old 02-04-2018, 04:59 PM   #170
ermax
ermax's Avatar
Cruising regularly at 4000 rpm
I never moved the posts. I’ve always maintained that cruising at high RPMs (I was originally saying 4500 at 35mph, you said 4000) when a simple upshift would take it back down is unnecessary. The auto doesn’t keep you where you need for max accelerate. It keeps it as low as possible. When you need to accelerate it then puts it where it needs to be for acceleration. My point was, the auto isn’t a dummy. It doesn’t cruise at 4500 if it can do it at 2000. It isn’t redundant because I’m moving goal posts. It’s because I’ve said the same thing, don’t cruise high if you don’t have to for like a week now. Hahaha
I stand by my statement that there is extra wear at higher RPMs. I don’t think a single engineer on this planet would disagree on that either. The only thing debatable is how much extra wear.
Old 02-04-2018, 05:03 PM   #171
Brink
Drives: 2017 BRZ
Auto won't even cruise that high in sport mode, would have to go into manual mode on it to cruise at 4k+.
Brink is offline   Reply With Quote
Old 02-04-2018, 05:04 PM   #172
ermax
ermax's Avatar
That’s because the engineers didn’t know what they were doing.
Old 02-04-2018, 05:15 PM   #173
new2subaru
Weight Weenie
Drives: 15 FR-S
Who came up with 4500 RPM at 35 MPH?
I said earlier that I "cruise" at around 3300 RPM on the Highway in 5th and in the City drive around 4K and up. There's lots of cornering in a City...I drive the same on rural roads with lots of bends.
It's not doing any harm IMO except burning a bit more fuel.
Old 02-04-2018, 05:17 PM   #174
How does the car feel sluggish when cruising? I agree with Decep. Why spin high revs for literally no reason other than to put extra wear on the engine and burn extra fuel. I run 6th at 50 even. If I anticipate the need to accelerate I will run a lower gear but not if I’m cruising for 15mins at a time. A big part of why the auto guys get better MPG is because the auto isn’t a dummy cruising at 35mph turning 4500rpm.
Exactly. It’s really very simple. If you’re in top gear at high speeds then you can’t avoid the high revs. I’m just pointing out that 4500 at just 35mph while “cruising” is just unnecessary wear.
Dang really? I’m never going to shift until I hit redline going forward.
Anyways, there is absolutely no way you can tell me there is no extra wear at all what so ever at 4K vs 2k. Regardless of extra oiling.
My thought exactly. But apparently people do it all day long. People say it sounds cooler and they are ready to accelerate in an emergency. You know like if someone gets sick of you hogging the left hand lane and decides to try to pass you in the right lane. I mean you have to be ready for an emergency like that. You can’t let someone pass you on the right. Right? Hahaha
IMO the car sounds like ass at 4K. Resonates like it’s ready to throw a rod through the block. 4K in an S2000 sounds cool. Not on the FA20 though.
Heal and toe braking, double clutching at revs and all those other super fun things cause more extra wear than driving at 4500 rpms ever would.
Old 02-04-2018, 05:20 PM   #175
Old 02-04-2018, 05:20 PM   #176
ermax
ermax's Avatar
True. But with a reward attached. Cruising at high RPM adds zero enjoyment to the drive.
Old 02-04-2018, 05:21 PM   #177
ermax
ermax's Avatar
I did. It was just an example. Not directed at you or anyone in particular.
Old 02-04-2018, 05:22 PM   #178
Unless you actually like the sound of the car which many people do. Besides you are once again deviating from the wear issue into personal preference.
Old 02-04-2018, 05:25 PM   #179
new2subaru
Weight Weenie
Drives: 15 FR-S
C'mom Ermax, that's your opinion. Can't you accept that I feel differently and that it enhances my driving experience?
I like the sound of this engine at 4k and you hate it. So what? That's why we don't have one or two cars out there to choose from.
Old 02-04-2018, 05:30 PM   #180
ermax
ermax's Avatar
Dude it hasn’t changed. Give it up. My point all along has been that cruising higher than necessary will add wear and eats gas. It’s a freaking fact. If you personally enjoy the sound, that is your personally preference. But it doesn’t change the fact I point out.
Old 02-04-2018, 05:30 PM   #181
humfrz
The difference if any at all the would be so minor that you would not be able to see it.
The numbers look like it should be different but the engine does not care if it is doing 2,000 rpms or 4,000.
Let me ask you these questions:
What wears out and engine ......??
Why do engines wear out .....??
humfrz
Old 02-04-2018, 05:33 PM   #182
new2subaru
Weight Weenie
Drives: 15 FR-S
humfrz
Lack of oil and cold starts
Opti - coat 2.0 (pro) vs waxing regularly radroach Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 34 01-19-2018 09:39 PM
Who else regularly checks BaT? NWFRS Other Vehicles & General Automotive Discussions 8 08-16-2014 12:02 AM
High rpm cruising in 6th abutterman Issues | Warranty | Recalls / TSB 12 03-22-2013 07:38 AM
Fr-S w/ Evo X cruising in SoCal NGabriel89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 09-12-2012 06:19 PM
JRP FR-S/BRZ build up (regularly updated) Stav CANADA 5 07-14-2012 04:21 PM
