Old 02-03-2018, 01:55 PM   #141
ermax
ermax's Avatar
How does the car feel sluggish when cruising? I agree with Decep. Why spin high revs for literally no reason other than to put extra wear on the engine and burn extra fuel. I run 6th at 50 even. If I anticipate the need to accelerate I will run a lower gear but not if I’m cruising for 15mins at a time. A big part of why the auto guys get better MPG is because the auto isn’t a dummy cruising at 35mph turning 4500rpm.
Old 02-03-2018, 03:23 PM   #142
Jordanwolf
Rice King
Jordanwolf's Avatar
Gotta agree with this key statement here, "How does the car feel sluggish when cruising", that really just don't make sense lol. You cruising, not mashing the gas pedal.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 02-03-2018, 04:09 PM   #143
By golly, another rational statement by ol Jordanwolf .......
I reckon his Friday evening sessions with his shrink are paying off ......
Old 02-03-2018, 04:23 PM   #144
Decep
Drives: 2013 FR-S Series 10
I guess now we know how some people get 30 mpg and others barely crack 20. lol
Old 02-03-2018, 04:45 PM   #145
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Why spin high revs for literally no reason other than to put extra wear on the engine and burn extra fuel. A big part of why the auto guys get better MPG is because the auto isn’t a dummy cruising at 35mph turning 4500rpm.
THIS
Again......
TommyW is offline   Reply With Quote
Old 02-03-2018, 09:12 PM   #146
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Decep View Post
That's fine, you're just wasting gas. Cruising implies a constant velocity no? If im getting up to speed and people are going too slow i'll stay in 4th or 5th for a while sometimes.
That's the beauty and fun of a manual transmission
It's my weekend toy. I'm not concerned about gas mileage.
Why can't you cruise at 4k RPM?
As I stated earlier, I think the car feels better, sounds better and drives better at 4K RPM.
To those who posted after, I drive an AT in manual at all times lol
Old 02-04-2018, 12:03 AM   #147
Now, new2subaru , I'll bet that when you were a kid, you put two playing cards on the spokes of your bicycle ........right .....??
Old 02-04-2018, 02:40 AM   #148
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
If someone could explain how "extra wear" occurs at highway speeds in the middle of the rev band I would be most grateful.
PetrolioBenzina is offline   Reply With Quote
Old 02-04-2018, 02:52 AM   #149
StraightOuttaCanadaEh
Wes
at 4000 rpm your engine is spinning faster than at 2000 rpm, hence the extra wear from going faster vs going slower. More heat, more friction, more wear, no? That'd be my guess
Instagram: @gt86ws
Old 02-04-2018, 04:23 AM   #150
Would you buy ..... extra wear per mile, for a car driven at an engine speed of 4,000 rpm vs. 2,000 rpm ......??
Old 02-04-2018, 04:28 AM   #151
ermax
ermax's Avatar
Exactly. It’s really very simple. If you’re in top gear at high speeds then you can’t avoid the high revs. I’m just pointing out that 4500 at just 35mph while “cruising” is just unnecessary wear.
Old 02-04-2018, 07:17 AM   #152
new2subaru
Weight Weenie
Drives: 15 FR-S
Just 2?
Old 02-04-2018, 11:53 AM   #153
Vic4uf
Drives: FRS, Camry
A smashed soda can worked even better
Vic4uf is offline   Reply With Quote
Old 02-04-2018, 12:15 PM   #154
Nope. Although that would seem logical it doesn't work that way. As revs increase so does lubrication and cooling. Your engine makes up for the change and for all intents and purposes it still is at the same levels as long as you are within the engineered operating range. Yes some things will "wear" faster through the extra fuel flow required but this difference would be very small. Yes if you are driving for a long period at red line or are rapidly changing revs you are adding wear since it is outside of the designed specs for cruising.
If anything cruising at too low of revs (there was somebody here that swore cruising at 1,000 whenever possible was best) can be harder on an engine than 4,000 since it would lug and lose oil pressure every time you tried to accelerate.
Opti - coat 2.0 (pro) vs waxing regularly radroach Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 34 01-19-2018 09:39 PM
Who else regularly checks BaT? NWFRS Other Vehicles & General Automotive Discussions 8 08-16-2014 12:02 AM
High rpm cruising in 6th abutterman Issues | Warranty | Recalls / TSB 12 03-22-2013 07:38 AM
Fr-S w/ Evo X cruising in SoCal NGabriel89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 09-12-2012 06:19 PM
JRP FR-S/BRZ build up (regularly updated) Stav CANADA 5 07-14-2012 04:21 PM
