Oxyg3n
Old 03-23-2019, 07:11 PM   #169
rmicroys
Drives: 2018 Subaru BRZ Sport-Tech RS
Good to know. Thanks. I’m looking forward to this. Lol. Not.
rmicroys is offline   Reply With Quote
Old 03-29-2019, 11:08 AM   #170
Scourge
Agent 86
Drives: 2017 Toyota 86
So, I just found a TSB (T-SB-0154-18) dated December 10, 2018 related to this problem...
If you go into the "Manufacturer Communications" section and expand the Engine listing dated Dec 10, 2018 (on page 1 as of this writing), you'll see the details.
https://www.nhtsa.gov/vehicle/2017/T...Communications
Direct link to PDF file:
https://static.nhtsa.gov/odi/tsbs/20...53203-9999.pdf
Update: Canadian Toyota TSB # is TCI-5183 for Toyota. Subaru Canada's is SB.07.70.18 (got from friend that works at Subaru). I don't have Subaru USA's. No luck online for that but if someone in the US could post it, that'd be awesome.
Scourge is offline   Reply With Quote
The Following 2 Users Say Thank You to Scourge For This Useful Post:
Larphraulen (03-29-2019), nitro_alltrac (03-29-2019)
Old 03-29-2019, 04:36 PM   #171
Scourge
Agent 86
Subaru screenshot sent by buddy...
Old 03-29-2019, 07:29 PM   #172
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
That TSB is in the TSB thread, the full version of the original subaru doc and the "cleaned up" version from Mitchell ProDemand.
I'm just waiting for Toyota to post their version, so I can have them deal with my car, because toyota dealer techs in this case, are useless without a TSB telling them EXACTLY what to do.
Old 03-29-2019, 07:39 PM   #173
nitro_alltrac
nitro_alltrac's Avatar
Drives: '17 86
Looks like I'm going to have to take mine in now. It through the codes again this evening on the way home this evening. Three times in less than a week.
I'm going to check with my QC folks at the plant Monday to see if I can get a contact at HQ to see if I can find which will be the best dealer in my area to take the car. I'm rather concerned about them pulling the engine and doing the valve adjustment. The just don't see that many of these cars around here.
I'm really glad to see the post where I could get the TSB. I'm printing that out and taking it with me when I take the car in.
nitro_alltrac is offline   Reply With Quote
Old 03-29-2019, 09:52 PM   #174
funpolice
Drives: 2017 brz sportech
so if you guys remember my posts from last year about my 2017 brand new brz cel after 1 day of driving.
dealer replaced my ecu, fuel injector last year. then the car sits in the garage during the winter. this week i took the brz out. let it idle abit on the driveway. boom, lights on again. i don't bother reading the codes again. cuz everytime it's the same effing codes. it ruins my fun to starr at the engine light on a new brz... i am sure everyone on this thread has the same depression, it sucks that because of this, i like driving the rav4 better in the winter time, at least the rav4 has no engine light on randomly giving me an heart attack
finally they have some tsb for this. i originally suspected it's only the 6-speed. and it seems align with this tsb. anyway. the screenshot of the subaru tsb says only ecm firm flash? no valve shimming?
funpolice is offline   Reply With Quote
Old 03-29-2019, 11:40 PM   #175
RZNT4R
The full tsb is in the pinned thread. Procedure is to check valve lash and correct if out of spec before reflashing
Old 03-30-2019, 08:42 AM   #176
funpolice
does that mean they have to drop the engine to check the valve clearane? thanks.
Old 03-30-2019, 09:32 AM   #177
RZNT4R
TSB gives 3.2 hours for valve clearance inspection without adjustment and 2.8 hours for engine R&R on a manual car. I don't think removing the valve covers, checking 16 valves, cleaning and resealing the engine is a 24 minute job, so it's probably 3.2 hours to measure it in place and every minute of that is a pain in the butt.
Also, engine R&R on an automatic allows for more time than measurement only.
Old 03-30-2019, 11:14 AM   #178
funpolice
just called the subaru dealership markham ontario canada. the service advisor says no such tsb from subaru. i don't think he tried to look up. he probably pulled up my brz profile on the computer and don't see any tsb alert associated with it.
didn't have the screenshot with me at the time.
Old 03-31-2019, 12:40 AM   #179
Larphraulen
Drives: 2018 Subaru BRZ 6m; 2012 VW GLI 6m
My car is still with the dealer after 22 days. They dropped the motor, did the valve shimming, put it back together, and put it back in the car. Should be getting it back Monday. No ECM programming/flashing done though. They said this was the first one they've had for this issue.
Sent from my Z978 using Tapatalk
Larphraulen is offline   Reply With Quote
Old 03-31-2019, 12:56 AM   #180
maslin
Benz Tech
Drives: 2017 BRZ Premium
A bulletin isn’t a recall. It won’t be flagged on your VIN. You go through the normal diagnostic procedure, if the car has a fault as described in a bulletin you follow the bulletin to perform the repair.
Bulletins are just guidance toward a known solution. Guidance that the tech is required to follow for warranty purposes.
The vast majority of people can’t pull their own codes, don’t know what a bulletin is, and don’t spend any time on forums. The car comes in with a check engine light, that’s it. You telling them the code and how they’re going to fix it doesn’t get you anywhere.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Tcoat (04-03-2019)
Old 04-02-2019, 06:01 PM   #181
funpolice
i can't remember if it's on this thread or anther thread. another owner went through this procedure(shim/ecm reprograming) and the same codes came back....
Old 04-02-2019, 06:44 PM   #182
Larphraulen
Just got my car back. The engine note has a noticeably more "rattle in a tin can" type sound to it now but no lights, no misfires, seems to drive ok so I'll take it.
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
