#169 |
As far as the holes above the rear struts in the trunk, I have driven through some hard rainstorms and I've not had any water intrusion or mildew in the trunk.
#170 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
It should be fine with just that.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#171 | |
All I know is that my rear window would completely fog up to the point of where I had to kick on the rear defrost multiple times. It has been bounds better since plugging the holes. |
#172 | |
The Answer
Drives: Mazda 2
Also If people are scared with rust in these areas, why cover it up? You want to make sure the humidity stay there and water can't evaporate? I'd just shoot a bit of rust prohibitor in there and call it a day.
#173 |
First 86
Drives: Scion FRS Argento Automatic
I went to the Scion dealer and ordered them.
Life is short...NO BORING CARS |
#174 | |
I park in my garage. The rear window would fog up after pulling out and cruising a few miles. Shoes would be dry because they never touched a wet surface. *shrug* Seems to be fine now but since you know more about me and what I do on a day to day basis then... *shrug* My car will never touch road salt so I am not worried about my car rusting. Just making an observation and covering the holes won't prevent rust. |
#175 |
Drives: 13 whiteout scion frs
Becuz racecar
#176 |
Drives: Toyota 86 TRD Version AT
This thread made me go out and check my under my car if they installed the grommets. They did. Not to mention its 1:48 am here. Haha! I know for a fact that the holes in the trunk have no plugs cause I installed coilovers already. I actually welcomed it thinking they might have thought of people installing coilovers.
#177 |
Drives: 2013 Subaru BRZ Limited(White)
My BRZ also did not have the plugs near the rear wheels(or in the glove box). I work in parts and have easy access so I ordered the Toyota part number in this post. Just got them in today and will put them in soon. Hopefully it will help with the odd smells I get in the the cabin. If not maybe I will try plugging the noise generator. I haven't checked my rear struts yet but probably will soon.
![]() Not sure if you can see it in the picture but they are stamped Subaru and have what looks to be the Subie part number on them. 90371CA010 |
#178 |
S5:F Gunmetal / Staggered
Drives: WHITEOUT 2013 SCION FRS
Just purchased a FR-S... popped the grommets in tonight!!! Another informative thread.
#179 |
I don't lie.
Drives: AE86 Successor
Thanks went to dealership on the weekend to install the plugs in trunk!
#180 |
Picked mine up last saturday. I didn't have them either over the strut or on the underside. Dealership found a set in a salesman's desk. Oops. Gonna go put them in. Dealer ordered me the top ones for the struts
| The Following User Says Thank You to suaveflooder For This Useful Post: | Marrk (02-18-2013) |
#181 | |
Drives: 2012 86
What should I do? Tap with a hammer/screwdriver? Edit: Nevermind, figured it out. And after that it was a 30-second job. *Hangs head in shame* I do wonder why a flathead screwdriver isn't included for this exact purpose, while there is a philips-head one in the trunk. And my car doesn't have the round seals on the rear strut towers (only checked the left side, but there's no reason why the right side should be different), but does have the oval grommets on the underside (both sides). Last edited by akyp; 02-19-2013 at 10:46 AM. |
#182 | |
When In Doubt...
Drives: Slowww
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
| The Following User Says Thank You to Laika For This Useful Post: | akyp (02-19-2013) |
| Basic tech info: spring rates, rear suspension, motion ratios, and you. | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 77 | 07-08-2022 03:56 PM |
| water temp | driver01 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 04-11-2013 03:57 AM |
| Impressive boot space! | BD | AUSTRALIA | 14 | 08-24-2012 05:30 AM |
| Fatal FRS Flaw!! | Skin | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-12-2012 05:21 PM |
| Pics of rear passenger area with plastic removed | JRitt | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 06-12-2012 09:17 AM |
