#1779 | |
Drives: subatoy
#1780 | |
Drives: DGM BRZ Limited
![]() ![]() Don't worry about the gear, on a dynojet it isn't going to matter. Not peak power at least. You will spool the turbo quicker though in 5th. And the powerband will look more broad. |
| The Following User Says Thank You to Coheed For This Useful Post: | nix (08-07-2012) |
#1781 | |
Boosted
Drives: Sideways
#1782 |
Boosted
Drives: Sideways
So we are currently at ~272whp/215wtq on 'unconfirmed' 8 psi.
So with a bit more tuning and a free flowing exhaust I don't see any reason why this car can't hit 300whp. And all on an untouched stock internals. Can't wait to see how everything holds up and what numbers are grinded out of 8psi.
#1783 | |
Drives: AVO BRZ
| The Following User Says Thank You to nix For This Useful Post: | Sportsguy83 (08-07-2012) |
#1784 | |
#1785 |
like was mentioned earlier though, the eddy current dynos can be different because they don't measure acceleration of a fixed mass. But the longer the pull, the less peak power is produced... typically. Lots of variables between dynos. But on the Dynojet 248c, with added ballast to 1500whp+ capability, the results speak for themselves.
#1786 | |
Drives: 2013 BRZ, 2002 WRX
If the stock internals will hold up, I'm in. Thanks again for being so transparent. My Accelerated Performance exhaust will be delivered tomorrow and then it's just a matter of time before the turbo joins it!
#1787 |
This still on factory injectors?
#1788 | |
Boosted
Drives: Sideways
#1789 |
Drives: '06 AM V8V Coupe
#1790 | |
Spaceman
Drives: 2013 Firestorm Scion FR-S
Here's the article I read this in. I'm just running my mouth based off this... http://kaizenfactor.wordpress.com/20...n-or-is-scion/ Sent from my Galaxy Nexus using Tapatalk 2
#1791 |
Rated torque capacity is just a guideline on what the OEMs can guarantee... You can usually push them to 150% capacity for a time on the track, or 300% for a weekend warrior that doesn't see a lot of abuse.
I took a transmission rated at 150tq and pushed 440tq through it for a few months before it grenaded. But it took to 350tq for years without issues. I'm sure 300wtq will do just fine for most. Keep a sprung clutch, and good gear oil. Should do just fine. |
#1792 |
Stock injectors? Also this is a .86 vband housing?
| Accelerated Performance 2013 BRZ Intake Dyno Testing Video | Don@Accelerated | Engine, Exhaust, Transmission | 109 | 05-17-2013 12:24 PM |
| Accelerated Performance 2013 BRZ Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 135 | 09-04-2012 12:24 AM |
| Accelerated Performance 2013 BRZ/FRS Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 24 | 07-07-2012 08:05 AM |
| Hello from Accelerated Performance! | Don@Accelerated | Announcements, Contests, Giveaways | 5 | 07-04-2012 09:14 PM |
