Old 07-02-2014, 01:57 PM   #1723
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Question Delay when stamping on the gas
I wonder how many of you experience a delay/sluggishness when you stamp on the gas pedal, rather than feeding the gas pedal.. when driving on the street and accelerating gradually car feels a lot stronger but on WOT it feels a bit sluggish.. I learned that the ECU on our cars limiting the throttle position to ~80% when on WOT but I am not sure if those things are related and/or there is a fix for that
thanks in advance
glamcem is offline   Reply With Quote
Old 07-02-2014, 07:27 PM   #1724
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
thanks in advance
the delay your talking about is it wot-release-then wot again?
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 07-03-2014, 04:10 AM   #1725
D-VO
Drives: Whiteout FR-S, Evo 8 RS
thanks in advance
86% on throttle is normal. It is 100%. I think the engineers were just trying to be funny. Are you guys stuck with 91 octane in Seattle? I was just having a discussion earlier today about how much timing needs to be pulled when on 91 octane.
D-VO is offline   Reply With Quote
Old 07-03-2014, 04:24 AM   #1726
glamcem
glamcem's Avatar
nope, it's the difference between stamping on gas (WOT) and squeezing the gas pedal.. the second option feels faster
we use 92 octane here and TP is 82%
Old 07-03-2014, 12:26 PM   #1727
zERoTu
Drives: 1st RBv2 10 Series FRS
Wow I just got beat by a frs with headers and exhaust. 3rd gear pull onto the highway. Wtf!!
zERoTu is offline   Reply With Quote
Old 07-03-2014, 12:41 PM   #1728
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
301hp on e85 c30 3300 elevation, custom local tune.
Taino-BRZ is offline   Reply With Quote
Old 07-03-2014, 12:42 PM   #1729
SPCorBUST
SPCorBUST's Avatar
Still no resolution on the tune?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 07-03-2014, 12:43 PM   #1730
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Taino-BRZ View Post
Attachment 83970
Good numbers. What's your setup?
Old 07-03-2014, 12:45 PM   #1731
Taino-BRZ
Taino-BRZ's Avatar
Borla uel, cat delete, 2.5 exhaust, aluminum drive shaft. E85
Old 07-03-2014, 12:48 PM   #1732
glamcem
glamcem's Avatar
and you didn't notice any bottle in the FRS' trunk (j/k)
that doesn't sound right.. Did you floor it? Do you notice the thing that I mentioned above? Do you have a dyno sheet?
Old 07-03-2014, 01:06 PM   #1733
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Delicious tune does not get happy under 2.5k when trying to rev match. Lots of popping and sluggishness.
post_break is offline   Reply With Quote
Old 07-03-2014, 01:16 PM   #1734
zERoTu
def no bottle its my friends car. all bolt on mods, no tune.
and i do know what ur talking about glamcem. once i get my headers and the cogged pulleys installed, im gonna get a tune from moto-mike. and hope for the best.
Old 07-03-2014, 01:22 PM   #1735
glamcem
glamcem's Avatar
I don't know about popping but the sluggishness should be the supercharger parasitic loss/load since the 2500 rpm looks like the break even point.. it takes power to make power so it will never feel like NA until a certain point
Old 07-03-2014, 01:23 PM   #1736
glamcem
glamcem's Avatar
so you don't have any tune on your car now or just the OTS map?
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
