go_a_way1
Old 08-17-2013, 06:34 AM   #1709
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
do u think the 30 offset is best choice over the 25? i wanna make sure it dont rub
NYCsubaruBRZ is offline   Reply With Quote
Old 08-17-2013, 02:49 PM   #1710
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by NYCsubaruBRZ View Post
i feel you on that. i took the car to tannersville a few times skiing it sucks in snow.
do i have to add camber? or will it rub if i dont? id like to not have to mess with the camber
I'm actually quite impressed with how well this car drives in the snow. If you weren't on snow tires that would explain things. :-)
Regarding rub, no, but you are noticeably outside the fender with that setup. You would need some camber or drop (which will give you a little camber) unless you want the mexiflush look.
We are talking about 5mm. :-)
The 30 is a 'better' choice.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-18-2013, 05:35 AM   #1711
Davesta619
Drives: Brz
How accurate is the recommended size from tire rack for a wheel? Looking to getting Enkei Kojin offset +45. Should I get 18x8 or 18x8.5 (does the extra .5 matter in anything?)
I plan on lowering 1" with Eibach Pro Kit Lowering Springs when I purchase the wheels. What tires will fit best and will this setup present any problems like rubbing? Im a complete noob when it comes to modding a car so any help would be greatly appreciated. Thank you.
Davesta619 is offline   Reply With Quote
Old 08-18-2013, 10:54 PM   #1712
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
I'm looking at getting some Forgestar 19x8.5 wheels with 235/35/19 tires for my ride. I won't do staggered, as I like to rotate my tires and dont want to go any heavier or wider than necessary to achieve the look I'm going for.
Given DarrenDriven's below table, I"ll need a rear 10mm spacer assembly to make the front and rear both flush with an appropriate offset. If I were only lowering the car 1", this would be simple, but I want to lower the fender just to the tops of the tires (2.5" ?). I've tried tools like the FRS Project Tire Calculator, but they don't account for the changing offset as the car lowers.
So my question is...what's the perfect offset for as close to "flush" front 19x8.5 wheel with the fender lowered just to the top of a 235/35/19 tire, with 0 rear camber and less than 2° neg front camber, without rubbing?
215/45/17 - Tire Diameter (mm) 625.30
235/35/19 - Tire Diameter (mm) 647.10
WHEEL |-- STOCK HEIGHT --| |-- LOWERED 1" --| |-- LOWERED 2.5" ?--|
WIDTH |-- FRONT REAR ----| |-- FRONT REAR --| |-- FRONT REAR --|
8.5 --- |--- +44 -- +37 -----| |--- +42 -- +32 ---| |--- +? -- +? --|
Thank you in advance.
mwjcyber is offline   Reply With Quote
Old 08-18-2013, 11:48 PM   #1713
NYCsubaruBRZ
yea i had summer tires when i was in the snow. not fun.
i know its not most peoples taste. but i actually like the mexiflush look...
so i can run 17x8 or 17x8.25 with a 30 offset and 235/50/17? no camber and no drop. no rub? is that correct?
i might add camber i just dont want to have to add camber.
The Following User Says Thank You to NYCsubaruBRZ For This Useful Post:
ill86 (08-25-2013)
Old 08-19-2013, 09:30 AM   #1714
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Tirerack is pretty accurate for tire and wheel sizing, great resource.
What are your goals for modding?
Looks, grip, track, autox, stance, power mods?
If you are just looking to change out to nicer wheels and to a better tire, then I would suggest sticking to an 8" wheel and go to a 225/40R18. This will be a nice upgrade especially with the Eibachs.
Slick is offline   Reply With Quote
Old 08-19-2013, 03:08 PM   #1715
Slick
Slick's Avatar
I would stick to a 225/35R19 or a 235/30R19. Both those sizes work well with a 8.5" wheel and are pretty damn close to factory diameter.
Not sure about spacers or offset as you didn't state what offset was available for your wheels, but you probably with need an extra 5mm on the back compared to the fronts since you will have a substantial drop. Off the top, probably +35 offset where you would want to start. See my pics further up on this page for reference.
Since you stated that you want 0 camber on the rear, you will need adjustable LCA's to pull back the camber from the drop, otherwise I would estimate about -3 camber without LCA's.
The Following User Says Thank You to Slick For This Useful Post:
mwjcyber (08-19-2013)
Old 08-19-2013, 06:48 PM   #1716
FRSEVO
Drives: Ultramarine FRS
Anyone have advice as to how much poke/camber I would need to fit a 17x10 +20 in the rear. Not looking to stretch the tire off the lip of the wheel but not looking for meaty tires either. Any and all help would be appreciated!
FRSEVO is offline   Reply With Quote
Old 08-19-2013, 07:24 PM   #1717
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
So i just ordered some 18 x 9 +38 forgestar f14s any suggestion on tires? don't want anything too meaty was thinking staggered front and back and I'm sitting on eibach pro kits.
thanks
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 08-19-2013, 09:15 PM   #1718
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
This is from the wheel fitment thread.
Originally Posted by DarrenDriven
"WHEN LOWERED 1" YOU WILL NEED TO REDUCE THE FRONT OFFSET BY 2MM AND THE REAR OFFSET BY 5MM FOR PERFECT FLUSHNESS"
Is this a linear correlation? As in, if I lower my car 1.5" will I then need to adjust offset in the front by 3mm and the rear by 7.5mm? Or is this a logarithmic/exponential correlation? In short I am planning on installing 17x9" with 245/40r17 on all four tires and plan on lowering the car 1.2-1.4" with the H&R Super Sport Springs. And was trying to figure out offset and if I will be able to sufficiently fix camber issues with camber bolts.
Turkish is offline   Reply With Quote
Old 08-20-2013, 01:43 PM   #1719
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
I just bought a new set of wheels and I am deciding on what tire selection I want. My wheel setup is 18x9.5 +45 square (on coilovers) and from what I read, people seem to run 255/35-18 or 245/35-18. I used the tire size calculator and the 245's fit a little closer to stock than the 255's. For brand I was going to get the Michelin Pilot super sports.
ApolloSki is offline   Reply With Quote
Old 08-20-2013, 06:10 PM   #1720
teamred
Drives: firestorm scion frs
ok so I just bought the gramlight 57dr 17x9 +35 and when I looked at the safe fitment
chart the guy has the stock tires stretched onto them how much rubber can I fit onto these things without rubbing im lowered about an inch on rce yellows and koni yellows?
teamred is offline   Reply With Quote
Old 08-20-2013, 07:23 PM   #1721
IE86er
Drives: FR-S Raven
I'm thinking of getting 17x9 rota grid +30 squared with Eibach Prokit. Will I rub with 225's or 235's.
Thanks
IE86er is offline   Reply With Quote
Old 08-20-2013, 07:33 PM   #1722
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Thanks
No rubs, but the wheels will poke a bit, especially in front.
You may need negative camber in front, but to me that's just a no-brainer.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
