#1667 |
Drives: '13 BRZ
Hi everyone,
I have a question about a staggered setup that I am interested in. Rims: Enkei Tuning Raijin 18x8 +45mm / 235/35-18(Front) (also have the option of going 18x8.5) 18x9.5 +45mm / 255/35-18(rear) I will be staying with stock suspension so I will be at stock ride height. How will this setup look on my car? will I experience any rubbing from the tires and the suspension? will the tires have a lot of poke from the fenders? im trying to keep it looking flush. Will this setup negativily effect my cars performance? Sorry for all the questions. First time buying new tires and im trying to make sure im staying safe. Thanks in advance for all the help! |
#1668 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
Wheel and tire combo is (most likely) heavier than OEM setup.
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#1669 | |
Drives: '13 BRZ
18x9.5 is 20.5lb (not sure how the rears r lighter...lol) If i went with 18x8.5 fronts, am i still free from rubbing? also if i switch the rubbers to 225 for the fronts? im not too sure what the specs r on the OEM setup, ill do a search right now tho |
#1670 |
Drives: 2013 FRS asphalt
just ordered my FRS to pick up tomorrow and trying to preorder 19"s.
Stock offset is 48mm? The 19"s i want to order are 19x8 with a 35mm offset. anyone know if this will be a problem? The car is NOT lowered. pleaseee help! |
#1671 | |
Drives: FR-S Firestorm 6MT
We discussed this exact setup on the previous page. See itdansharpe's sig. Last edited by Slick; 08-12-2013 at 02:04 PM. |
#1672 |
Should be fine depending on the width of tire you choose.
#1673 | |
1337
Drives: 2013 BRZ WRB S/C
They should be pretty close to flush in the front at stock height. |
#1674 |
Drives: 2013 BRZ 6MT
Hey guys I'm looking into the following setup:
17x9 +45 enkei kojins on stock suspension 245/40/17 tires I've done a lot of reading and it sounds like I may need a spacer to make this work on stock suspension in the front. I was looking into adding a 10mm hubcentric H&r spacer to the front wheels to add clearance from the strut. I am not concerned with flushness or poke, as long as it has enough clearance to fully lock the wheel with no rubbing. I will eventually drop it ~1" or so but not right now. Likely just springs, not coilovers. I'll worry about correcting the camber later. Any input would be great. Thanks! |
#1675 | |
Sounds like you've done your research. I don't think the 9" +45 will fit up front on stock suspension.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm.. |
#1676 |
#1677 |
My only concern with adding a 10mm spacer would be that you lose 10mm of thread on your lugs. Should be fine, but I'm not the one to ask regarding this.
#1678 |
^^ This...
Also, would suggest if you run spacers to run them in the rear also. The rears are already more tucked in than the front, so it may look odd if your fronts are flush (with spacers) but the rears are tucked in. |
#1679 |
Drives: 2013 Subie BRZ Limited, black, 6MT
From all I've read (and will soon find out) is that with stock struts and a 9" wide rim, you need 42mm offset for "safe" clearance. If you go with anything more than a 3mm spacer, you'll need longer studs too.
#1680 |
Drives: S
Just got a set of 18x8.5 +35 square set up. I'm not sure if I want to go 225 or 235, so I will likely try both: 225/40/18 F and 235/40/18 R - I can always just buy two new tires. I also will likely have a set of Eibach Sportline springs (-1.4") in the mail this week, going to coils before Winter. I also will want to bring camber as close back to spec as possible.
Any issues? Also, I want to bring the rear wheels out close to flush - maybe 10-15mm? For that adjustment, I saw that adapters (as opposed to spacers/bolts) would be a better option? Haven't really found too much on people running with adapters. Input? |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
