Old 03-05-2025, 01:57 PM   #155
StraightOuttaCanadaEh
Wes
Originally Posted by blsfrs View Post
I am not aware of any 2 piece stock/non-Brembo rotors. Do you have a link?
https://86speed.com/dba-slotted-5000...qDidecfWqJk_xa
it says stock brakes, no mention of brembo or performance pack
Instagram: @gt86ws
Old 03-05-2025, 09:36 PM   #156
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
IAG site says this, but I'm with you. It sound like the rotors fit non Brembo packages. I guess you need to call and get a definitive answer.
DBA 5000 Series T3 Slotted 2 Piece Front Brake Rotor (Single) For 2002-14 Subaru WRX, 04-13 FXT, 13-20 BRZ / FR-S
and
The DBA 5000 Series is a lightweight 2 piece design that features a aluminum center hat and steel rotor. The 5000 series utilizes a High Carbon Alloyed Iron rotor with Thermal Stability Profiling allowing for constant heat cycles generated from "late braking" scenarios. weekend track race events. *Does not fit BRZ limited.
Old 03-05-2025, 09:52 PM   #157
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
My OEM rotors (from 2017 with 140 km on them!) are finally due to be changed. I'm very confused about 2 piece rotors. According to google they're only a little bit lighter than the oem pieces, but not sure if that means brembo or non-brembo. I have the latter, so anyone know if there is a weight reduction there? Are those 17 lb or is that for the brembo rotors?
326mm cast blank rotors for Brembo are 23 lb.
294mm cast blank rotors for base are 17 lb.
Cost for weight reduction of 2pc rotors for base brakes isn't compelling. They'll wear out not much slower than blank rotors, you barely lose any weight, and you're paying 5x more.
Finally overall, DBA 2pc solutions seem to be pretty inefficient with weight reduction.
- For example, the DBA 2pc for Brembo comes in at 20.3 lb, while Girodisc's comes in at 16.5 lb
EndlessAzure is offline   Reply With Quote
Old 03-05-2025, 11:16 PM   #158
Wes
Thanks, I figured. I was gonna combine it with lighter wheels for a significant weight drop per corner but only if it was 5lb+. From the sound of it it's not even 1 lb
Instagram: @gt86ws
Old 03-06-2025, 12:59 PM   #159
blsfrs
blsfrs's Avatar
I wonder if there is a heat dissipation advantage?
Old 03-06-2025, 06:56 PM   #160
Wes
Apparently they overheat more cause of less metal for the heat to dissipate into, but maybe that's just conjecture
Instagram: @gt86ws
Old 03-12-2025, 01:47 PM   #161
Tokay444
Anti stance.
Tokay444's Avatar
That's what you asked for.
brake, discs, lines, pads, rotors
R1 Concepts Brakes upgrade carlossanchez89 Brakes, Suspension, Chassis 1 01-13-2014 08:28 PM
Brakes for Turbo Upgrade? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 08-29-2013 06:49 PM
HELP with understanding Brakes upgrade path bear89103 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-17-2013 07:08 PM
[StreetFX] 86 GT HID upgrade kit with DIY GUIDE! (including parking lights) WTF Australia Classifieds 12 08-14-2012 03:10 AM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:27 AM
