#155 | |
Wes
it says stock brakes, no mention of brembo or performance pack
Instagram: @gt86ws
#156 | |
Drives: 2013 frs base
DBA 5000 Series T3 Slotted 2 Piece Front Brake Rotor (Single) For 2002-14 Subaru WRX, 04-13 FXT, 13-20 BRZ / FR-S and The DBA 5000 Series is a lightweight 2 piece design that features a aluminum center hat and steel rotor. The 5000 series utilizes a High Carbon Alloyed Iron rotor with Thermal Stability Profiling allowing for constant heat cycles generated from "late braking" scenarios. weekend track race events. *Does not fit BRZ limited. |
#157 | |
Wheels for Brains
294mm cast blank rotors for base are 17 lb. Cost for weight reduction of 2pc rotors for base brakes isn't compelling. They'll wear out not much slower than blank rotors, you barely lose any weight, and you're paying 5x more. Finally overall, DBA 2pc solutions seem to be pretty inefficient with weight reduction. - For example, the DBA 2pc for Brembo comes in at 20.3 lb, while Girodisc's comes in at 16.5 lb |
#158 | |
Wes
Instagram: @gt86ws
#159 |
#160 |
Wes
Apparently they overheat more cause of less metal for the heat to dissipate into, but maybe that's just conjecture
Instagram: @gt86ws
#161 | |
Anti stance.
| Tags |
| brake, discs, lines, pads, rotors |
| R1 Concepts Brakes upgrade | carlossanchez89 | Brakes, Suspension, Chassis | 1 | 01-13-2014 08:28 PM |
| Brakes for Turbo Upgrade? | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 08-29-2013 06:49 PM |
| HELP with understanding Brakes upgrade path | bear89103 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 07-17-2013 07:08 PM |
| [StreetFX] 86 GT HID upgrade kit with DIY GUIDE! (including parking lights) | WTF | Australia Classifieds | 12 | 08-14-2012 03:10 AM |
| [StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:27 AM |
