Koji_Online
Old 12-17-2012, 04:13 PM   #155
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Since I did mine I notice a burning clutch smell every once and awhile. Not sure if its from driving with boots on with this light clutch or if the engagement point is too low. Its even with the brake pedal right now.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 12-17-2012, 05:36 PM   #156
developer
Drives: BRZ Limited
Originally Posted by hybrid4g View Post
whoever said this was easy...
I think my neck and back are ruined now --- I could have used a highly trained small monkey with tiny hands to do this. Also the small rod was not easy to turn at first (NEED GRIP).
However --- after all is said and done my cluch petal is adjusted just slightly lower than the brake pedal (I have not measured yet) and it does feel better. Instead of reaching an engagment point at 80% out of clutch it is more like 50% now. I did have to adjust the sensor for the cruise/gear thing.
I am still not used to how LIGHT the clutch is. I thought this mod made it feel lighter or that I did something wrong but I think the clutch is just really light to begin with.
Thanks much for this DIY!!!
(long time lurker --- but just got an FRS last friday---PICS LATER )
I also noticed that mine is noticeably lighter now. I think it might have something to do with the downward adjustment precompressing the clutch return spring that sits on the firewall.
developer is offline   Reply With Quote
The Following User Says Thank You to developer For This Useful Post:
EBMCS03 (12-18-2012)
Old 12-18-2012, 01:17 AM   #157
EBMCS03
Drives: Argento FR-S
Thanks for this post I already find the clutch waaaay too light for my liking and the clutch pedal travel to be too short also so I guess I'm staying away from this mod.
It has too much of a springy feel like its on rubber bands vs a spring.
EBMCS03 is offline   Reply With Quote
Old 12-18-2012, 01:25 AM   #158
cf6mech
Drives: FRS Silver LS1 swapped.
this is a good fix,....props to the op,...my left leg sure appreciates it
cf6mech is offline   Reply With Quote
Old 12-20-2012, 11:59 AM   #159
choi0706
Drives: t
+1 adjusted but softer now.. but damn the high engagement made it hard to drive..
choi0706 is offline   Reply With Quote
Old 12-21-2012, 02:12 PM   #160
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Drives: '13 BRZ SWP Ltd --> '24 Trueno Ed
Love it!
Got my SWP BRZ on monday and just did this DIY and it's so much better! Thanks!
ScottDRFT is offline   Reply With Quote
Old 12-22-2012, 05:20 PM   #161
xxscaxx
Drives: 2013 SWP BRZ
Did this mod yesterday. Its been on my list, just haven't gotten around to it.
My god what a difference. Car is so much more enjoyable to drive now. Have it set slightly higher than the brake pedal.
Adjustment took less than 5 minutes. I am not sure what some are talking about it in here about those bolts being tight, unless you have the strength of a 12 year old lol. Maybe my bolts weren't as tight but they broke free with little force. It was a little tricky adjusting the cruise control sensor because you need to use both hands and contort all crazy but overall it was easy.
If you haven't done this mod, get on it!
xxscaxx is offline   Reply With Quote
Old 01-03-2013, 01:48 AM   #162
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
just did it. big props to op! simple yet amazing mod. took me like 30 mins tho just coz i waas too scrade of screwing anything up haha
Dispect is offline   Reply With Quote
Old 01-03-2013, 09:13 AM   #163
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
Yes, thanks to OP. i asked my dealership to adjust this on arrival a week before the car arrived from japan they looked at me like i was kidding... They had only sold maybe 4, and serviced none at that point though...
jshadeck is offline   Reply With Quote
Old 01-03-2013, 11:32 PM   #164
Dang Lad
Dang Lad's Avatar
Drives: Asphalt MT FR-S
Thanks again to Koji for the OP and Joe for the great video based on Koji's post. I just adjusted mine (about 10 minutes) to be just about even with the brake pedal and already felt so much better after going around the block a couple of times.
I also had the feeling that there wasn't any play with the clutch, until I realized it was only because I had to constantly angle or hover my foot, and the only time I could come in contact with the clutch was to shift. The clutch feel was my biggest/only gripe with the car, and now I'm looking forward to seeing the results as I get more used to the new set-up!
Dang Lad is offline   Reply With Quote
Old 01-05-2013, 12:56 PM   #165
mrjester
What an amazing difference this made. It is like a new car again! I positioned the clutch pretty much even with the brake like so many others. This was one of the only real gripes I had about the car. The clutch feel. Now it is very reminiscent of my SI which, to me, had a perfect clutch.
mrjester is offline   Reply With Quote
Old 01-06-2013, 09:45 PM   #166
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
I Just Did Mine, I Think I May Have Set It Too Low. It Should Be Good As Long As It's Not Grinding Or Anything Right?
Cade01 is offline   Reply With Quote
Old 01-12-2013, 02:31 AM   #167
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
Did mine as suggested by OP (just a tad under the brake). Night and day in terms of how much easier it is to find the bite point. Hill starting like a baws now
EDIT: oh yeah its a bit harder to screw the bolt back on in our RHD 86s as the rod is directly connected to the clutch, not through the rotating arm, and as a result there is a lot of shit that prevents you from properly getting a wrench on it - had to temporarily remove the white stopper grommet and use a short wrench in order to secure it properly.
proficience is offline   Reply With Quote
Old 01-15-2013, 01:20 AM   #168
Intake
BRZ
Intake's Avatar
The clutch is already really soft, did you guys adjust it to make the engagement lower? I feel that this car has a really soft clutch and a high catch for how soft it is, but easy to drive for sure.
Intake is offline   Reply With Quote
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 11:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 03:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 02:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
