Old 02-11-2012, 08:41 PM   #155
serialk11r
Drives: '06 AM V8V Coupe
^^^ the virtues of a 6 speed gearbox. Actually, having a lot of pull in 6th gear isn't really a good thing IMO since an overdrive gear should be optimized for 50-80mph range efficiency, but the closer ratios in between are definitely helping.
Old 02-11-2012, 09:41 PM   #156
bw1235
Drives: 2002 WRX / 2011 STI
Originally Posted by Deslock View Post
Here's a rough estimate for comparing acceleration of the BRZ and WRX. As expected, once the WRX hits boost the BRZ never matches it. Still, I was a little surprised to see that:
  • The BRZ in 6th gear has more pull than the WRX in 5th until 70 MPH.
  • The BRZ has more pull than the WRX when both are in 5th.
  • The BRZ has more pull than the WRX when both are in 4th until 55 MPH.
This doesn't account for traction and of course it doesn't take much to increase the WRX's output. Even stock, it'll be 1.2-1.5 sec faster just to 60 MPH.
... and it doesn't account for the WRX's, um, brick-like aero =)
bw1235 is offline   Reply With Quote
Old 02-11-2012, 09:57 PM   #157
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Actually it does. Read the text on the bottom left of the plot.
Deslock is offline   Reply With Quote
Old 02-11-2012, 10:34 PM   #158
serialk11r
How did you add drag in? CdA 1/2 \rho v^2?
Old 02-12-2012, 01:31 AM   #159
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
also note that he is using the 4.1 final drive which we probably will not be getting here. Thank you CAFE.
Homemade WRX is offline   Reply With Quote
Old 02-12-2012, 03:09 AM   #160
serialk11r
I doubt it, current fuel economy regulations in Europe/Japan are probably stricter than they are in the US but 2016 will be different. Higher final drive doesn't hurt city test economy much anyways. What I want to see is a crazy 0.6 6th gear with 4.100 final drive, best of both worlds. Probably something like a 10-15% fuel economy increase on the highway as it'll decrease rpms by 14% compared to the 3.727 final drive even. With a 3.727 final drive you'd be getting into like 260-270g/kwh cruise which is great but you'd lose first gear acceleration.
Old 02-12-2012, 03:09 AM   #161
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
looks like only Cd was used not CdA.
WingsofWar is offline   Reply With Quote
Old 02-12-2012, 06:43 AM   #162
Deslock
Deslock's Avatar
1/2 * VFA * CoD * rho * V^2
rho varies depending on temp, elevation, etc but I used 0.00235 slugs/ft^3
I used VFA of 23.68 ft^2 for the WRX (found from google) and approximated the BRZ as 20.5 ft^2. I think the VFA I initially used for the BRZ was a bit too low, so I changed it and added more notes to the plot.
I used this WRX dyno:
http://www.clubwrx.net/forums/engine...yno-pull.html:
I know nothing about rolling resistance, but I based my numbers on the formulas I found at http://www.mayfco.com/aero1.xls which was discussed at http://www.rx7club.com/showthread.php?t=541682
Other links:
http://www.miata.net/garage/tirecalc.html
http://www.mayfco.com/mazda.htm
http://www.engineeringtoolbox.com/ca...on-d_1309.html
(I used the last two linkes to make sure my numbers were in the right ball park)
Old 02-12-2012, 07:05 AM   #163
serialk11r
Rolling resistance is a constant value, good estimate is about 0.008 of the car's weight.
Old 02-12-2012, 08:12 AM   #164
old greg
Rocket Surgeon
Drives: PSM GGA OMG
For force, yes. For power, it scales linearly with speed.
Oh, and LRR prius tires FTW.
old greg is offline   Reply With Quote
Old 02-12-2012, 08:22 AM   #165
serialk11r
The stock Prius tires are in the 0.006xx range :O Michelin Primacy tires all look to be a tad over 0.008, and there is some Bridgestone tire that is 0.00615, pretty ridiculous.
Old 02-12-2012, 09:40 AM   #166
Deslock
Deslock's Avatar
Yeah at legal speeds rolling resistance ends up being close to 0.008 * weight, but according to that spreadsheet it starts increasing around 80 MPH and it's significant above 100 MPH.
The formulas in the spreadsheets are:
fs = Speed Effect Coefficient
V = speed (mph)
Fd = force rolling drag (lbs)
fo = 0.008
W = weight (lbs)
fs = 0.00195 + 0.000024833 * (V - 150)
Fd = (fo + 3.24 * fs * (V/100)^2.5) * W
From what I've read, though the force required to offset rolling resistance isn't related to velocity, at high speed the additional heat increases the coefficient of friction. I got curious about the formula's numbers and the 5/2 exponent, so I clicked around the domain where the spreadsheet came from and found rolling drag at http://www.mayfco.com/keith.htm
DR = W * (fo + 3.24 * fs * (V * (60/88)/100)2.5 (where 60/88 is just a conversion)
It's also mentioned at
http://www.physicsforums.com/archive.../t-321017.html
http://www.ffcars.com/forums/17-fact...top-speed.html
At some point I might dig my old textbooks out of the basement to look it up.
Anyway, while putting this together last night, it also occurred to me that the FT86's "Prius" tires ought to be advantageous for this. Everyone bashes them, but if steering feel is as good as the reviews say, then I think they make sense.
Old 02-12-2012, 07:46 PM   #167
serialk11r
Coefficient of friction doesn't matter as long as the tires don't slip...?
I'd think that at higher speeds the tire actually becomes stiffer since it experiences strong centripetal forces...
I think the reason why it apparently takes extra power at high speeds could be the fact that C_d changes a bit as speed changes. I'm not sure about this but for example a fastback whose rear windshield is angled at 20 degrees could have attached flow at 40mph, but at 120mph the flow will have significant separation and a much larger wake. With FlowIllustrator (a 2d fluid dynamics thingy) turning up the reynolds number definitely has this effect.
Old 02-12-2012, 08:22 PM   #168
old greg
Rocket Surgeon
Drives: PSM GGA OMG
The extra heat is not the cause, it is the effect. Rolling resistance isn't caused by friction, but rather by hysteresis in the rubber. Basically, as the tire rolls forward and a certain patch of rubber comes into contact with the pavement, that rubber gets squished and stores up energy like a spring. As the tire continues to turn and the patch of rubber starts to lift off of the pavement it pushes away from the road and releases most of the stored energy, most but no all. The difference in energy has been absorbed by the tire as heat.
If I had to make a wild guess about that exponential velocity component, I'd say it comes from the viscoelastic nature of rubber. The faster you try to squish it, the harder it is to squish, and presumably the higher its hysteresis becomes.
2013 Porsche Boxer is revealed early DIG1992 Other Vehicles & General Automotive Discussions 62 09-05-2012 12:26 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Toyota Reconfirms Production 2012 FR-S / FT-86 Boxer Engine, 6MT, 6AT, LSD Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 30 05-02-2011 03:30 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 01:47 AM
