Old 02-10-2012, 05:22 PM   #141
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by ahausheer View Post
why do F1 cars have basically no torque...?
Because they are required to be 2.4L, duh.
In torque-centric terms, the high rpms at which F1 motors operate allow a relatively large gear reduction and fairly significant torque at the wheels.
Please ignore the fact that I'm saying Torque x RPM is what matters.
old greg is offline   Reply With Quote
Old 02-10-2012, 05:22 PM   #142
Dimman
Kuruma Otaku
Dimman's Avatar
Anyone want to overlay some rpm drop by gear over this graph? Throw in some wheel torque figures by gear too?
Because titanium.
Old 02-10-2012, 05:25 PM   #143
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Did we get gear ratio info while I wasn't looking?
Old 02-10-2012, 05:27 PM   #144
Dimman
Kuruma Otaku
Dimman's Avatar
Japanese brochures I thought. I remember seeing for sure the two different diff ratios (stripper JDM gets like a 3.73:1, while the rest are 4.10:1, I think...).
Edit:
Because titanium.
Old 02-10-2012, 05:29 PM   #145
serialk11r
Drives: '06 AM V8V Coupe
Yea, I almost have them memorized already rofl. 4.1f/d (or 3.727 non-lsd), 3.626, 2.188, 1.541, 1.213 (had to look these two up), 1.000, 0.767. Wheel is 24.6 inches I think. Okay 24.61 or 625mm.
Old 02-10-2012, 05:30 PM   #146
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by Exage View Post
This was already answered with the bike question I believe.
Power = Force X Distance / Time
HP is roughly calculated with: Torque x Rpm / 5252
5252 is some conversion factor I don't have the heart to research right now.
Speed of the engine torque is applied at gives you the amount of power the engine is producing at RPM.
Something like 10m (~33ft) cable with a 10kg (~22lbs) weight attached, and you have a spool/drum to do a vertical lift. I'm in metric sorry for those who use the imperial.
The force is 10kg x 9.81m/s2 (gravity), distance 10m. Two electric motors lift the weight up vertically. One motor takes 20 seconds the other 30 seconds. They didn't do the same work despite delivering the same force:
(98.1N X 10m / 20s) = 49.1W : In 1 minute this motor can lift 10kg 3 times.
(98.1N X 10m / 30s) = 32.7W: In 1 minute this motor can lift 10kg twice.
Also the RPM of the spool will be different: I'm sure you can figure out which is faster. It's hard to explain, I hoped going liner (strait line) helped.
____________
People try to keep RPM low. Fuel economy, engine wear, noise etc... The way to counter lack of power at daily driving speeds is an increase in torque. This is achieved through drive-train design. Hence when SUB says his RSX is gutless because it has little torque, what he means is it develops insufficient power for his liking at low rpm (or the whole range).
SUB-FT86 is offline   Reply With Quote
Old 02-10-2012, 05:33 PM   #147
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Bling bling.... can we get spinners from the factory, or are they a dealer installed option?
Old 02-10-2012, 07:18 PM   #148
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Manual = Blue
Auto = Red
Purple = Manual 5th and Auto 4th
Name:  torque v speed.png
Name:  rpm v speed.png
It looks like the car would benefit from a few more rpm up top, even without any mods.
Old 02-10-2012, 07:24 PM   #149
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
Ok, for all you smarty pants, if torque is what moves you and is also what you ''feel'' why do F1 cars have basically no torque and super high Hp? I still argue that, in the end, HP is more important. That's why we see power to weight, not torque to weight metrics.
It's a 2.4L so more RPM = more air = power but because it's power at RPM, Torque is comparatively seem lower. Then take into account that they gear the shit out of them, which is a torque multiplier.
I see Greg posted some. I have mine with lines drawn back to gear drop from redline but otherwise the same...and it isn't on this computer but now you get the point.
Homemade WRX is offline   Reply With Quote
Old 02-11-2012, 08:46 AM   #150
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Here it is with 15% drivetrain loss.
Deslock is offline   Reply With Quote
Old 02-11-2012, 11:53 AM   #151
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Thanks for sharing the graphs guys, that helps a bunch.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 02-11-2012, 01:10 PM   #152
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I love it when you guys get technical
I get to learn something new all the time
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 02-11-2012, 02:16 PM   #153
bw1235
Drives: 2002 WRX / 2011 STI
Based on Subau's history of horrible tunes on the STI, I wouldn't be surprised if the torque dip is due to emissions/economy, but time will tell. If it's anything like their turbo tunes, the dip would be where the AFRs drop from too lean to too rich...
That would certainly be a good thing- it would be straightforward to tune out.
Found a quick example here with AFR: http://www.iwsti.com/forums/2731193-post16.html
bw1235 is offline   Reply With Quote
Old 02-11-2012, 08:33 PM   #154
Deslock
Deslock's Avatar
Here's a rough estimate for comparing acceleration of the BRZ and WRX. As expected, once the WRX hits boost the BRZ never matches it. Still, I was a little surprised to see that:
  • The BRZ in 6th gear has more pull than the WRX in 5th until 70 MPH.
  • The BRZ has more pull than the WRX when both are in 5th.
  • The BRZ has more pull than the WRX when both are in 4th until 55 MPH.
This doesn't account for traction and of course it doesn't take much to increase the WRX's output. Even stock, it'll be 1.2-1.5 sec faster just to 60 MPH.
2013 Porsche Boxer is revealed early DIG1992 Other Vehicles & General Automotive Discussions 62 09-05-2012 12:26 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Toyota Reconfirms Production 2012 FR-S / FT-86 Boxer Engine, 6MT, 6AT, LSD Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 30 05-02-2011 03:30 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 01:47 AM
