Old 08-01-2025, 11:03 AM   #155
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
What is this from?
and also is that John Candy?
smackrel is offline   Reply With Quote
Old 08-01-2025, 11:57 PM   #156
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by blsfrs View Post
My FA20 "seized" because of a broken piston.
That was a good one. Wonder what ultimately caused that? I used to see kind of similar failures on 4 stroke motocross bikes when they came out. Worn piston would break the skirt off and shove it into the head sideways then throw the rest of it through the bottom of the engine.
Old 08-02-2025, 11:05 AM   #157
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
A couple of years prior to this, the engine ingested something into cyl #3. It chucked 2 rocker arms and broke the timing chain. The top of the piston looked "peppered" but otherwise didn't appear damaged. The engine was reassembled with new rings, bearings, etc.. As I remember, the pistons were even sent out to have the skirts recoated.
I suspect the piston had damage that wasn't evident on a visual inspection. Hence: boom.
Old 08-02-2025, 11:11 AM   #158
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Originally Posted by smackrel View Post
What is this from?
SCTV (1976-84) Canadian. Yes, John Candy. The other is Joe Flaherty.
They've done some stuff since then. Only blowed up sorta a little.
FA20 Engine Oiling, Bearings, and Starvation Element Tuning Engine, Exhaust, Transmission 776 04-20-2024 04:25 AM
VVT Problems: 100$ reward for a solution!! Exhaust targets all 0, intakes no response bren5279 Forced Induction 12 03-14-2017 07:34 AM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
An alternate solution to Drone problems 86-tundra Engine, Exhaust, Transmission 1 09-26-2013 02:50 AM
Question about oiling filters showbe Engine, Exhaust, Transmission 7 10-25-2012 09:50 PM
