#155 |
Drives: '13 Scion FR-S & '17 Toyota 86
#156 |
Drives: 2014 BRZ Limited
| The Following User Says Thank You to shadow_772 For This Useful Post: | eastendraceshop (01-24-2019) |
#157 | |
-Armrest -Quik Latches (bumper) - halfway, gotta pick up a larger step up bit tomm -Headlights (1/2, got them in, tested, and tomorrow going to wire them up a bit differently than the norm I think that's it haha |
#158 | |
Very Nice! I love the quick latches! They help get rid of the bumper sag! As for the headlights.. ![]() Side note: I got my Morimoto Fog Lights installed this weekend!
| The Following User Says Thank You to eastendraceshop For This Useful Post: | Rican_D (01-29-2019) |
#159 |
Drives: Asphalt FR-S
| The Following User Says Thank You to Rican_D For This Useful Post: | eastendraceshop (01-29-2019) |
#160 |
| The Following User Says Thank You to eastendraceshop For This Useful Post: | Rican_D (01-30-2019) |
#161 |
So am i going potato here? Auto levelers means that the switch inside the car to shift the lights up and down doesnt work anymore, so how do we go about leveling?
#162 |
Drives: 2017 Toyota 86
#163 | |
Drives: 2013 WRB BRZ Limited
We have a electronic control on the inside of the cabin via a switch. the headlights themselves still have a manual adjustment on the back. Pop the hood, then stick a screwdriver into the adjustment knob and adjust their height according to spec... just like every car before them. EVEN if you have the electronic adjustment you can manually adjust them. -B |
| The Following 3 Users Say Thank You to HeresMyMind For This Useful Post: |
#164 |
Hmm i didnt see the normal couple adjustment screws/bolts, but then again i only had to worry about that on old trucks that were pretty obvious to adjust. The morimotos have that small sealed electronic unit on the back that i thought was to be plugged in, allowing for manual adjustment from inside, I may be mistaken, or maybe i forgot a plug. Ill look in the AM when im out of work.
#165 |
Ah, nevermind, i just popped the hood quickly here and i can see the little plastic knob on there! Thanks for the polite response to that haha
| The Following 3 Users Say Thank You to shadow_772 For This Useful Post: |
#166 |
Got some more shots for you guys!
#167 |
I'll have to sort out an issue. I wired in an aux fuse box at the same time I did headlights. Everything works well with the exception of the dimming feature on the clock and radio. I'm either full bright or nothing on the clock and dim on the radio, then when headlights are on I'm in max dim on clock and radio... hmm
#168 |
Drives: 2023 BRZ
How is overall light output with these compared to OEM HIDs?
Director of Rocky Mountain 86CUP
| Spec-D Headlights & Morimoto D2S HID Kit | FyeaFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 03-10-2017 01:19 AM |
| 6K H11 Morimoto HID Kit | Zero90 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 05-20-2014 01:49 PM |
| FS: FRS HID Retrofit Kid (Morimoto) | Khyron686 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 04-21-2014 11:08 PM |
| Stock FR-S Headlights & Tail Lights, Morimoto Elite HIDs, and OEM Mud Guards | tbox | Exterior Parts (Aero, Lighting, Etc.) | 14 | 01-11-2014 03:18 PM |
| Help Morimoto HID kit | Jacob G. | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-18-2013 03:03 AM |
