Old 01-23-2019, 05:38 PM   #155
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Originally Posted by shadow_772 View Post
I need to install mine 0.o
What are you waiting for? It's completely plug-and-play and super easy!
eastendraceshop is offline   Reply With Quote
Old 01-23-2019, 08:51 PM   #156
shadow_772
Drives: 2014 BRZ Limited
My work schedule hasn't allowed for it yet haha. I'm hoping to get it done this weekend.
shadow_772 is offline   Reply With Quote
The Following User Says Thank You to shadow_772 For This Useful Post:
eastendraceshop (01-24-2019)
Old 01-26-2019, 11:32 PM   #157
shadow_772
Well, I managed to get the following installed:
-Armrest
-Quik Latches (bumper) - halfway, gotta pick up a larger step up bit tomm
-Headlights (1/2, got them in, tested, and tomorrow going to wire them up a bit differently than the norm
I think that's it haha
Old 01-28-2019, 12:23 PM   #158
eastendraceshop
-Armrest
Very Nice! I love the quick latches! They help get rid of the bumper sag! As for the headlights..
Side note: I got my Morimoto Fog Lights installed this weekend!
The Following User Says Thank You to eastendraceshop For This Useful Post:
Rican_D (01-29-2019)
Old 01-29-2019, 12:05 PM   #159
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
I got the same turn signals
Sent from my Pixel 2 XL using Tapatalk
Rican_D is offline   Reply With Quote
The Following User Says Thank You to Rican_D For This Useful Post:
eastendraceshop (01-29-2019)
Old 01-29-2019, 12:20 PM   #160
eastendraceshop
They look great!
-Sam
Rican_D (01-30-2019)
Old 01-29-2019, 08:16 PM   #161
shadow_772
So am i going potato here? Auto levelers means that the switch inside the car to shift the lights up and down doesnt work anymore, so how do we go about leveling?
Old 01-29-2019, 10:54 PM   #162
Mr_Eyo
Drives: 2017 Toyota 86
Mine didn't have the leveling motors to plug into, just the actuator to switch to high beams.
Mr_Eyo is offline   Reply With Quote
Old 01-29-2019, 10:57 PM   #163
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
AUTO leveling is for cars that have sensors built into them that will level the beams depending on the weight in the car and the angle of the hill.
We have a electronic control on the inside of the cabin via a switch.
the headlights themselves still have a manual adjustment on the back. Pop the hood, then stick a screwdriver into the adjustment knob and adjust their height according to spec... just like every car before them. EVEN if you have the electronic adjustment you can manually adjust them.
-B
HeresMyMind is offline   Reply With Quote
The Following 3 Users Say Thank You to HeresMyMind For This Useful Post:
Chimera (01-30-2019), eastendraceshop (01-30-2019), shadow_772 (01-29-2019)
Old 01-29-2019, 11:52 PM   #164
shadow_772
Hmm i didnt see the normal couple adjustment screws/bolts, but then again i only had to worry about that on old trucks that were pretty obvious to adjust. The morimotos have that small sealed electronic unit on the back that i thought was to be plugged in, allowing for manual adjustment from inside, I may be mistaken, or maybe i forgot a plug. Ill look in the AM when im out of work.
Old 01-29-2019, 11:55 PM   #165
shadow_772
Ah, nevermind, i just popped the hood quickly here and i can see the little plastic knob on there! Thanks for the polite response to that haha
The Following 3 Users Say Thank You to shadow_772 For This Useful Post:
Chimera (01-30-2019), eastendraceshop (01-30-2019), HeresMyMind (01-30-2019)
Old 02-28-2019, 07:31 PM   #166
eastendraceshop
Got some more shots for you guys!
The Following 5 Users Say Thank You to eastendraceshop For This Useful Post:
8RZ (03-19-2019), Chimera (03-13-2019), nyfries (03-12-2019), Rican_D (02-28-2019), zeal86 (02-28-2019)
Old 03-19-2019, 12:04 PM   #167
shadow_772
I'll have to sort out an issue. I wired in an aux fuse box at the same time I did headlights. Everything works well with the exception of the dimming feature on the clock and radio. I'm either full bright or nothing on the clock and dim on the radio, then when headlights are on I'm in max dim on clock and radio... hmm
Old 09-12-2019, 04:24 PM   #168
Pat
Pat's Avatar
Drives: 2023 BRZ
How is overall light output with these compared to OEM HIDs?
Spec-D Headlights & Morimoto D2S HID Kit FyeaFRS Cosmetic Modification (Interior/Exterior/Lighting) 9 03-10-2017 12:19 AM
6K H11 Morimoto HID Kit Zero90 Exterior Parts (Aero, Lighting, Etc.) 2 05-20-2014 12:49 PM
FS: FRS HID Retrofit Kid (Morimoto) Khyron686 Exterior Parts (Aero, Lighting, Etc.) 2 04-21-2014 10:08 PM
Stock FR-S Headlights & Tail Lights, Morimoto Elite HIDs, and OEM Mud Guards tbox Exterior Parts (Aero, Lighting, Etc.) 14 01-11-2014 02:18 PM
Help Morimoto HID kit Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 4 02-18-2013 02:03 AM
