#155 | |
Drives: GTS 86
Runner before after 1. 431 472 2. 433 474 3. 430 471 4. 427 468 Hope this helps |
| The Following 5 Users Say Thank You to Hawk77FT For This Useful Post: | Dr. BRZ (02-12-2019), D_Thissen (02-15-2019), lamawithonel (02-13-2019), Tokay444 (02-12-2019), Tristor (02-13-2019) |
#156 |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Hawk77FT (02-13-2019) |
#157 |
The (aged) NA motor being used for testing failed while exploring high RPM gains. A new OEM engine is being sourced to continue testing.
| The Following 16 Users Say Thank You to CSG Mike For This Useful Post: | BatStig (02-13-2019), chaoskaze (02-13-2019), CkOne (04-12-2019), Code Monkey (02-12-2019), DocWalt (02-15-2019), Hawk77FT (02-17-2019), JBezugs (02-13-2019), JonAvalon (02-12-2019), Lantanafrs2 (02-12-2019), mistople (02-13-2019), NoHaveMSG (02-12-2019), RayRay88 (02-12-2019), SuperTom (02-12-2019), Teseo (02-13-2019), TheStig85 (02-13-2019), Turdinator (02-14-2019) |
#158 |
Drives: Crapcan
#159 |
Drives: Subaru BRZ
#160 |
I'm actually quite impressed with the delta between the factory runners. Quite a well made unit, as one would assume something N/A at over 100hp/L would need to be.
#161 | |
Drives: GTS 86
Well, I have used the new intake manifold (2017) for this exercise. The guy that did it for me said that it actually flows really well, and has seen these numbers on bigger engine Porsches...so, looks like the intake manifold is pretty well built. |
#162 |
Drives: frs
And now the 17' intake manifold will cost more
| The Following User Says Thank You to Teseo For This Useful Post: | Hawk77FT (02-13-2019) |
#163 | |
Drives: A Hot Mess
ive always tossed up the idea of doing that to the 2017 and sandblasting the outside and having it thermal coated to prevent heat soak.
one of the first people to ruin the frs.
#164 |
Drives: GTS 86
#165 |
Drives: GTS 86
About 450 AUD and had it ceramic coated as well afterwards. Haven't had a chance to hit the dyno, but compared to my previous set up there is a quantifiable improvement for sure. I should get it done pretty soon!
#166 |
Drives: 2017 Subaru BRZ
Bump, any updates?
#167 |
Señor Member
Have you had a chance to dyno your car with the manifold?
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | Hawk77FT (06-10-2019) |
#168 |
Drives: GTS 86
| The Following User Says Thank You to Hawk77FT For This Useful Post: | Turdinator (06-10-2019) |
| In for the long haul Ultimate NA build thread. | celek | Engine, Exhaust, Transmission | 683 | 06-07-2020 07:26 PM |
| TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL | Andrew666 | AUSTRALIA | 8 | 11-19-2018 05:24 AM |
| RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** | RallySport Direct | Transmission and Driveline | 92 | 09-01-2015 01:17 PM |
| RallySport Direct's Ultimate Interior Thread! | RallySport Direct | Interior Parts (Incl. Lighting) | 45 | 03-25-2015 02:12 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 06:25 PM |
