Old 02-12-2019, 05:58 PM   #155
Hawk77FT
Drives: GTS 86
Originally Posted by Tokay444 View Post
Less restriction? What are the flowbench numbers of the stock manifold?
Keep in mind now, the engine will be ingesting measurably warmer air.
CFm - after my intake manifold extrude honing.
Runner before after
1. 431 472
2. 433 474
3. 430 471
4. 427 468
Hope this helps
Hawk77FT is offline   Reply With Quote
Old 02-12-2019, 06:44 PM   #156
Tokay444
Anti stance.
Tokay444's Avatar
Runner before after
1. 431 472
2. 433 474
3. 430 471
4. 427 468
Hope this helps
It does when we have flow numbers for these ITBs, and the heads.
Old 02-12-2019, 08:50 PM   #157
CSG Mike
CSG Mike's Avatar
The (aged) NA motor being used for testing failed while exploring high RPM gains. A new OEM engine is being sourced to continue testing.
Old 02-12-2019, 08:52 PM   #158
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
RIP
Pouring a beer out for our dead hommie.
Old 02-12-2019, 08:59 PM   #159
Code Monkey
Drives: Subaru BRZ
What RPMs are we talking about here? The usual 7,800 or did you guys push it past 8,000?
Code Monkey is offline   Reply With Quote
Old 02-13-2019, 08:07 AM   #160
Tokay444
Anti stance.
Tokay444's Avatar
Runner before after
1. 431 472
2. 433 474
3. 430 471
4. 427 468
Hope this helps
I'm actually quite impressed with the delta between the factory runners. Quite a well made unit, as one would assume something N/A at over 100hp/L would need to be.
Old 02-13-2019, 05:56 PM   #161
Hawk77FT
Drives: GTS 86
Well, I have used the new intake manifold (2017) for this exercise. The guy that did it for me said that it actually flows really well, and has seen these numbers on bigger engine Porsches...so, looks like the intake manifold is pretty well built.
Old 02-13-2019, 06:40 PM   #162
Teseo
Drives: frs
And now the 17' intake manifold will cost more
Old 02-13-2019, 06:51 PM   #163
staycrushing
staycrushing's Avatar
Drives: A Hot Mess
Runner before after
1. 431 472
2. 433 474
3. 430 471
4. 427 468
Hope this helps
what did the honing end up costing you?
ive always tossed up the idea of doing that to the 2017 and sandblasting the outside and having it thermal coated to prevent heat soak.
one of the first people to ruin the frs.
staycrushing is offline   Reply With Quote
Old 02-13-2019, 08:26 PM   #164
Hawk77FT
Drives: GTS 86
They are pretty much the same as the previous plastic one. Mine will cost more for sure.
Old 02-13-2019, 08:28 PM   #165
Hawk77FT
Drives: GTS 86
About 450 AUD and had it ceramic coated as well afterwards. Haven't had a chance to hit the dyno, but compared to my previous set up there is a quantifiable improvement for sure. I should get it done pretty soon!
Old 06-10-2019, 11:53 AM   #166
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
Bump, any updates?
MotoX16 is offline   Reply With Quote
Old 06-10-2019, 07:22 PM   #167
Turdinator
Señor Member
Turdinator's Avatar
Have you had a chance to dyno your car with the manifold?
1974 TA22 Celica
2013 86 GT
Old 06-10-2019, 07:46 PM   #168
Hawk77FT
Drives: GTS 86
Mate, been very busy and completely forgotten about it. Will see if I can book it in sometimes next week!
In for the long haul Ultimate NA build thread. celek Engine, Exhaust, Transmission 669 06-07-2020 06:26 PM
TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL Andrew666 AUSTRALIA 8 11-19-2018 04:24 AM
RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** RallySport Direct Transmission and Driveline 92 09-01-2015 12:17 PM
RallySport Direct's Ultimate Interior Thread! RallySport Direct Interior Parts (Incl. Lighting) 45 03-25-2015 01:12 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
