Old 11-30-2018, 04:04 PM   #155
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
For the older track addicts out there
I've always wanted a "tripod" photo, and shortly after my 65th birthday, it happened
Fish Eagle is offline   Reply With Quote
The Following 6 Users Say Thank You to Fish Eagle For This Useful Post:
Joesurf79 (12-04-2018), korhun (02-21-2020), rice_classic (04-30-2019), strat61caster (12-04-2018), Takumi788 (11-30-2018), treedodger (12-04-2018)
Old 12-04-2018, 01:52 AM   #156
byun
byun's Avatar
Drives: 2015 BRZ CWP
Track Builds Picture Thread
byun is offline   Reply With Quote
The Following 6 Users Say Thank You to byun For This Useful Post:
86_IT (12-04-2018), CSG Mike (12-04-2018), Joesurf79 (12-04-2018), Jonsey (12-04-2018), treedodger (12-04-2018), yberther (05-02-2019)
Old 12-04-2018, 03:34 AM   #157
Enkrow
Enkrow's Avatar
Here's mine from Buttonwillow at the end of October. Needs more drivermod, I'm planning to get a lot more of it in 2019.
Enkrow is offline   Reply With Quote
The Following 4 Users Say Thank You to Enkrow For This Useful Post:
86_IT (12-04-2018), Joesurf79 (12-04-2018), korhun (02-21-2020), treedodger (12-04-2018)
Old 12-04-2018, 11:42 AM   #158
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
When life gives you lemons, weld up a press and get to squeezing!
After breaking a huge chunk off of my second hand, 2 year old, beat to heck velox splitter that had been drilled, hacked, and cobbled to death to keep it "working" it was time for a real front Aero solution. The cardboard held up for a track day by the way - trailing edge isn't under huge load But the thing has always been flexy, bumper mounted wonkiness. It served it's purpose.
THE NEW Splitter frame hung from a replacement crash beam is in progress, as is new, more robust ducting. Cut up and welded a Drift Armor "crash bar" for supporting the frame struts. New splitter will be plywood (they're sacrificial anyways if they're low enough to generate real DF) and mounted to this bad boy...Hopefully all wrapped up by this weekend - I want to test it out!!!
Joesurf79 is offline   Reply With Quote
The Following 10 Users Say Thank You to Joesurf79 For This Useful Post:
86_IT (12-04-2018), chickunfut (01-19-2019), Code Monkey (12-04-2018), CSG Mike (12-04-2018), Jonsey (12-04-2018), korhun (02-21-2020), new2subaru (12-04-2018), Takumi788 (12-04-2018), treedodger (12-04-2018), Tristor (05-01-2019)
Old 04-30-2019, 07:56 PM   #159
Joesurf79
Joesurf79's Avatar
New splitter and support frame work!
New splitter, frame and ducting all finally on track together, and it DOES make a difference!
The Following 5 Users Say Thank You to Joesurf79 For This Useful Post:
86_IT (04-30-2019), korhun (02-21-2020), Reamer (04-30-2019), rice_classic (04-30-2019), Tristor (05-01-2019)
Old 04-30-2019, 11:53 PM   #160
86league
Drives: '13 BRZ Limited
Impressive machine you've built. Look how far it's come :
Mine on the other hand -- looks the same...
Thanks for letting me drive it at MSRC - had a blast.
86league is offline   Reply With Quote
The Following User Says Thank You to 86league For This Useful Post:
korhun (02-21-2020)
Old 05-07-2019, 04:56 PM   #161
Joesurf79
Joesurf79's Avatar
Originally Posted by 86league View Post
Impressive machine you've built... Mine on the other hand -- looks the same...
The view hasn't changed either - I still cant shake you despite all the work I've done
Appreciate you driving it and giving me your impressions!
Old 05-13-2019, 09:41 AM   #162
Joesurf79
Joesurf79's Avatar
Surge tank plumbing all made. Wiring in place. Just need to add a return fitting to the in tank fuel basket, and hard mount the surge tank Fuel starvation is almost a thing of the past (I hope!).
EDIT: Replaced the In Tank pump with a DW65c for ethanol compatibility, hard mounted the radium surge tank to the trunk ledge it is on the in pic, ran the lines through a grommet made from the plug that was in that hole, connected all the lines at each end, fixed the inevitable fuel leaks that popped up.
Flicked the key between off and run a couple dozen times to push all the air out of the surge tank through the return line to the fuel basket...set the fuel pressure regulator to 45 psi...AND THE CAR FIRE RIGHT UP! ran it in the garage as long as I dared (11pm in the burbs, and while not as loud as some cars in the neighborhood - it's not factory quiet ) No leaks or problems. A few more hours of clean up work and the car will be ready for the track this weekend
Hat tip to the Pit Crew!
The Following User Says Thank You to Joesurf79 For This Useful Post:
korhun (02-21-2020)
Old 12-14-2020, 08:37 PM   #163
Lonewolf
Lonewolf's Avatar
Drives: Moped
Bump for some new pics of track builds...many newer members have probably never seen this thread.
The Following 2 Users Say Thank You to Lonewolf For This Useful Post:
Hyper4mance2k (03-29-2022), Kulebrero1 (11-11-2022)
Old 12-15-2020, 09:19 AM   #164
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I'll bite. Can't have enough track build pics and I haven't posted a pic since here since the wrap.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following 2 Users Say Thank You to Takumi788 For This Useful Post:
Lonewolf (12-15-2020), ML (01-03-2021)
Old 01-02-2021, 10:58 AM   #165
jflogerzi
jflogerzi's Avatar
It's still my DD so it will be a while before it goes full race car. NA with flex fuel and some suspension mods with bigger brakes and a JCR dual oil cooler/radiator
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
Lonewolf (01-02-2021), Racecomp Engineering (01-04-2021)
Old 01-03-2021, 03:18 AM   #166
Icecreamtruk
Drives: Track preped NA FRS
New year, new pics, because why not (since the thread seems to have been renewed already anyways)
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
Lonewolf (01-12-2021), ML (01-03-2021)
Old 01-03-2021, 04:13 AM   #167
staples323
staples323's Avatar
Drives: '22 GR86
Little bit of 2 wheelin'
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD
staples323 is offline   Reply With Quote
The Following User Says Thank You to staples323 For This Useful Post:
Old 01-03-2021, 10:23 AM   #168
racingfool
racingfool's Avatar
Drives: Miata
Looks pretty close to airborne.
racingfool is offline   Reply With Quote
Full engine teardown picture thread. Taking requests. (PICTURE HEAVY!) nelsmar Engine, Exhaust, Transmission 53 02-28-2014 06:29 PM
The What Do You Look Like/Picture of Yourself Thread Anthony Off-Topic Lounge [WARNING: NO POLITICS] 39 08-11-2013 04:19 PM
Can someone tell me what this car is(Picture in thread) jflogerzi Other Vehicles & General Automotive Discussions 12 09-23-2012 04:02 PM
D1GP Picture Thread AJUSA.com FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 08-24-2012 01:22 PM
Random Picture thread WheelFast Other Vehicles & General Automotive Discussions 2 01-16-2012 03:28 AM
