go_a_way1
Old 08-22-2013, 11:21 PM   #1541
fenton
Originally Posted by NickFRS View Post
Only time I hit boost is at WOT. I usually drive in -boost. Bypass valve ftw. Only lost 15 miles to a tank.
@fenton is this charger only when you flip it on? After your done with drift office you should bring it down to PIR and see what it traps in the 1/4 mile.
Yes you can completely disable it by not engaging the system but why on earth would you do that
The car drives in negative boost all the time unless you go wot.
That is @Thatruth2001 that is getting the drift office tune. He has talked about going to pir a couple times once he is tuned.
Sent from my HTC One using Tapatalk 4
fenton is offline   Reply With Quote
Old 08-23-2013, 12:01 AM   #1542
NickFRS
Drives: 2013 Asphalt FRS
Is there a map change when you turn off the charger or does it run on the same map? Seems like that could be dangerous being tuned for boost then turning it off and running no boost.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 08-23-2013, 12:40 AM   #1543
fenton
Forget everything you know about boost when thinking about the ESC. The tune doesn't need to compensate for no boost because the supercharger only functions at closed loop full throttle. That means a full throttle you tune for boost, what timing you want, what fuel you want.... And at anything else you basically just have a NA tune.
It sounds complicated but it really isn't.
The car drives like a NA FRS from 0 to 95 percent throttle and once you go to 100 percent you are greeted with 60 to 40 HP more. A smooth surge of power.
Old 08-23-2013, 03:30 AM   #1544
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
So does it activate once the car switches to closed loop, or when you go to WOT (which is only 80%, our cars never go past 80% throttle)? The car will switch to closed loop anytime you increase throttle from a cruise, not just at WOT.
Old 08-23-2013, 05:14 AM   #1545
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
Originally Posted by Gary in NJ View Post
You've confused CFM with RPM. The compressor spins/turns at 40,000 RPM...which produces something like (I don't know the actual number) 750 CFM.
Here is why the eCharger looses impact (not efficiency) as rpm increases. Once again, my example is NOT using actual figures.
At WOT and 3000 rpm the engine is drawing (sucking) 250 cfm, and the ESC is forcing 750 cfm; a net gain of 500 cfm (750-250)
At WOT and 6000 rpm the engine is drawing 600 cfm and the ESC is still producing 750 cfm, a net gain of 150 cfm ((750-600)
no, i ment cfm but as i said my numbers are for example but yes way off.
NYCsubaruBRZ is offline   Reply With Quote
Old 08-23-2013, 10:39 AM   #1546
fenton
Its a physical switch on the floor at WOT.
This has all been answered before....in the first post.
Old 08-23-2013, 10:43 AM   #1547
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
^ I didn't even read, but that was my guess.
Not going to take input from the TPS. Probably could move that switch around / modify it if you wanted it to open up slightly earlier. Wouldn't be surprised if that was mentioned before as well though :-).
PhastekSport is offline   Reply With Quote
Old 08-23-2013, 10:44 AM   #1548
CBR600RR
Drives: Raven Black
@fenton is there no way for the controller to reat the throttle position sensor and turn on the E-Charger that way?
to me the physical switch looks like it may wear out over time, or even break if you hammer the throttle (which I tend to do when shifting hard)
Old 08-23-2013, 10:47 AM   #1549
fenton
I can assure you that nobody shifts harder that me lol. Its a nos switch designed for this.
You could do it on tps but that adds cost.
The Following User Says Thank You to fenton For This Useful Post:
CBR600RR (08-23-2013)
Old 08-23-2013, 10:50 AM   #1550
fenton
Yes it was mine is at about 80 percent which is well past the 100 percent in the ecu
Old 08-23-2013, 11:00 AM   #1551
Wild Weasel
Wild Weasel's Avatar
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
As Fenton mentioned, it's a nitrous switch meant for exactly this sort of use. And heck... you've probably already got switches down there detecting when the clutch or brake is pressed.
To be fair... my original thoughts on this were similar. Slapping a switch on the pedal seems a bit ghetto... but just a couple weeks ago I was replacing a switch on a friend's car because his brake lights stopped working. In the end, it's a perfectly good option and completely normal.
Wild Weasel is offline   Reply With Quote
The Following User Says Thank You to Wild Weasel For This Useful Post:
Old 08-23-2013, 11:07 AM   #1552
PhastekSport
I believe at one point car manufacturers had switches mounted under the gas pedal as well.
ie. My 1992 Lexus SC400...
Oh look. Lexus IS-F as well...
http://www.clublexus.com/forums/is-f...gas-pedal.html
Old 08-23-2013, 11:09 AM   #1553
nonicname
Drives: it has 4 wheels and a motor
someone needs to race this ESC FRS against an innovate SC FRS and see what happens.
nonicname is offline   Reply With Quote
Old 08-23-2013, 12:26 PM   #1554
Wild Weasel
I think installation should be included as part of the race.
Robftss (08-23-2013)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
