Old 03-22-2015, 08:05 PM   #141
eztygr
Drives: Toyota
Originally Posted by Mishimoto View Post
Thanks for chiming in! We are currently working to develop a bracket specific for RHD vehicles. Our prototype is now in the test-fitting process and we should have an update in the coming weeks. Sorry for the inconvenience guys!
Hey John, any news on how the RHD fix is going?
I pinged Cust Support a few weeks back and they advised 'we still have not confirmed fitment with the RHD models'
Thanks
eztygr is offline   Reply With Quote
Old 04-12-2015, 06:22 PM   #142
Hagbard
Hagbard's Avatar
Just got around finally to install mine and my Car has the STI Strut Tower and it does fit but its a very tight fit, I'll try and get some more pics later.
Hagbard is offline   Reply With Quote
Old 04-14-2015, 02:37 PM   #143
Mishimoto
Drives: 2013 Subaru BRZ
Thanks
Sorry for the delayed response! We are still working to confirm fitment with our RHD bracket. We The prototype was fabricated and sent to one of our associates for test fitting. We should have an update on that soon!
Thanks
-John
Thanks for confirming! It does appear to be quite tight but very nice to know the two are compatible together.
Thanks
-John
Mishimoto is offline   Reply With Quote
Old 04-21-2015, 05:59 PM   #144
dj2020
@Mishimoto: Will there be a CCV specific kit released for the FRS/BRZ? I apologize if I didn't see it in this thread. From your testing, I see that the PCV catch definitely caught a significant amount of oil after one month of driving in a NA application, while the CCV can did not catch anything. I have a JRSC, and was wondering if the results would be different on the CCV side of things?
Anyone with real life experience showing that a CCV catch can is necessary for a supercharged application? Is anyone getting their intercooler, plumbing, MAF coated with oil without a CCV catch can?
dj2020 is offline   Reply With Quote
Old 04-24-2015, 02:45 PM   #145
Mishimoto
Great question DJ! We did develop a bracket and lines for the CCV side, however we did not end up moving forward with this portion of the kit. Our testing showed it was not needed on an NA vehicle. You are correct that this could be different with a vehicle featuring a forced induction system.
In order to validate the need for such a kit we would need to conduct testing on a turbo or super charged BRZ/FR-S. If anyone with a CCV can installed has positive results we would be very interested to see what kind of accumulation is generated!
Thanks
-John
Old 04-24-2015, 07:52 PM   #146
yaguphire
Drives: white-out FR-S
Very honest opinion from Mishimoto. Thumbs up
yaguphire is offline   Reply With Quote
Old 04-25-2015, 12:10 AM   #147
dj2020
Thanks
-John
I'll be more than happy to test a CCV catch can on my supercharged BRZ!
@glamcem: I believe in your thread from last year showed that you collected no oil on your CCV catch can. Can you confirm that your CCV can is still dry even with extensive tracking on your Kraftwerks kit?
Old 04-25-2015, 01:57 PM   #148
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I have removed the secondary catch can a while ago since I didn't collect anything
glamcem is offline   Reply With Quote
Old 04-25-2015, 02:09 PM   #149
dj2020
Thanks for the confirmation. Where do you think the blow by is going when on boost? When boosting, the in line check valve on the PCV side prevents blow by from leaving the crankcase and going to the PCV can. Maybe just no blow by at our power levels into the CCV can?
Old 05-08-2015, 01:23 PM   #150
koteman
koteman's Avatar
Drives: Scion frs
I finished my 3 port can set up. It has both pcv and ccv going in to the can. I have the outlet and check valves going to manifold under vacuum and vent to atmosphere under boost. I had about an ounce of oil blow by after 3 weeks of daily driving.
koteman is offline   Reply With Quote
Old 05-08-2015, 05:14 PM   #151
dj2020
Could you take a picture of your set up? I want to see how you're routing the tubing and how you're venting to atmosphere under boost. Is this a Mishimoto 3 port can?
Old 05-08-2015, 05:41 PM   #152
koteman
koteman's Avatar
Drives: Scion frs
Yeah the 3 port mishimoto can and check valves
Size:  457.0 KBName:  uploadfromtaptalk1431121241160.jpg
Size:  507.9 KBName:  uploadfromtaptalk1431121253488.jpg
Old 05-08-2015, 05:51 PM   #153
dj2020
Attachment 109119Attachment 109120Attachment 109121
Thanks for the pictures. I didn't know that plumbing the PCV and CCV into one can was possible. I thought the two systems see different pressures per @Mishimoto and that this type of routing was not possible. Your check valves and vent to atmosphere at boost allows for this?
Old 05-08-2015, 05:52 PM   #154
dj2020
Mishimoto Compact Baffled Oil Catch Can Build Thread! Mishimoto Engine, Exhaust, Transmission 81 08-21-2019 08:05 PM
Mishimoto Build Thread: BRZ/FR-S Silicone Induction Hose Mishimoto Engine, Exhaust, Transmission 23 11-29-2018 11:35 AM
Mishimoto Build Thread: BRZ/FR-S Performance Cold-Air Intake Mishimoto Engine, Exhaust, Transmission 90 12-03-2016 06:22 PM
FS:WA- ADD W1 REd Baffled Universal Aluminum Catch can glamcem Engine, Exhaust, Bolt-Ons 0 07-05-2014 07:15 PM
Win a Mishimoto Oil Catch Can! Mishimoto Announcements, Contests, Giveaways 68 10-23-2013 05:27 PM
