Old 03-30-2014, 12:02 AM   #141
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I installed the rear sti brembo with dba 4000 today.
The front was installed 2 weeks ago.
I did not cut or modify the front dust shields. They just wont contact with rotor. So the front 08 sti caliper and DBA 4000 rotor are just bolt on.
For the rear dash shields, I did cut them.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 03-31-2014, 06:49 AM   #142
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
so , what is the dba's code part number?
Inviato da mio iPhone usando Tapatalk
Trap63 is offline   Reply With Quote
Old 03-31-2014, 08:30 AM   #143
Figo
Figo's Avatar
Dual-drilled 08 Sti Rotor will fit.
Old 03-31-2014, 04:35 PM   #144
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Just make sure they have the -10 at the end to let you know they are dual drilled.
Old 04-13-2014, 11:56 PM   #145
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hi guys, need some advice. I chanced upon a guy selling a set of front Brembo calipers + rotors from a 2005 STI (I understand that the rotors from an 05 won't fit and I'll be getting a new pair of 2004 rotors). But what I'd like to know is:
a) will the calipers fit under my Rota Titan's (17x8 +42)?
b) when refitting new bleeders in place of the allen head bolt (assuming I manage to get it out) do I need to use any thread locker or sealant?
c) seller is including his Stoptech SS brake lines. Can I use them or should I get new SS lines suited to the FRS?
Fizz is offline   Reply With Quote
Old 04-14-2014, 01:37 PM   #146
OrbitalEllipses
Drives: Attitude
a) Check NASIOC - they had a fitment thread for STI that's been closed for a few years, but should have pertinent information.
b) Bleeders do not generally need thread locker or sealant (in my experience anyway) as you need to undo them to bleed the brakes - they're also only torqued to ~13in-lbs.
c) You want lines that are the correct length and orientation for our application. The lines on our car mount to the strut in the opposite orientation from the Impreza - this will cause issues if you use Impreza lines. The length is acceptable, it's just where it mounts to the strut causes a routing/kinking issue.
Old 04-14-2014, 01:39 PM   #147
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
A) A clever trick I saw from someone else was to search for 2004 STI wheel fitment since they're Brembos with 5x100. I searched Wheeldude.com for the Titan's under the 2004 STI and only saw 17x9 +42. I would think that the offset isn't high enough to clear nor the wheel design extreme enough to clear.
B) Someone else can chime in.
C) You'll want ones that fit the Twins. Stock ones should be fine.
Edit:
Frakkin' Orbital over here!
Old 04-14-2014, 03:07 PM   #148
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Official brembos were just released for the 86/brz! Source: japan parts Facebook page! Though they don't have a link to their website yet!
SuperDave is offline   Reply With Quote
Old 04-14-2014, 03:23 PM   #149
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
$4353 for just the fronts.
No.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 04-14-2014, 03:36 PM   #150
SuperDave
SuperDave's Avatar
No.
Around the price range of the trd brakes, I didn't say they were cheap!
Old 04-15-2014, 04:19 AM   #151
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Tried your tip....but no luck. Best I could find was 17x8 +42 in the TC105N wheel, but since mine is the knockoff version (Rota Titan ) I don't know for sure. See here: http://istargazer.ca/sti/weds/sti-weds-tc105n.htm
By the way, where can i get new caliper mounting bolts? Is it ok to just use similar size/length/pitch purchased from hardware store?
Old 04-15-2014, 08:14 AM   #152
Figo
Figo's Avatar
My STI caliper with red powder coat:
Installed pics:
Front
Rear
Old 04-15-2014, 12:09 PM   #153
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks. Could you take a couple of shots showing the back of the caliper where the banjo connects. Which bleeders and stainless lines did you get?
By the way.....just wanted to make sure that 05 calipers are the same as 04 yes? Just the rotors are different....?
Old 04-15-2014, 06:57 PM   #154
brz_star21
Drives: DGM BRZ
a). Sounds like you're definitely going to need to run spacers with that offset. Stocks (17x7 +48) will fit under these calipers with at least a 15-20mm spacer.
b). shouldn't need to.
c). I'd take them anyway just cause. I myself purchased new Stoptech lines, brand new caliper bolts from Oakos Automotive (http://www.oakos.com/Merchant2/merch...ory_Code=12900 or even your local Subaru dealer can order them for you, and I also did a seal rebuild just because I had everything off the car already.
brz_star21 is offline   Reply With Quote
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
