Old 09-18-2023, 08:20 PM   #141
Jmudge
Originally Posted by Kelse92 View Post
The seat rule includes mounting hardware, so by the time you add a slider and side mounts. Or even just side mounts on a fixed base and hardware, most composite seats will exceed the 25lb minimum weight.
This right here. With the mount and hardware, it meets the 25# minimum weight.
Also regarding the battery, no restrictions on batteries have been implemented, although there has been talk about it. Still in the stock location even.
Jmudge is offline   Reply With Quote
Old 09-18-2023, 08:23 PM   #142
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
OK, good deal. I was just curious. The rules can sometimes be a little vague so hearing from someone that has been all the way to the top is very helpful. Thanks.
RongTurnRacing is online now   Reply With Quote
Old 09-18-2023, 08:26 PM   #143
Jmudge
Very welcome. Hope it helps!
Old 09-19-2023, 12:49 PM   #144
Yetti
Drives: FRS
Suspension/driveline
KW V3 with 300 lb front and 400 lb rear springs
Strano 22mm hollow front bar
Whiteline 19mm rear bar currently set to soft.
OSGiken rear diff
Verus RLCA's
Rear subframe bushings
Raceseng camber plates
Engine
Nameless ELH ceramic coated
Nameless everything else with a turndown
TRD Intake
Tune from Revolutions Performance in Colorado Springs like 9 gears ago
Jackson Racing oil cooler
Miscellaneous
AP/Essex Sprint front brake kit
Corbeau FX1 Pro driver seat
2 lb Shorai lithium battery
Random bushings because I was bored
245-40-17 A052 tires
First off I appreciate you posting your setup, not everyone likes to share how they won. As for the setup based on your spring rates and roll bars I am a little surprised your car isn't super loose and undrivable, a 19 mm rear bar is pretty big you must have an interesting alignment and or much different ride height than most.
Yetti is offline   Reply With Quote
Old 09-19-2023, 03:33 PM   #145
Jmudge
My mistake actually. Meant to say it was a 16mm rear bar. Original post is edited.
Old 09-19-2023, 08:03 PM   #146
Yetti
Drives: FRS
That makes more sense.
Old 09-20-2023, 10:10 AM   #147
jcaserta
Drives: 2015 FR-S
I was told to post here with my setup, as I just won Nats in STX and my co-driver coming on 3rd. Few setup changes I want to change this winter, such as ride height. Anyways, first post here we go.
Whiteline 16mm rear bar currently set to soft.
OSGiken rear diff
Verus RLCA's
Engine
TRD Intake
Miscellaneous
Thanks for the share . Mind sharing your alignment? Curious mostly about rear toe. Also ride heights if you know them.
I'll share my updated setup in a second.
jcaserta is offline   Reply With Quote
Old 09-20-2023, 10:17 AM   #148
jcaserta
Drives: 2015 FR-S
I posted earlier in the thread but maybe I can update. I won the prosolo national championship this year and was winning after day 1 of solo nats before Mr Mudge here kicked my ass day 2 and took the win, I ended up 2nd at nats.
-2015 FR-S
-MCS 2 way remote with 6k/9k springs
-Karcepts sway bars front and rear. Large center section for the rear bar.
-Verus rear LCA STX legal version
-OS Giken LSD 1.5 way tuned by Shaftworks
-17x9 +35 RPF1 with 245 A052. Running a 3mm spacer in front
-Skunk2 intake with MAF insert removed
-JDL EL 4-2-1 header
-JDL overpipe
-JDL ultra quiet midpipe
-stock catback
-ECUtek tuned by xero limit
-Whiteline rear subframe bushings, rear diff bushings, and positive shift bushing
-Perrin motor mounts
-Master cylinder brace
-Ferodo DS2500 brake pads, stock calipers, castrol SRF fluid
-Forester oil cooler for track day bro time
-Camber 4.8F/2.6R
-Stock caster
-Toe 0F/0.33 degrees total rear toe in (that's slightly over 1/8" toe in, 0.14" or so)
-Ride height 12.95" F/ 13.2" R hub to fender metal
Still stock seats, stock exhaust, stock brakes. I just got a HKS spec-L delivered to my front door so that's going on for next year . I'll probably get the AP sprint kit over the winter.
Old 09-20-2023, 12:07 PM   #149
TRACE_on
TRACE_on's Avatar
Drives: 2023 GR86 - Track BRed Premium 6M
What kind of shock settings are people liking? I only have single adjustables, but I seem to be faster when running the rear noticeably stiffer than the front.
STR also-ran
TRACE_on is offline   Reply With Quote
Old 09-20-2023, 12:46 PM   #150
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Extremely loaded question, haha.
Totally depends on the rest of the setup but also on how the shocks are valved, what the adjusters do, etc etc.
Old 09-20-2023, 01:25 PM   #151
jcaserta
Drives: 2015 FR-S
As Ken said this question is a can of worms but to try to answer a complicated questions simply, for me on my off the shelf MCS I run about the same setting all around.
Of course the rebound is valved higher in the front so even though I'm equal all around in clicks, in actuality the front is stiffer. Compression I think is actually pretty equal all around though. Sometimes I play with going up one click of comp in the rear and it's nice, a bit less forgiving though.
One of those things where with a lot of runs I'm faster with the extra rear click, but with not many runs I end up making more mistakes. I tried up one click in the rear for nats day 2 and it was part of my struggles.
Old 09-20-2023, 06:33 PM   #152
steverife
Drives: 2016 Scion FRS
Related, I plan to pick up MCS 2WR's over the weekend.
I plan to turn all the knobs, but what is a good starting point for settings?
steverife is offline   Reply With Quote
Old 09-20-2023, 07:14 PM   #153
Jmudge
Sure thing!
Ride heights from the floor to the center of the fender well.
Front: 24"
Rear: 25 5/8"
Alignment
Front Camber: -4.6*
Front Toe: 0.10* out
Rear Camber: -2.5*
Rear Toe: 0.10 Toe in (equates to about 1/16" total in)
Regarding my ride height, I'm pretty confident there is too much rake/the front is too low. Believe I'm giving up too much front compression upon lifting and braking, as I think I'm hitting the bumpstops and it just pushes or brakes like shit.
Old 09-21-2023, 09:09 AM   #154
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
I'm on fresh 2WNR's, and I'm running Karwan's recommendation of +3 bump all around, +6 rebound front, and +7 to 9 rebound rear. Rear rebound changes things a lot. 7 is easy, 9 can be hard to hold onto.
Autocross nut
AustinTX is offline   Reply With Quote
STX setup sharing thread (2022) Autoxer62 Tracking / Autocross / HPDE / Drifting 204 06-15-2023 02:34 PM
STX setup sharing thread (2021) Autoxer62 Tracking / Autocross / HPDE / Drifting 366 12-07-2021 01:57 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 01:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
