Old 04-28-2021, 10:11 PM   #141
3k1n
3k1n's Avatar
Drives: 2017 BRZ limited PP WRC Blue
Originally Posted by PLX92 View Post
Welcome! Another MA local here, as a novice driver just getting your feet wet, focus on improving as a driver. Tire pressures would be where I'd start when you're ready, and that will be tire/course/setup depended really.
Alignment could use a bit more camber up front, and a touch of toe in - in the rear.
I've spent the last 2 seasons on STX prep level really just driving the car and fussing with tire pressures. Even then, I still feel like there's more time to be found in the seat.
You can usually find me out at Devens with various clubs. I haven't actually run with NER scca in the past year or so, but will start to attend now that the weather has broken. Hope to see you out there soon!
What would the toe in the rear do, I assume induce a bit of understeer? Is that generally favorable in autox ? Generally what tire pressures do you run at Devens in dry weather? What about in the wet?
Yea certainly hope to see you sometime this season. For now I've only ran with NER SCCA and proh will continue to do so for the rest of the season as the folks there, specially the instructors have been great.
3k1n is offline   Reply With Quote
Old 04-29-2021, 12:05 AM   #142
strat61caster
strat61caster's Avatar
Rear toe in is stability and predictability, not necessarily under steer.
iirc Strano tries to zero out toe, more 'forward thrust' in theory, lots follow that advice but I've seen no testing that shows minor toe in negatively impacts speed and just adds confidence. If you're happy with rear stability as is leave zero toe, if it feels unstable add the toe in. Hypothesize, test, observe, repeat, but as above with only three events just get seat time.
ineedyourdiddly
Old 04-29-2021, 03:04 PM   #143
ka-t_240
For all of you talking ride heights, how are you accurately/constantly measuring but to fender distances? Seems there is no "good way" to do it with a tape measure as you can't always start in the same place.
I have always used the bottom of the rim to put my tape measure on. its a repeatable spot for the tape measure
ka-t_240 is offline   Reply With Quote
Old 04-29-2021, 03:15 PM   #144
RayRay88
Drives: 2017 86 860 Special Edition
I thought the same thing. I assume something like this might make things easier.
RayRay88 is offline   Reply With Quote
Old 04-29-2021, 10:52 PM   #145
cjd
cjd's Avatar
Drives: 2017 BRZ
I do this. On the scales when everything is level and all. Not perfect but seems consistent over time. I do check that the tape is plumb too since it can look so and add 1/4" so easily.
Old 04-30-2021, 08:23 PM   #146
Autoenthusiastasm
Drives: 2013 BRZ Limited - stock
Just curious how many of you do the pedal dance for autox. The driver who a national caliber driver and only has a mildly prepped STX car(olihns shocks , header, flash tune ) only uses the manual disengagement of nanny’s and nearly got FTD and pax after taking three years off. He had read that the pedal dance affects breaks. Any thoughts. I do the pedal dance and do not notice any issues. I’m only average or mildly above average driver
Autoenthusiastasm is offline   Reply With Quote
Old 04-30-2021, 10:03 PM   #147
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
I usually do it for autocross. I always do it for the track. The issue I've heard about not doing it is that you may end up having ABS engage at a time when you really don't want it.
I'm sure there are those on here that can explain it a lot better.
RongTurnRacing is online now   Reply With Quote
Old 04-30-2021, 10:06 PM   #148
Molez93
Scott M
Molez93's Avatar
Drives: '13 BRZ (DocWalt's old car)
Every time. Only exception is if it won’t take because the oil temp is too low as of my first run. Same thing for track days. I *hate* not being in complete (ok, “nearly” complete) control of the car- mistakes and all.
13 BRZ (DSTprep)
14 Lotus Evora S; 08 Exige S240
06 BMW Z4M Roadster, 20 M850
Molez93 is offline   Reply With Quote
Old 05-02-2021, 02:38 PM   #149
e1_griego
e1_griego's Avatar
Drives: Many
I have never pedal danced.
e1_griego is offline   Reply With Quote
Old 05-02-2021, 08:55 PM   #150
Autoenthusiastasm
Do just use the buttons for autox? Any issues with the nannies kicking in.
Old 05-03-2021, 01:35 AM   #151
e1_griego
e1_griego's Avatar
Drives: Many
Yes, just a long press to turn everything off. Never had an issue at all.
Old 05-03-2021, 07:24 AM   #152
M0nk3y
For the past 4 years of ownership all I've done is long press. I'd say it's worked out okay for me
Kyle H. - #89 STX
Old 05-03-2021, 08:43 AM   #153
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Just a long press for me at autocross.
The only times any of systems have kicked in, the run was ruined anyway or sometimes getting the car stopped after the finish.
Breezio is offline   Reply With Quote
Old 05-03-2021, 09:50 AM   #154
steverife
Long press here.
When I ran SSC in 2018-19, I would pick up the inside rear on some tight off camber turns and that usually lead to some CPU intervention. But it wasn't in a bad way that I felt impacted my times.
steverife is offline   Reply With Quote
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 12:44 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 01:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
