Old 02-07-2015, 01:45 PM   #1513
M23
Drives: 86
Just curious:
Anyone running, or planning to run, 4.56 FD with their JRSC kit?
Seeing how this kit/compressor/turbine makes and maxes out at 245-310rwhp (depending on tuning and running E85 or not), and will honestly never reach 350-400+ rwhp without major expensive changes (swapping in a larger more expensive compressor, fuel support mods, pulley, engine/block/head rebuild, etc.), I believe putting in a 4.56 FD will give it a bit more grunt and quickness…especially if you feel you still want “more” after the JRSC install.
JRSC + 4.56 FD ….your opinion?
I think this is what I would like to do (of course, dependent on this little thing, $6k)
M23 is offline   Reply With Quote
Old 02-07-2015, 08:25 PM   #1514
nelsmar
Originally Posted by M23 View Post
Just curious:
Back when I had my vortech I felt like the gearing was too short. But that's just my two cents.
My flickr - Canibeat
Local magazine scout
Old 02-07-2015, 08:32 PM   #1515
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Just curious:
Honestly, I feel like I run through the gears fast enough already. Don't need them shorter at all.
ScionOfHorus is offline   Reply With Quote
Old 02-07-2015, 08:34 PM   #1516
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Same here. I find myself skipping a gear some times. You get to speed SO quick!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 02-07-2015, 08:36 PM   #1517
ScionOfHorus
Yep. When I was tracking at Texas World Speedway I could run the entire track in 4th with the exception of the straightaway. Then I could get up to 6th.
Though I also know a guy who is seeking his JRSC because he says it make tracking way to easy :P
Old 02-07-2015, 10:42 PM   #1518
Old 02-08-2015, 01:33 PM   #1519
M23
Drives: 86
I guess adding a 4.56 with a SC/JRSC kit is a nay then.
Old 02-08-2015, 01:51 PM   #1520
ScionOfHorus
Barely :P
Would get to 6th for a couple seconds before having to slow down and go back to 4th. The vipers and corvettes were hitting 180 if they came into the straight properly. That was terrifying to be passed by :eek:
Old 02-08-2015, 03:17 PM   #1521
Poodles
I know that track, one of the TX2K meets had their track day there. The speeds some of those guys were hitting on that straight were downright scary...
Old 02-08-2015, 04:17 PM   #1522
ScionOfHorus
Yeah, a viper passed me doing 180+. Scared the fuck out of me.
Old 02-08-2015, 05:51 PM   #1523
I've been at Laguna Seca, and cresting on the front straight, I didn't see anyone coming out of T11. Braking for T2 (andretti), I have two Viper ACRs on each side of me, DIVEBOMBING me into T2. Needless to say, they broke later than I did, passed on either side of me, and just took off. By the time I was at T5, they were already past T6.
Old 02-09-2015, 01:02 AM   #1524
The Slow One
Track Junkie
Drives: Argento Scion FR-S
I highly doubt you hit 6th gear, you were going on the slower direction which you could barely tap 5th gear. Us guys that are in the more advanced/solo groups barely tap the top of 5th/changing to 6th gear going Clockwise which has the better direction of picking up speed for the front straight much easier. Going CCW, you should only be in 5th gear, not even topping out the gear yet because of how Turn 13/14/15 works.
The Slow One is offline   Reply With Quote
Old 02-09-2015, 02:19 AM   #1525
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Are you saying that Vipers are faster than S2000s? That's unpossible.
Old 02-09-2015, 08:03 AM   #1526
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
There's only a slight displacement difference. Only slight....
2016 Camaro SS is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
