#1513 |
NASA SpecE30 Racer
So what was the cause for the recommendation to go back to OEM injectors? Is there possibly something still wrong with his motor?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#1514 |
Drives: Blue Subarus
He told me he hadn't been able to get the larger injectors to start perfectly (but wasn't bad), so it wouldn't ever be as smooth as stock for starting/idling (until it switches to DI). And he said it wouldn't be a problem making that power on the stock injectors, given what they've seen in the past on the stock motor.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
#1515 |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Having not been at the final tuning session my best guess is that the lower compression brought the power numbers down. As far as fueling, I do not know as I have no data.
On the health of the motor, that too I can not say for certain as all we did was replace the gaskets and reset lash. We did not break open the block or send the head out for machining. On the starting/idle issues, Bill has now worked that out. It was an issue that arrose recently as EcuTeK changed the way the VE tables work within the tunes. After the software change Bill had to go back and make many changes to his SD tunes (that already had several hundred hours of development time invested in them). |
#1516 | |
#1517 |
DADA
Drives: 2013
And it begins |
#1518 |
NASA SpecE30 Racer
- King Tut
#1519 | |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
#1520 |
DADA
Drives: 2013
#1521 | |
PhoneFlash by EcuTeK
Thank you for stating this. From the multiple conversations we had this was your number one priority above all else (drivable and smooth), so that was my suggestion for going back to stock injectors, as this would make it start and drive like a normal vehicle even on 15 PSI of boost. You also stated you only wanted to run waste-gate pressure which is what we set your vehicle too. So the power we able to get out of it was what we achieved on pure California 91 octane. Now as far as power, I think people are missing that this vehicles has an extremely low compression engine, 9:1 versus stock. This is going to have a LARGE impact on the overall power output. To give you an example we tuned a MA Performance turbo kit with a similar turbo, stock compression, stock injectors, California 91 octane and made 270 on a Mustang dyno. I believe if we had standard compression and ran 15 PSI on this setup we would be around 300+ on a Mustang dyno. Compression has a big impact on power. As for stock injectors, we have implemented a technique with EcuTeK RaceROM that allows us to run basically 100% DI and 100% PI, in turn this allows us push the power further on stock injectors. We have found the limit to be about 15 PSI on pump fuel and 11 PSI on E85. Though I was calculating more that seems to be it. Just looking for ways to keep the price down on builds for customers. Cheers, William Knose Delicious Tuning. |
#1522 |
Again Bill I'm on the same low compression engine with the same crap fuel but I made 425whp so what gives?
The Frozen North
#1523 | |
I Love custom Turbo kits
Drives: Limited BRZ
He was on WG spring pressure.
#1524 |
Which was 15psi. I made 425 at 16psi....... So I'll say again wtf, I'm not being a d1ck I just want to know where the HP difference is coming from.
The Frozen North
#1525 | |
We discussed what power my car made on the old smaller turbo setup - 353whp on a dynojet with stock OP and FP. Then we decided that at 15psi with a larger turbo, and replacing the OP+FP, we'd easily be able to hit 400whp. I never imagined the car would make less power at the same boost level
#1526 | |
Sincerely, Zach Delicious Tuning |
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
