Old 05-05-2014, 01:45 PM   #1513
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Infamous Performance View Post
King Tut, Bill does not run port to the "ragged edge". He does not normally go above 94% IDC.
So what was the cause for the recommendation to go back to OEM injectors? Is there possibly something still wrong with his motor?
Old 05-05-2014, 01:54 PM   #1514
pmccut
Drives: Blue Subarus
He told me he hadn't been able to get the larger injectors to start perfectly (but wasn't bad), so it wouldn't ever be as smooth as stock for starting/idling (until it switches to DI). And he said it wouldn't be a problem making that power on the stock injectors, given what they've seen in the past on the stock motor.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 05-05-2014, 03:50 PM   #1515
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Having not been at the final tuning session my best guess is that the lower compression brought the power numbers down. As far as fueling, I do not know as I have no data.
On the health of the motor, that too I can not say for certain as all we did was replace the gaskets and reset lash. We did not break open the block or send the head out for machining.
On the starting/idle issues, Bill has now worked that out. It was an issue that arrose recently as EcuTeK changed the way the VE tables work within the tunes. After the software change Bill had to go back and make many changes to his SD tunes (that already had several hundred hours of development time invested in them).
Infamous Performance is offline   Reply With Quote
Old 05-05-2014, 04:00 PM   #1516
pmccut
Ah, that's good to know. I definitely love the drivability of his tune. This is honestly the first tune I've had for the car that I'd want to DD. There's very few spots where it's not smooth.
Old 05-05-2014, 05:03 PM   #1517
mashal
DADA
mashal's Avatar
Drives: 2013
And it begins
mashal is offline   Reply With Quote
Old 05-05-2014, 05:47 PM   #1518
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Old 05-05-2014, 05:55 PM   #1519
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Originally Posted by mashal View Post
Attachment 77496
And it begins
I wish i could make it there in time to help!
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 05-05-2014, 06:09 PM   #1520
mashal
DADA
mashal's Avatar
Drives: 2013
No problem ! I'm sure I'll need your help eventually haha , I'm gonna message you on fb
Old 05-05-2014, 09:43 PM   #1521
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hi,
Thank you for stating this. From the multiple conversations we had this was your number one priority above all else (drivable and smooth), so that was my suggestion for going back to stock injectors, as this would make it start and drive like a normal vehicle even on 15 PSI of boost.
You also stated you only wanted to run waste-gate pressure which is what we set your vehicle too. So the power we able to get out of it was what we achieved on pure California 91 octane.
Now as far as power, I think people are missing that this vehicles has an extremely low compression engine, 9:1 versus stock. This is going to have a LARGE impact on the overall power output. To give you an example we tuned a MA Performance turbo kit with a similar turbo, stock compression, stock injectors, California 91 octane and made 270 on a Mustang dyno. I believe if we had standard compression and ran 15 PSI on this setup we would be around 300+ on a Mustang dyno. Compression has a big impact on power.
As for stock injectors, we have implemented a technique with EcuTeK RaceROM that allows us to run basically 100% DI and 100% PI, in turn this allows us push the power further on stock injectors. We have found the limit to be about 15 PSI on pump fuel and 11 PSI on E85. Though I was calculating more that seems to be it. Just looking for ways to keep the price down on builds for customers.
Cheers,
William Knose
Delicious Tuning.
Old 05-05-2014, 09:50 PM   #1522
Dipstik-sportech
Dipstik-sportech's Avatar
Again Bill I'm on the same low compression engine with the same crap fuel but I made 425whp so what gives?
The Frozen North
Old 05-05-2014, 09:54 PM   #1523
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Dipstik-sportech View Post
Again though Bill I'm on the same low compression engine with the same crap fuel but I made 425whp so what gives?
The Frozen North
He was on WG spring pressure.
Old 05-05-2014, 09:57 PM   #1524
Dipstik-sportech
Which was 15psi. I made 425 at 16psi....... So I'll say again wtf, I'm not being a d1ck I just want to know where the HP difference is coming from.
The Frozen North
Old 05-05-2014, 11:21 PM   #1525
pmccut
Originally Posted by DeliciousTuning View Post
Hi,
Cheers,
William Knose
Delicious Tuning.
Drivability was definitely #1 for me, and I appreciate your focus on that.
We discussed what power my car made on the old smaller turbo setup - 353whp on a dynojet with stock OP and FP. Then we decided that at 15psi with a larger turbo, and replacing the OP+FP, we'd easily be able to hit 400whp. I never imagined the car would make less power at the same boost level
Old 05-06-2014, 12:38 AM   #1526
DeliciousTuning
The Frozen North
A small bit to mention here and forgive me if I am wrong...but Canadian gas is in no way comparable to California gas, even at the same octane level. What is it up there, 91 or 93? Our 91 here in CA does not perform the same as a 91 in any other state. It's much worse here. Food for thought.
Sincerely,
Zach
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
