#127 | |
Drives: WORKS CARB Legal Turbo BRZ
PM sent. Visit our commercial thread for pricing, purchasing and the like. A base tune file is included, but you may also tune with OFT.
#128 |
Minus the catback/header-back, you are correct. The base ECU calibration was created on an entirely stock vehicle with exception of our WORKS high-flow drop-in air filter installed.
| The Following User Says Thank You to WORKS For This Useful Post: | tyrantcf (06-23-2015) |
#129 | |
Drives: '16 WRX, CBR1000RR
This is at the top of my list. One more question that I haven't seen: Does the kit include a MAP sensor? Either way, what pressure MAP sensor is the base tune assuming? 3 bar? Stock?
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
#130 |
Runs off the MAF not MAP.
| The Following User Says Thank You to raven1231 For This Useful Post: | tyrantcf (06-23-2015) |
#131 |
| The Following User Says Thank You to tyrantcf For This Useful Post: | raven1231 (06-23-2015) |
#132 | |
The base tune is intentionally conservative due to the need for a degree of safety when creating a tune that will be used in many different cars in many different environments. We recommend custom dyno tuning from a competent tuner if you want to get the very most out of your setup, but it is, of course, not a necessary procedure. Cheers.
#133 |
#134 |
Drives: FR-S 10 Series MT, Honda 919
I've been very interested but missing or misunderstanding numbers. What can one expect with just this kit and a high-flow air filter running on the base tune?
-The dyno from ghost is at 7.5psi, with aftermarket exhaust -The description says up to 92hp gain, but the dyno on page 4 looks around 75whp gained. (225-150) Dyno also includes aftermarket exhaust... Not bashing anything; it looks great. It's just a huge investment, not to mention for anyone being an early adopter. |
#135 | |
Works also quoted crank hp numbers in their 92hp gained statement, not whp.
| The Following User Says Thank You to tyrantcf For This Useful Post: | WORKS (06-24-2015) |
#136 | ||
The dyno graphs display readings at the wheels. The quoted gains are, as it states, at the crank. Lastly, as he explained, the dyno graphs we published will be very close to what you can expect from just a high-flow drop-in air filter and Stage 2. Cheers.
#137 |
Our intercooler radiator blends in nicely behind the grill.
| The Following User Says Thank You to WORKS For This Useful Post: | tyrantcf (06-25-2015) |
#138 | ||
![]() It's official! The WORKS Stage 1 and Stage 2 Turbo Kits are the first FR-S/BRZ turbo kits to be granted a CARB Executive Order! Under CARB Executive Order D-748, the installation of our WORKS Stage 1 and Stage 2 Turbo Kits are exempt from the prohibitions of Section 27156 of the Vehicle Code for 2013 through 2016 model year Subaru BRZ and Scion FR-S vehicles. What does that mean? 50 state smog legal versions of our Stage 1 and Stage 2 Turbo Kits will soon be available! Stay tuned for more details and pre-ordering. Cheers, WORKS Motorsports
| The Following 22 Users Say Thank You to WORKS For This Useful Post: | AyJay (07-23-2015), Bach415 (06-27-2015), BigFatFlip (06-27-2015), clayrush (06-26-2015), DeliciousTuning (06-28-2015), DriftinFRS (06-28-2015), GhostOp86 (06-26-2015), hmong337 (06-28-2015), JonAvalon (06-26-2015), Kaotic Lazagna (06-27-2015), khantran04 (03-01-2016), Lonewolf (06-29-2015), LucidMomentum (06-29-2015), protpibe (06-27-2015), raven1231 (06-27-2015), surfuxalot (06-27-2015), Trefoil (06-29-2015), turtlefeeder (07-19-2016), Tylub (08-02-2015), tyrantcf (06-26-2015), Xero-Limit (06-27-2015), zoth (06-28-2015) |
#139 | |
Drives: 2013 BRZ, SSM, Limited, M/T
![]() Can't wait to see a couple of these kits out in the wild! I'm running buttonwillow race track this weekend and it's 110 F outside right now... how do you think the turbo kit will hold up in this kind of heat during HPDE's? (And yes, I already have an oil cooler. lol) |
| The Following User Says Thank You to stoked_on_spool For This Useful Post: | WORKS (06-29-2015) |
#140 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Congratulations!
| The Following User Says Thank You to clayrush For This Useful Post: | WORKS (06-29-2015) |
| P&L Motorsports Stage 1 Turbo Kit Build Thread | P&L Motorsports | Forced Induction | 31 | 10-25-2017 05:26 AM |
| WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal | WORKS | Forced Induction | 230 | 08-11-2016 07:01 PM |
| Stage 2 Cosworth Kit Preview!!!! | Titanmotorsports | Forced Induction | 377 | 04-01-2015 08:29 AM |
| WORKS Stage 1 Turbo Kit Pre-Release Offer - Over $800 Discount! | WORKS | Forced Induction | 107 | 11-22-2014 01:15 AM |
| WORKS Stage 1 Turbo Kit Pre-Release Offer | WORKS | Northern California | 31 | 11-11-2014 08:24 PM |
