Old 02-27-2014, 01:41 PM   #127
nelsmar
Originally Posted by s2d4 View Post
Yeah, lets hope he puts the right one on.
I will be installing the 3.48" Pulley my self for him before shipment. Looks like my 3.33" is still on it. I'll be labeling the other pulley and he knows that it may or may not be usable with OFT and I have told him to talk to shiv directly on the matter.
There is no iffy stuff going on here... I Just threw him in an extra pulley thats just a hair higher boost in the case that OFT is able to support it without pushing limitations of the MAF sensor. It really depends on your specific setup. On a stock exhaust car with a stock header I would imagine the 3.33 be just fine, especially at higher elevation.
My flickr - Canibeat
Local magazine scout
Old 02-27-2014, 01:58 PM   #128
s2d4
s2d4's Avatar
I wasn't suggesting that. Just hoping he knows what he is doing, he was running 87 at one stage iirc.
Old 02-27-2014, 02:14 PM   #129
krulux
Drives: 2013 Scion FRS
So glad I decided to not go the ECUTek route...
krulux is offline   Reply With Quote
The Following User Says Thank You to krulux For This Useful Post:
Shiv@Openflash (02-27-2014)
Old 02-27-2014, 02:37 PM   #130
nelsmar
He knows whats up now, he has come a long way A lot of people have done stuff like that, and unless you know fully whats going on in the car its hard to tell what is and isn't safe. And honestly with the vortech kit... I would say its one of the safest routes to go. The MAF is designed to not require speed density and is far enough away from the compressor things such as dirty air filters, modified intakes, etc won't affect the MAF much if at all after it goes through the intercooler. Its far enough away from the throttle to avoid turbulence and a canned tune can probably work just fine for the majority of people.
Old 02-27-2014, 04:19 PM   #131
Sniper2606
Sniper2606's Avatar
Ecutek is not bad.
Visconti is the problem.
Sniper2606 is offline   Reply With Quote
Old 02-27-2014, 08:03 PM   #132
krulux
Originally Posted by Sniper2606 View Post
Ecutek is not bad.
ECUTek as a platform is a tool like any from the toolbox. Nothing wrong with the tool itself... and I understand why some shops would want to use it ...but, in my opinion, it is over priced and needlessly cumbersome for the end-user.
When I was researching which tuning device/platform I wanted to spend my money on - ECUTek was certainly a solution I reviewed. I also looked at the Uni-Chip solution. I ended up going with the OFT product. For my purposes it was easily the best solution for me.
The OFT team has delivered a solid product. One that is EASY to use and is VERY economical. So when I say I'm glad I did not take the ECUTek route - that's just me patting myself on the back for going with the OFT/Vishnu product instead.
I'm happy with the choices I've made on the performance mods to my car thus far. Of the folks that have stopped and ask me about my car, and it happened quiet frequently with that sweet ass rumble, and they ask who "tuned" it - I proudly tell them.. oh just some guys out of California calls themselves Vishnu...
As it stands now, there are no vendor decals or stickers on my car - if I ever decide to decorate my ride - the VISHNU decal will be the first one to grace it!
The Following 2 Users Say Thank You to krulux For This Useful Post:
Shiv@Openflash (02-27-2014), Sniper2606 (02-27-2014)
Old 02-27-2014, 08:05 PM   #133
Sniper2606
Sniper2606's Avatar
Agreed, this is why i left ECUtek for OFT.
Well mainly because of Visconti.
So props to Vishnu great service and people skills.
The Following 3 Users Say Thank You to Sniper2606 For This Useful Post:
Garrett@Openflash (03-24-2014), krulux (02-27-2014), Shiv@Openflash (02-27-2014)
Old 02-28-2014, 02:34 AM   #134
briantran123
Drives: fire storm frs 6mt
@shiv@vishnu ill be purchasing a vortech kit soon. my only issue is tuning, ive done some research on your OFT and love the results. due to my location (high elevation,denver colorado, 5280ft+), tuning is somewhat an issue. i was wondering if anyone else is in high elevation like me.
briantran123 is offline   Reply With Quote
Old 02-28-2014, 11:10 AM   #135
Malt
Drives: 2015 WRX
@shiv@vishnu Are these numbers with the 2.5" Perrin CBE or the 3"? How much of a gain would you anticipate using perrins full 3" (including the 3" catted front pipe) with your Vortec tune? Would using the 3" need a revised tune or will the off the shelf map work? Thanks
Malt is offline   Reply With Quote
Old 02-28-2014, 02:24 PM   #136
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
@shiv@vishnu
When should we expect the vortech maps? I am installing the vortech kit this coming Friday and I really don't want a 30,000 plus paperweight.
cjsporl1996 is offline   Reply With Quote
Old 02-28-2014, 06:09 PM   #137
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I don't expect any unique tuning requirements at your altitude. The tune is MAF based so it will be corrected for your lower airflow rates. You could always opt for e-tuning if you want to optimize the map your your conditions. Given your altitude, we could probably make the map a bit more aggressive since you will be running less effective boost than us sea level folks.
Old 02-28-2014, 06:10 PM   #138
Shiv@Openflash
Drives: 2013 FRS
These numbers are with the 2.5" Perrin CBE. I don't expect much (if any) power gains going to the 3.0" version. It will be louder though. FWIW, we are running the 2.5" CBE without the optional resonator and I LOVE the sound. Personally, I wouldn't put a resonator in if given the choice.
Old 02-28-2014, 06:11 PM   #139
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by cjsporl1996 View Post
@shiv@vishnu
Just email your original file to me (shiv@vishnutuning.com) and I can send you a .dev file. Keep in mind that it is intended for use with the OFH as well. Not intended for stock headers.
Old 02-28-2014, 06:26 PM   #140
nelsmar
Are the vortech roms going to stay in .dev format or will there be .bin versions?
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
