#127 | |
Drives: Toyota 86
There is an interpolating factor at FFF89C88 (A01G) which is used to interpolate between AVCS Intake Base table and the return from AVCS Intake Safe/Normal table (Safe/Normal switch is determined by IAM with hysteresis). Exhaust code is virtually identical. Have not logged FFF89C88 to see when it is active, but presumably not very much. |
#128 |
I would also like to know how many cells it averages. Is it a 3 cell spread across rows, and a 5 cell spread down columns? I know there is a spread for smoothing. I would just like to know how wide it is to know how long a change will last across RPM's or Load. Also, which is the more advanced table, and which is the less advanced table, Safe or Normal, as determined by the IAM.
If I say yes, will that make you think I understand?
#129 | |
Drives: UK GT86
@ztan that's how I was told and that's why base and the safe maps are set the same (or all 3 in my case).
Safe = IAM high Normal = IAM Low I have defined boundary of IAM = 0.4 for the normal/safe determination.
.: Stealth 86 :.
#130 | |
Drives: 2013 FRS
I'm not sure when the base map would take over so far now make all the maps the same so I know for sure what I like or don't like... Hopefully it warms up again so I can do some tweaks.... Below 20 last couple of days.... Hates the |
#131 | |
Drives: Toyota 86
#132 | |
Would you mind...
#133 | |
Drives: UK GT86
I can't post them for 2 reasons: 1) They're not my cam maps 2) If I use the ECUtek custom maps, it renders these irrelevant.
.: Stealth 86 :.
#134 |
Drives: Toyota 86
Greddy T518Z turbo. Base maps similar, Safe and Normal identical.
#135 |
Thank you @ztan. Once again, the beauty of using Open Source software is the ability to show what you know without being sued for it.
#136 | |
Drives: Toyota 86
Credit @Shiv@Openflash where credit is due. The AVCS map I use is based on his OFT350 work, running less overlap in a few areas where I was still getting quite a bit of knock. Not sure if this was due to running a turbo that spools just that bit quicker, local environment and fuel, or just the way I drive (on the road, not on the dyno). |
#137 |
These maps feel a bit tame under 3000 rpms. I like what @shr133 did at the low rpms, so I'm going to do some blending and I'll post what I find works for me.
#138 |
Drives: 2013 FRS
#139 |
Drives: 2013 FRS
I tweaked my maps a little, I'm bring in the cam timing faster moving my map 1 step to the left and going to a max of 35 degrees of intake...
The biggest thing is I went to 5 degrees less exhaust timing with a max of 25 degrees... Feels less "torquey" but revs much better and seams to run cleaner... Have to drive it a little more but spun the tires good going to second for the first time so it must be running better... I think I'm really close on the maps, now I'm working on the optimum split... |
#140 | |
| Timing chain issue? | Hardpack | Issues | Warranty | Recalls / TSB | 14 | 01-10-2016 11:25 PM |
| AVCS failures? | hmong337 | Forced Induction | 26 | 02-12-2015 03:01 PM |
| Stock Rom: Timing + Learn Value | sw20kosh | Software Tuning | 7 | 12-11-2013 07:09 PM |
| E85, Boost and Ignition Timing | jamesm | Software Tuning | 23 | 12-11-2013 02:19 PM |
| Timing belt shredded..?! | drei | CANADA | 5 | 12-06-2013 05:54 PM |
