Old 12-20-2013, 12:51 PM   #127
humfrz
Is there any problem using cable chains with the FR-S ...??
(besides being a PIA to put on .... )
humfrz
Old 12-20-2013, 02:37 PM   #128
FRiSson
Drives: FR-S MT
The FR-S is one of the best winter cars I have had. I say this with a caveat. Obviously because of the low clearance, you can't drive on deep snow.
The reason it is so good is the way that it telegraphs your grip and how predictably it responds. With front wheel drive, you never quite know whether it is an adhesion problem or an acceleration problem. With the drive wheels in the back, the front tires telegraph the adhesion, and the rear wheels allow you to respond with the throttle. No torque steer induced weirdness, no over-light rear end. And, since the car essentially pivots around its center (or pretty near to it) it doesn't tend to swing out from the ends. Overall an excellent winter car, if you don't take it into deep snow.
FRiSson is offline   Reply With Quote
The Following 2 Users Say Thank You to FRiSson For This Useful Post:
amram (12-20-2013), Snowball (12-21-2013)
Old 12-20-2013, 10:59 PM   #129
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Had the FRS out in 1 inch of snow this morning and I aint'nt ded yet.
The all seasons worked well for what they are.
Took the long way around though and not over the hills.
Couple of slips that were easily corrected by letting off the throttle.
ZionsWrath (12-20-2013)
Old 12-20-2013, 11:35 PM   #130
amram
amram's Avatar
Drives: 2013 FR-S AT
Interesting observation. After my very harrowing experience in the snow with the Bridgestone all seasons on tue evening, on wed before it all melted I experimented in an empty parking lot and some empty streets, unsettling the car and trying to catch it when it slid to get a feel for the dynamics of the car in the snow and in my limited time playing I found it very communicative and like you said it seems to pivot around its center. Very balanced. And by god what fun it was, almost sad to be soon switching out to winter tires, though I don't want to relive the harrowing part again either so it's for the best of course.
"That's why I like the GT86 so much..... It's a car designed for one thing only: fun." - Jeremy Clarkson
amram is offline   Reply With Quote
Old 12-21-2013, 12:04 PM   #131
Jertronic
Jertronic's Avatar
Drives: FR-S 10 Series 120 of 2500
I've put 250 miles on my new set of Michelin X-Ice 3's 16's. I will give feedback later after the tires have worn in properly, but the initial impression is great in the snow, but squirmy on the highway. Squirmy as in it's hard to keep a straight line on center at highway speed.
Jertronic is offline   Reply With Quote
Old 12-21-2013, 12:06 PM   #132
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
I have to share my experience with winter driving so far:
The car loves to slide on tarmac, on snow it's just a hoot. I'm using Nokian Hakkapeliitta 7 winter tires, one of the best set of winter tires on the market and I still slide my ass around every corner.
The car is light and RWD, creating a lack of traction at the back very easily. I almost slid into someone entering a parking lot last week because I couldn't get any traction from the backend.
If you drive in real heavy snow like we have here in Quebec, I recommend getting some weight in the trunk and to get used to the way your car behaves when sliding and taking off. I'm able to take off from 1st gear without spinning the wheels, some people prefer going from the 2nd gear as the power delivery is longer, hence less chances of losing traction.
This car is a lot of fun, but remember that it is light and that it has a tendency to slide in the dry, so snow only amplifies that. It's safe to drive, just a bit more prone to oversteer. Managed to get almost sideways on a straight by hitting a bump under the snow when driving. You have to concentrate on your "butt feeling" of the car's behaviour.
And remember that snow slides, a lot. Drive slower and don't take ramps and corners as fast as you would in the dry. You might be the next one on the news.
Anyway, that was my 2 cents on my real winter driving so far. None of that 1 inch of snow that you guys get down south haha
Mad1723 is offline   Reply With Quote
Old 12-21-2013, 12:11 PM   #133
Suberman
Drives: Subaru BRZ Sport Tech Satin White
"A bit more prone to oversteer" wins my understatement of the year award.
I agree with the assessment of this car on snow or ice.
I'm trying out 90 lbs (40kg) of sandbags today on fresh snow. In the trunk, I have a compact shovel (designed in Quebec naturally) in case things don't work out so well.
If I survive I'll post my impressions.
I'm on four Sottozeros and, for severe winter conditions, I recommend studless winter tires like those top of the line Hakkas. Performance winters aren't quite enough for severe winter on this car.
Suberman is offline   Reply With Quote
Old 12-21-2013, 12:39 PM   #134
FRiSson
Drives: FR-S MT
This is my second year on X-Ice3's. They are much better after the first couple of thousand miles. They are terrific in snow and slush and the highway squirmyness has pretty much gone away. They still don't track nearly as well as the summer tires however, so you have to constantly adjust. But they don't feel loose at all. I am even happier than before with their performance at low to mid speed. In fact, they are kind of fun, since they can be induced to slip easily with the throttle.
The Following User Says Thank You to FRiSson For This Useful Post:
Jertronic (12-21-2013)
Old 12-21-2013, 01:06 PM   #135
thill
Loving my Blizzak WS-70's. We have had 12 snow events in December alone and I have had zero issues getting around, even before the plows have had a chance to clear side roads and some major roads. Traction is great with these tires and very easy to recover if the rear end starts to slide out.
Old 12-21-2013, 02:43 PM   #136
Suberman
Weight in the trunk doesn't work.
The only discernible effect was, as I expected, a slight increase in polar moment towards the rear axle (I placed the sand at the back of the trunk (against the seatback) to minimize this. That way the weight is over the axle and not lifting the front axle at all.
The car was slightly trickier to reign in when stepping out.
The effect on forward traction was precisely zero.
This is unsurprising since the factory weight distribution with driver has to be close to 50/50 (unladen is 53/47 f/r, but you can't drive an empty car.)
The "problem" is the Torsen diff is too tight. The snow tires I have on are fine as the braking and steering is normal (Sottozeros in 225/45x17 size). Also, the stability of the car once it starts to slide is exemplary. Catching the rear axle is child's play if you are experienced at winter driving. Judging how much throttle to use to sustain or end the slide is very easy. The electric power steering is superb. You can twirl the wheel as rapidly, slowly and precisely as you need to.
The only real trouble with this car on snow is lack of straight line grip. That just had to be the Torsen. Nothing else could affect only the straight line grip.
Just by the by anyone with an automatic and TC fully off tried winter mode? Do you get good traction then because that starts the car off in second gear, softens the shift speed and I think slows down the throttle response.
Old 12-21-2013, 03:45 PM   #137
Jertronic
Jertronic's Avatar
This is good to know. I figured this might be the case. If the new alpin A4's came in my size I would have got those. Looking forward to wearing the X ice's down a little.
Old 12-21-2013, 04:48 PM   #138
theurbaninja
Drives: FR-S 6MT Ultramarine
I've got Hakkapeliittas' as well and couldn't have said it better myself. Careful fun is probably a good way to describe it.
theurbaninja is offline   Reply With Quote
Old 12-21-2013, 09:40 PM   #139
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
No need to be sad, this car will still slide on request (and often when you don't) even with winter tyres. It is much more fun than with summers as you can expect it to be easily catchable as opposed to the standard summers when it is just unmanageable.
It is by far the most fun winter car i've ever had (at halfway sane speeds at least) and that includes my STi.
jonboy99 is offline   Reply With Quote
Old 12-21-2013, 09:45 PM   #140
jonboy99
jonboy99's Avatar
I've got the same tyres and have had just the same experience as you - probably done only a thousand klicks on them though. It bothered me for the first few days, but then you just get used to it - the less grip and stability this car has, the more fun it seems to get! I imagine when the summers go back on it will feel like a formula 1 car (albeit a very slow one).
Horrible 458 crash both driver and track worker survive DIG1992 Other Vehicles & General Automotive Discussions 16 05-16-2013 03:55 PM
Now that Winter is over... mrdanyo CANADA 29 04-11-2013 11:39 PM
Winter is here firehawk Scion FR-S / Toyota 86 GT86 General Forum 33 10-30-2012 04:25 PM
For those considering winter set-ups #87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-19-2012 09:37 PM
For the winter brichard0625 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-30-2012 05:16 PM
