Old 11-05-2013, 11:59 PM   #127
Lonewolf
Lonewolf's Avatar
Drives: Moped
Looking for more impressions on this driveshaft...does anyone else have and updates or impressions of this shaft installed?
I would love to pair this cf driveshaft with a 4.55 final drive, exhaust, and tune and call it a day...
Old 11-06-2013, 02:37 AM   #128
akyp
Drives: 2012 86
If I'm reading this thread correctly, a flexible driveshaft is more desirable than a rigid one? But wouldn't it absorb and thus waste engine power?
akyp is offline   Reply With Quote
Old 11-06-2013, 02:40 AM   #129
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Think of it as a spring....
Old 11-06-2013, 02:44 AM   #130
akyp
Drives: 2012 86
My high school physics tells me there's no perfect spring in the world. All springs absorb some energy...
I guess the question is does this CF DS absorb more or less energy than the stock steel one?
Old 11-06-2013, 02:48 AM   #131
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Xcatly, which is why you can get away with stock axles but a cf shaft on some builds, because when you launch the car the shaft absorbs some of the power
Old 11-29-2013, 03:43 AM   #132
Lonewolf
Lonewolf's Avatar
Drives: Moped
Did PST ever develop a production carbon fiber driveshaft for the automatic?
Old 02-20-2014, 06:37 PM   #133
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I'll give this a bump because I'm curious about it for the auto as well.
Nevermore is offline   Reply With Quote
Old 03-10-2014, 05:51 AM   #134
OICU812
Just a dude
OICU812's Avatar
Originally Posted by RallySport Direct View Post
The torque specs are 54.6 ft/lbs and we did not use loctite on ours, but if you were worried about it, I don't think it would hurt. Just make sure to use a lower strength version incase you need need to remove the bolts at a later time.
Thanks,
Rick
I'd like to know hoe you torqued these bolt/nuts, what attachment?... Last time I messed with shaft I can't see how there's room for anything other then a standard wrench??
Old 03-10-2014, 06:17 PM   #135
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
It would be a pain with anything but an open ended torque wrench unless you got very creative with attachments and very shallow sockets.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
OICU812 (03-11-2014)
Old 03-11-2014, 03:35 AM   #136
Alabang 86
Alabang 86's Avatar
Drives: GT86
I got one about 5000 miles ago. no issues
No noticeable performance difference at low rpms (nothing happens in this car at low rpms) but you will definitely notice how it "spins up" when you are going north of 4k.
You can even chirp 3rd if you're careful enough.
I recommend it.
Also got mine at rallysportdirect
...my turn...
Alabang 86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Alabang 86 For This Useful Post:
OICU812 (03-11-2014), RallySport Direct (04-10-2014), unsurety (06-13-2014)
Old 03-11-2014, 04:34 AM   #137
imom
Drives: BRZ sold
For the cars with notchy tranny issue even with MTL fluid change.... does the 1 piece drive shaft fix this issue? I noticed from time to time the suspension and the 2 pc flexing causing 2nd gear shifting difficulty.
imom is offline   Reply With Quote
Old 03-11-2014, 05:35 AM   #138
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Why do you attribute suspension and a 2 piece drive shaft to difficult gear change?
Old 03-12-2014, 03:50 AM   #139
imom
Drives: BRZ sold
driving and turning on uneven road and shifting gears from 1st to 2nd gear. I'm looking for a solution to this annoying issue. If you have something contribute...would be nice.
Old 03-12-2014, 04:53 AM   #140
Captain Snooze
Drives: Red Herring
I'm sorry I do not but this is the first time I have read of this. Not the difficult 2nd gear change but the suspension and drive shaft being the cause.
PST Carbonfiber Drive Shaft In Stock and Ready To Go!! RallySport Direct Transmission and Driveline 27 11-18-2012 02:39 PM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 05:44 PM
HELP...Drive Shaft/Rear Tire Shutter UM FRS Issues | Warranty | Recalls / TSB 11 09-05-2012 12:14 PM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 02:40 PM
