#127 |
Drives: Moped
Looking for more impressions on this driveshaft...does anyone else have and updates or impressions of this shaft installed?
I would love to pair this cf driveshaft with a 4.55 final drive, exhaust, and tune and call it a day... |
#128 |
Drives: 2012 86
If I'm reading this thread correctly, a flexible driveshaft is more desirable than a rigid one? But wouldn't it absorb and thus waste engine power?
#129 |
Just a dude
Drives: Scion FR-S 2013
Think of it as a spring....
#130 |
Drives: 2012 86
#131 |
Boosted
Drives: Not a supra....yet
Xcatly, which is why you can get away with stock axles but a cf shaft on some builds, because when you launch the car the shaft absorbs some of the power
#132 |
Drives: Moped
Did PST ever develop a production carbon fiber driveshaft for the automatic?
#133 |
Wayward Member
Drives: Hot Lava 86
I'll give this a bump because I'm curious about it for the auto as well.
#134 |
Just a dude
I'd like to know hoe you torqued these bolt/nuts, what attachment?... Last time I messed with shaft I can't see how there's room for anything other then a standard wrench??
#135 | |
Drives: 2014 Widebody Cosworth FR-S
Thanks, Rick |
| The Following User Says Thank You to RallySport Direct For This Useful Post: | OICU812 (03-11-2014) |
#136 |
Drives: GT86
I got one about 5000 miles ago. no issues
![]() No noticeable performance difference at low rpms (nothing happens in this car at low rpms) but you will definitely notice how it "spins up" when you are going north of 4k. You can even chirp 3rd if you're careful enough. I recommend it. Also got mine at rallysportdirect
...my turn...
| The Following 3 Users Say Thank You to Alabang 86 For This Useful Post: |
#137 |
Drives: BRZ sold
For the cars with notchy tranny issue even with MTL fluid change.... does the 1 piece drive shaft fix this issue? I noticed from time to time the suspension and the 2 pc flexing causing 2nd gear shifting difficulty.
#138 |
Because compromise ®
Drives: Red Herring
Why do you attribute suspension and a 2 piece drive shaft to difficult gear change?
#139 |
Drives: BRZ sold
driving and turning on uneven road and shifting gears from 1st to 2nd gear. I'm looking for a solution to this annoying issue. If you have something contribute...would be nice.
#140 |
Drives: Red Herring
I'm sorry I do not but this is the first time I have read of this. Not the difficult 2nd gear change but the suspension and drive shaft being the cause.
| PST Carbonfiber Drive Shaft In Stock and Ready To Go!! | RallySport Direct | Transmission and Driveline | 27 | 11-18-2012 01:39 PM |
| Carbon Fiber Hoods. | Asterisked Accolade | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 09-25-2012 04:44 PM |
| HELP...Drive Shaft/Rear Tire Shutter | UM FRS | Issues | Warranty | Recalls / TSB | 11 | 09-05-2012 11:14 AM |
| Does FRS come with Carbon drive shaft? | STi88 | Engine, Exhaust, Transmission | 30 | 07-30-2012 01:40 PM |
