Old 06-09-2014, 12:59 AM   #127
Boba_kz
Cusco
Boba_kz is offline   Reply With Quote
Old 06-09-2014, 01:17 AM   #128
stevesnj
stevesnj's Avatar
Home Depot, $14.99
Old 06-09-2014, 05:39 PM   #129
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Originally Posted by Boba_kz View Post
Cusco
Why did you mount it there and not in the centre as the manual suggests?
Efferalgan is offline   Reply With Quote
Old 06-09-2014, 10:36 PM   #130
Basket Case
Drives: 2013 Raven fr-s
Originally Posted by stevesnj View Post
Home Depot, $14.99
How well is it working?
Basket Case is offline   Reply With Quote
Old 06-09-2014, 11:28 PM   #131
mike the snake
I had one of these on my BMW 135i, it was very nice and worked well.
Originally Posted by MANDALAY View Post
Sometimes its worth to see what other cars have installed/designed.
This is a great design , absolutely a work of art, all billet and blends in like an OEM part.
Works which is the key and is cheap at $179. One of the highest upgrade parts in the BMW scene
http://www.google.com.au/url?sa=t&rc...DeboWslkVSBpCA
Old 06-10-2014, 12:23 AM   #132
Boba_kz
It is not horizontal mounting oil catch.
Old 06-10-2014, 01:40 AM   #133
protpibe
protpibe's Avatar
Here's my new setup
Dual cans by Saikou Michi with custom vent and PCV hard lines. It's boosted so I have a check valve on the PCV line Name:  ImageUploadedByTapatalk1402375205.724743.jpg
Old 06-10-2014, 05:37 AM   #134
Efferalgan
Yes, I can see it. I have a vertical AOS from Cusco but it's still mounted in the middle, like this:
The Following User Says Thank You to Efferalgan For This Useful Post:
Boba_kz (06-10-2014)
Old 06-10-2014, 06:05 AM   #135
Boba_kz
Yes, but there is your tower strut bar?
And actually I didn't have in main box additional mounting parts to fit it in the middle
пысы. привет на драйв2.ру
The Following User Says Thank You to Boba_kz For This Useful Post:
Efferalgan (06-10-2014)
Old 06-10-2014, 07:23 AM   #136
Efferalgan
Хе-хе! Не посмотрел на location - привет!
OK. Understood. The strut tower bar is much more towards the front, so the AOS fits well behind it actually. But if you did not have mounting parts (you must be got a universal version) - this location makes sense, I like it!
Old 06-10-2014, 10:43 AM   #137
stevesnj
stevesnj's Avatar
I use it in my Land Cruiser and it works great. Only downfall is that it's plastic bowl so gotta keep it from a large heat source. Plus I can see when to empty it. On a new car with tighter valve seals like an FR-S you may have to empty it twice a year.
Old 06-10-2014, 04:08 PM   #138
Crawford Performance
Crawford Performance's Avatar
Drives: 2008 STI
Crawford Air Oil Separator
Yup
It's also designed for the BRZ/FRS
Yes we do make one specifically for the BRZ/FR-S/GT86
We do not call it a catch can as it is a closed loop system, so no messy draining, etc
thanks!
Crawford Performance is offline   Reply With Quote
Old 06-10-2014, 07:35 PM   #139
mike the snake
I'm running the Crawford BRZ/FRS specific catch can/air-oil separator on my car. Nice product, seems to be working fine (no way to really tell as it dumps any oil collected back into the engine).
thanks!
Old 06-11-2014, 09:31 AM   #140
Model Citizen
Lacking brains
Drives: frz
First I made this.
Pvc y pipe, sink strainer baskets at entry and exit along with strainer covers and stainless mesh from a tea maker sphere. Zip tied to a bookend under the battery.
It worked very well for a few months. But on my last autox day Apparently the heat/fuel exposure softened the plastic to the point where it cavitated.
IMG_6674 by utekineir, on Flickr
IMG_6675 by utekineir, on Flickr
So, decided to try something new.
Can of nair $3, Autozone breather filter $5, reused fittings, hoses, bookend, also some electrical tape, zip ties, jb weld and paint and a bit of scotchbrite pad. Also had to buy a couple bolts to plug the return hoses with, since nobody stocks big vacuum caps locally.
IMG_6716 by utekineir, on Flickr
IMG_6719 by utekineir, on Flickr
IMG_6717 by utekineir, on Flickr
IMG_6728 by utekineir, on Flickr
After a few days it seems to be working just fine. The smell is much more apparent than it has been in the past when I had a vta can mounted at the front of the bay on a different car. I'm guessing the battery location is close to a cabin air intake. Basically any time with the fan on at stopped/low speeds it can be smelt. I'll sort out a relocation.
The best bonus of everything. My balls have never been this smooth. The nair worked like a champ.
I won't be adding a drain. I'll either extract with a big syringe and hose or just pull the can and pour out.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
bakerr6 (06-11-2014)
blow by, carbon build up, catch can, crawford catch can, radium catch can, saikou michi
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 04:07 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 11:58 AM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 01:30 PM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 04:16 AM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 04:55 PM
