#127 |
Mr.Fujitsubo
Drives: 2018 STI
Yes, all tunes void your warranty.
However, with the OFT, the first time you plug it in, it will ask you to save your stock ROM onto the device. This will help you go back to your stock tune anytime you will need to do warranty work or if you go to the dealer for oil changes etc.... There is no traces left for the dealer to be able to find out that you tuned your car.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
#128 |
Drives: 2015 FRS Halo (White)
The check engine light + traction control light combo lit up means that there might be a timing actuator problem. I'm also from Vancouver, but sadly people have understood that the best solution to intakes is a dry drop-in air filter. So people most likely keep their stock airbox.
Drop by the FT86Vancouver Facebook page to get more replies locally.
AVO Turbo with FlexFuel| Perrin 2.75" CAI(gone) | Now: Perrin 3" Catback | MXP Comp RS Catback(gone) | Magnaflow Catback(gone) | Gruppe-S UEL Headers (gone) | 18x7.5 TE37 on Firehawk Indy500 225/40/18 | Valenti Tail Lights | Drift-Office Tuned 220whp-350whp
#129 | |
Drives: 2013 frs
I see you have a cold air intake? Haha. What did you do with your old one! My trac control livht goes off aftee 5 minutes. I think it may just be a precaution if cel shows up. Just so u dont disengage trac controls. I threw no timing actuator codes. Threw lean and injector codes
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
#130 | |
I'm keeping my stock intake as I'm switching back to it in the future. I only heard about the trac + check engine from a friend and she said it disappeared after a while. If it didn't disappear, then it's a costly repair if the car is out of warranty.
#131 |
Drives: 2013 frs
Its most definitley dissapeared. And i threw no timing codes. AND its still under warranty. So yay
#132 | |
#133 |
Drives: 2013 frs
Ok so update!! Got stock intake. Installed and unplugged battery overnight. Car ran great for an hour and a half. No stalls no sputters then BAM check
Engine light. My 3 other codes were wiped. The p0172 and p117 0/b. Which is what was causing my idle and stall. Now im getting p0420 which i wasnt before!? Havent touched the header or o2s. Deleted the code. Wonder if it will come back? Any negative side effects of driving with p0420? What are my options in fixing it permanently Other than putting stock header on. Which im not doing. Would a rear o2 spacer help!? I remember a previous member saying something of the sort
#134 | |
You can try 02 spacer in rear 02 sensor but its no guarantee , only guarantee is to disable p0420 in tune. if you have stock intake back on and no intake or exhaust leaks then your fueling problems are likely to be front 02 sensor or the maf sensor. usually it goes rich on exhaust leak as sensor keeps seeing fresh air thinks its lean so signals ecu to richen fueling. If your super confident theirs no leaks then its likey one of those sensors. Unless you have equipmemt to log ecu and test sensors its probably going to be cheaper to take it to a shop that has, the 02 and maf sensors are not cheap and we are just guessing without proper diagnostics. im putting my money on a exhaust leak though, check the front 02 sensor is scred in all the way and the metal ring on it is not loose. if it is dont force it in remove it and run an M18 by 1.5 mm thread tap through the 02 bung in header so it screws in easily. many people stuff the 02 sensors forcing them in |
#135 | |
Drives: 2013 frs
Ill look this weekend if those o2 sensors are loose. Why arent the holes pretapped? Youre saying theres just a cut hole and the o2 threads itself?! All other vehicles where 02 sensor goes theres a threaded hole! Ever heard of shoving a shop vac into exhaust pipe and listening down the line for air shooting out? Could this damage anything? I dont assume itd be powerful enough to do so. Maybe ill just go get a smoke test.
#136 | |
Drives: 2017 BRZ Limited PP
Sent from my HTC6535LVW using Tapatalk |
#137 | |
#138 |
Drives: 2013 frs
Heard nothing but bad about 02 spacers. If i had a 92 civic i wouldnt spend money on a tune as its worth more than the car.
Just decided to not pay my property tax and tuned the car. Everything is running smooth as butter now.
| Upgrade, now ticking. | Fartsicle | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 07-20-2015 10:30 PM |
| ticking sound when taking off???? | 93frs | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 02-09-2015 12:50 AM |
| Tapping/Ticking in 2nd gear | radroach | Issues | Warranty | Recalls / TSB | 5 | 03-02-2014 05:00 PM |
| Ticking sounds from exhaust when off | Kefu | Issues | Warranty | Recalls / TSB | 26 | 12-20-2013 02:11 PM |
| ticking noise? | iHeartmyFR-S | Issues | Warranty | Recalls / TSB | 13 | 04-18-2013 05:42 PM |
