Old 06-12-2013, 10:27 PM   #5335
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Originally Posted by grostoine View Post
No one can help for my cruise controle probleme?
I would suggest starting a separate thread in this forum http://www.ft86club.com/forums/forumdisplay.php?f=72
Your CC issue is most likely not related and coincidental.
You might want to provide a little more detail like if you you have a manual or automatic transmission.
I've had this issue with a couple manuals that I've owned over the years.
As I recall the first time it was the switch on the clutch that failed and another was the switch on the brake pedal. Both replaced under warranty.
CircuitJerk is offline
Old 06-12-2013, 10:31 PM   #5336
grostoine
Drives: Subaru BRZ
Originally Posted by JPxM0Dz View Post
Did you submit a ticket ?
I've put it in the ticket that I already oppened. I've told John 2 times already it didn't worked and he have not answer already...
I don't want to go to the dealer. With all my mods, they will cancel my garantee. I would have to returned fully stock and even there, they could see that i've put a tune in my ECU i'm pretty sure. It was working before I plugged the Ecutek on my car, so John can certainly do something for that. He can certainly make it work again, I hope.
The car is doing a more raspier sound now... Don't know if it's normal. The engine feels slugish for the moment but I know it's pretty normal.
grostoine is offline
Old 06-12-2013, 10:33 PM   #5337
Sensisnow
Drives: 05 TSX & 13 BRZ
As others have suggested, flash back to stock, if it still doesn't work then take it to the dealer. If it works on the factory ROM, but not on your updated tune, submit a ticket to Visconti and wait for a reply. That's all you can do right now.
Sensisnow is offline
The Following User Says Thank You to Sensisnow For This Useful Post:
Rich@ViscontiTuning (06-13-2013)
Old 06-12-2013, 10:45 PM   #5338
grostoine
Drives: Subaru BRZ
If the clutch switch was broken, the car should not start ?
I have a manual transmission, my car have 5000 km (3106 miles), it's a premium.
I've heard that those switch could broke, but were are they? lol
I would like to have the electrical shematics so I cant find it myself. But before to try anythings, I want to be sure that John cannnot do anything for me, wich it would surprised me.
It's stop working right after I plugged the Ecutek to produced the Romdump. So Is it possible that it was ''disable'' there? I've tried getting stock but it didn't change anything, the cruise doesn't worked.
Like I said I will wait for John to answer before to do anything...
Originally Posted by pheoxs View Post
If the switch failed close it would start but never let cruise come on.
To test that can you start the car in neutral without the clutch in?
Sent from my Nexus 4 using Tapatalk 2
Will try that tomorrow. Good idea ! Thanks!
Old 06-12-2013, 10:47 PM   #5339
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Nolan
pheoxs is offline
Old 06-12-2013, 10:53 PM   #5340
Sensisnow
The switch he's referring to is under your dash, just above the clutch. It's responsible for showing the gear indicator and allowing cruise control.
Personally, I would just avoid using cruise control for the time being and wait for John to get back to you about your issues. He has a TON of stuff on his plate right now, so you'll just have to be patient. Plenty of people on this forum have been waiting weeks for his latest tune, flex fuel kits, vortech kits, etc. It may take some time, but he'll take care of you, just be patient.
CircuitJerk (06-12-2013)
Old 06-12-2013, 11:01 PM   #5341
grostoine
Drives: Subaru BRZ
You are certainly right and I totaly understand. But I would like to know if there was somebody who had the same issue.
The problem is not just that the cruise doesn't worked, the green light don't even come on when I pressed the on/off button, so this is why I think the problem come from the ECU and that it is not siwtches...
Everything is working good on my car exept for cruise control... That's weird.
Old 06-12-2013, 11:12 PM   #5342
CircuitJerk
Pull my finger...
Have you done any work to your interior lately? Any upgrades?
The Following User Says Thank You to CircuitJerk For This Useful Post:
Sensisnow (06-12-2013)
Old 06-12-2013, 11:23 PM   #5343
Sensisnow
If you're looking for people who have had a similar issue, I'd start a new thread in the Technical Topics section. http://www.ft86club.com/forums/forumdisplay.php?f=72
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Old 06-12-2013, 11:24 PM   #5344
grostoine
Drives: Subaru BRZ
Noo! I've unmounted the airbag on the steering wheel like 3 weeks ago so I can do some wrapping on the silver trim, after that the cruise was working.
He did not worked anymore by the time i've produced the dumpfiles.
Just started a thread in the technical section.
Old 06-13-2013, 10:58 AM   #5345
CircuitJerk
Pull my finger...
It is important to have as much detail here as possible.
Granted, EcuTek RR maps can be controlled via the CC stalk, but no reply from Visconti to verify it could be related. Certainly the first I've heard if it is.
There is more revealing information below which leads me to believe this is conincidental. It just happened to manifest itself or it was noticed at the time the ROM dump was performed.
Who knows, maybe that operation caused the problem?
I suggest you revisit your recent mods surrounding the steering wheel.
John just send me the tune and it worked. But my cruise controle is not working!!!
Anybody had this probleme before? It's not working since i've produced the dumpfiles!
Old 06-13-2013, 12:13 PM   #5346
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
You may have to adjust the position of your clutch switch if you have adjusted your clutch pedal height. I know I had to do this after adjusting the height.
cobrabyte is offline
Old 06-13-2013, 01:44 PM   #5347
Rich@ViscontiTuning
Drives: 2012 VW GLI
What's the status on this? The advice given in the thread is good advice but I didn't see a post from you to verify if you did try flashing back to stock to check and see if that alleviated the problem. Keep us posted!
Rich@ViscontiTuning is offline
Old 06-13-2013, 01:46 PM   #5348
Visconti
Drives: 05 STi
I would actually try using the dtc tool to clear codes first
Visconti is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
