Old 06-10-2013, 07:39 AM   #1
>(559)< FR-s
>(559)< FR-s's Avatar
Drives: 2013 FR-s® (Red)
Exclamation Thrust Bearing Going Out
So every time I let my clutch out, I hear a noise. The only thing I can compare the sound to is a Waist Gate or a damn Chipmunk. Im only @ 9,000 miles! Something is not right!!!!!!!!!!!!! No slipping yet, but N.F.G.
Rudolph's
Red
Nose
>(559)< FR-s is offline   Reply With Quote
Old 06-10-2013, 07:41 AM   #2
whtchocla7e
Drives: 2013 FR-S Hot Lava
Already a thread on this noise. Check a couple pages back.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 06-10-2013, 08:03 AM   #3
>(559)< FR-s
Don't see or hear anything like im talking about
Rudolph's
Red
Nose
Old 06-10-2013, 11:22 AM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I am guessing you mean throwout bearing, and I have never heard one sound like a wastegate, and I have never heard a chimpmunk sound like a wastegate either.
Old 06-10-2013, 02:20 PM   #5
Carwhisperer
Drives: A lot of supercars.
Mine does it too... I'm not sure whats causing the *tink* noise as I let the clutch out.. or just sometimes when im driving in any gear I hear a high pitched *tink*
Carwhisperer is offline   Reply With Quote
Old 06-10-2013, 02:26 PM   #6
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
You sure you aren't hearing the well documented air conditioning clutch kick on? It can be quite noisy at times and makes a noise just like you are describing.
Freetime is offline   Reply With Quote
Old 06-10-2013, 03:03 PM   #7
Pedalincircles
Drives: FRS
I had this *tink* sound on my old impreza. Maybe it's a Subaru thing.
Pedalincircles is offline   Reply With Quote
Old 06-10-2013, 03:25 PM   #8
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
My 2000 Impreza has the clutch squeak. It's either the clutch fork or one of the cylinders. Just needs some lube.
I would assume this is yet another Subaru quirk that has been carried over.
TOMIMOTO is offline   Reply With Quote
Old 06-10-2013, 06:45 PM   #9
Carwhisperer
Just got back from doing some testing to see when it'll *tink*.. And it'll do it in just about any gear, breaking, accelerating, when I let out the clutch. Going straight and turning. I notice the noise will sometime be on the left or right side of the car, with both windows down I can notice which side it comes from.
Sometimes its just 1 high pitched *tink* sometimes it tinks back to back very fast up to 3 times. Interesting how it will just do it on its own under pretty much any driving condition.
Old 06-10-2013, 09:00 PM   #10
FirestormFRS
Put a rather large screwdriver behind your crank pulley and pry, if the thrust bearing is going out the crank will move back and forth.
That being said engines with bad or missing thrust bearings don't last 9k miles normally.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
Carwhisperer (06-11-2013)
Old 06-11-2013, 12:14 AM   #11
Carwhisperer
I'll try that tomorrow ^
Old 06-11-2013, 12:58 AM   #12
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
Um I'm sorry that's such horrible advice, don't pry anything. If you are really concerned take it to the dealer its what warranty is for. Or you can pull the inspection cover. Come on man don't pry your pulley really....
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 06-11-2013, 01:03 AM   #13
Carwhisperer
She's stiff as a goose. I tried yanking out the motor too, that was pretty stiff as well. So.. i'll try the flux capacitor next and then check the blinker fluid.
Old 06-11-2013, 05:53 AM   #14
>(559)< FR-s
Yes Throw Out!
Ok, so there is No *Tink* Nothing metal sounding about it. When I said wastegate, I was referring more towards the air pattern. No Tink. Open Link. Go to the 16th Second. Exactly the 16 Second! Turn up the Volume. Press Play and Listen.
[ame]http://youtu.be/GR8Rw8jFHy4[/ame]
Its Very Fast. Seconds 16-18! That's what Im hearing.
Just been way to hard on it. Im a very aggressive driver. Drift it a bit "every day I can". lol When im having Fun an Down Shifting through turns, I don't match RPMs. I slam it an let that a$$ slide an scream.
Rudolph's
Red
Nose
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
WTB: front passenger hub / bearing assembly sw22 Brakes, Suspension, Chassis 1 01-28-2014 12:51 AM
bearing identification paraguin Other Vehicles & General Automotive Discussions 7 04-16-2013 10:18 AM
Fortune Auto New Roller/Radial Bearing JPxM0Dz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-29-2013 11:31 PM
Blown wheel bearing =( silverbullet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-23-2013 10:34 PM
