Old 06-10-2013, 10:11 AM   #15
superstani
Drives: 12 TL
is this with a GT2871R at 7 psi? on 93?
superstani is offline   Reply With Quote
Old 06-10-2013, 10:22 AM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by SilverSkyline210 View Post
That is exactly what i felt, random jerky hesitations, and definitely felt like it got better once it was warmed up. and actually i noticed when my coworker blipped the throttle with just the silicone coupler in place, the whole hose would collapse from the vacuum lol, i hope my drawing made sense, cause personally i think full blown should redo that section with 2 pipes and 3 couplers like how i have it now. and one more thing, i dont advise you going and cutting up your piping or silicone :P, i just did it cause i was so fed up with waiting for stuff i had to take matters into my own hands
Very interesting. My kit uses a pipe from the reducer, then a coupler in the area of the headlight that is partially squished from the headlight, and then goes into another pipe and then the coupler that connects to the intercooler. I have never checked to see if the coupler collapses at all.
Old 06-10-2013, 11:05 AM   #17
SilverSkyline210
SilverSkyline210's Avatar
Drives: WRB BRZ
GT2871r at around 9-10psi on 93 octane
I noticed in the intructions on their BRZ it had different piping like how you're describing, i think you got one of the earlier kits that use that set up, but now they send one long silicone coupler that replaces the whole upper pipe, i think when the coupler is that long its more flexible and easier to kink and collapse under vacuum, I think yours should be fine
SilverSkyline210 is offline   Reply With Quote
Old 06-10-2013, 11:10 AM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
When do you experience the jerkyness and hesitation? Can you describe the situation in more detail?
Old 06-10-2013, 11:28 AM   #19
SilverSkyline210
Drives: WRB BRZ
Well, just to clarify, it doesnt happen anymore :P, but when it did, it would be after letting cool down, then probably the first mile or until its warm, when you would try to lightly accelerate in first and second and third, car would randomly hesitate like power just cuts out real quick, and it would buck a bit too, only happened down low with light driving, if you rev it higher and floor it and drive it hard, power felt smooth, i wonder if the coupler was collapsing randomly under light driving because its was still in vacuum. But it is definitely good now
Old 06-10-2013, 12:20 PM   #20
pmccut
Drives: Blue Subarus
This. Only noticed it in 1st/2nd and under light driving. I haven't noticed the issue after the first ~3-4 minutes the car is warming up. I've gotten the "WT* is wrong with your car" from the few passengers that felt it.
I need to install the radiator soon so I'll certainly try and take pictures, but that might not be until this weekend.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 06-15-2013, 09:08 AM   #21
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
My brother has that gauge in his MS3, works great!
@SilverSkyline210, which vent pod are you using?
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 06-15-2013, 03:14 PM   #22
SilverSkyline210
Drives: WRB BRZ
@Draco_PR23
Nothing aftermarket, I just took apart the stock vent assembly, took the fin section out, and theres this circular mesh thing on the very back of the assembly, and I just mounted the gauge to that, maybe I'll take a photo of it when I get some time
Old 06-15-2013, 04:23 PM   #23
Draco_PR23
Fiebru
Draco_PR23's Avatar
@Draco_PR23
Nice and thanks .. I will try to take it out to see if my gauge (52mm) fits.
Current Cars:
NLM - Full Blown turbo kit with a twist No Limit Motorsport Forced Induction 84 06-19-2013 12:59 PM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 12:06 PM
Full Blown Turbo Kit Install This Weekend Gulf Breeze/Pcola/FWB King Tut Southeast 42 02-16-2013 03:24 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 08:38 PM
