Old 06-02-2013, 12:05 AM   #71
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by dabocx View Post
Mine was labeled as FX300 with steel flywheel. I got it in yesterday, so weird on the labeling!
Take a pic of your clutch please. Also, what is the part number?
Sent from my HTC One X using Tapatalk 2
Old 06-06-2013, 06:23 PM   #72
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
No one else is running a Exedy clutch?
Really want one that has a OEM feel but stiffer in feel. From what I have seen the ACT 6 is hard to drive and get use too and the FX350 makes lots of noise decellerating and braking?
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 06-06-2013, 07:40 PM   #73
Sportsguy83
Drives: Limited BRZ
I honestly can't say its much, but of course this is all subjective. When you stop at a drive thru you can hear it. On driving, you can hear it sometimes yes, but its nothing like wow, this is awful. IMHO.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Mr.Jay (06-07-2013)
Old 06-07-2013, 10:26 AM   #74
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
ACT makes a full face clutch that should satisfy your needs and should hold more than enough power for a bolt on forced induction kit.
Mr.Jay (06-07-2013)
Old 06-07-2013, 11:41 AM   #75
jamesm
that's what i've decided to go with. i'm hoping it'll hold a bit more than the 270 lb/ft they claim.
Old 07-12-2013, 02:47 AM   #76
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by ptuning View Post
We use the Exedy Stage 1 Clutch on our 345whp, 257wtq FR-S. We can tell you with certainty, that it is the closest that you'll get to the stock clutch, in terms of range of modulation and overall feel. There is a little bit of clutch noise when idling in neutral, but it's very minor compared to most other aftermarket clutches. This clutch is 100% parallel parking friendly.
Please contact us, if you'd like any additional information.
pm sent
gdrider77 is offline   Reply With Quote
Old 07-12-2013, 03:11 AM   #77
sw20kosh
Drives: 2013 Black FR-S
Stock clutch is good to 220-230 FT-lb at the wheels.
I smell burning clutch when accelerating up inclines sometimes in a high gear.
We smelled strong burning clutch today on the dyno when we did a 5th gear pull.
I am at 175-180 ft-lbs. I don't expect this thing to hold very long...
Old 07-12-2013, 04:09 AM   #78
Nothing
Drives: FRS
Two weeks ago I took the ACT 6 puck out and put the full face street disc in. I kept my streetlite flywheel. While the idle and feel have greatly improved as well as my down shifts in to 2nd gear. I still get a crap load of noise when I decelerate while in gear. I'd actually like to get a quick video tomorrow to post here to see if others get this same level of noise. My previous cars with ACT light weight fly wheels never made this kind of noise and is the basis of my concern.
Nothing is offline   Reply With Quote
Old 07-12-2013, 04:29 AM   #79
DAMotorsports
Drives: 2013 Scion FRS "Raven"
I would recommend the AVO clutch and flywheel. I have driven Bob's car from @Drift-Office (Thank you again Bob), he has the AVO 15 lbs flywheel and the organic clutch in his AVO Turbo charged FRS. OMG!!! I loved the way it felt. just a slight touch stiffer then stock and the engagement was amazing. I did not notice and nose from while driving the car. I did not push the car as I do not own it, but the reason I was allowed to test the vehicle was to feel the AVO clutch and flywheel.
over the last 10 years I have felt several different clutch and the first impression of this clutch was amazing and I was sold on the spot. I will be ordering the ceramic disk and Ill share my impression upon install. According to BOB and Paul @AVOturboworld they will feel the same just handle the heat better because of the minerals.
DAMotorsports is offline   Reply With Quote
Old 07-12-2013, 06:36 AM   #80
nix
nix's Avatar
Drives: AVO BRZ
I've run the ACS/AVO clutch plate & flywheel with full organic, carbon puck and currently the ceramic puck disc and they all made some decel noise somewhere between 3500 to 2500 rpm. I wasn't happy with the nvh from the ceramic disc and then with adding the STI engine mounts and either the STI or stock & whiteline trans mounts it's more noticeable.
I have an early 2012 build car, and even when they were stock I noticed I had way more shifter rattle/movement than driving @Benn0r's 2013 build car. So I'm thinking about trying to warranty the shifter with subaru, which could be interesting or try an aftermarket one. It could remove some of the nvh I am getting.
But even with oem mounts the decel was noticable with this clutch combo, and since it's very similar to oem design I expect most clutches will be the same.
nix is offline   Reply With Quote
Old 07-12-2013, 11:44 PM   #81
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Sorry man but you replaced everything but what is causing the issue which is the lightweight flywheel and the throwout bearing. Mine makes rattling noises as well, but they are normal, and I just accept it.
Sportsguy83 (07-12-2013)
Old 07-13-2013, 02:20 AM   #82
Nothing
Drives: FRS
I replaced the throwout bearing as well.
Old 07-14-2013, 01:17 PM   #83
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yep, it is the lightweight flywheel that makes the throwout bearing rattle. It is only really annoying to me at stoplights with the A/C on which puts enough load on the engine to make it start rattling.
Old 07-14-2013, 01:59 PM   #84
Sportsguy83
Drives: Limited BRZ
@lbroskee, here are my thoughts on the ACT 6 puck clutch.
Pedal feel is actually LESS hard than mine. It felt light right after driving my car back to back.
The clutch engagement point is harsher than mine (kind of obvious but just to confirm). Even with that, it is not a hard clutch to use. You just need to modulate the RPMs to get it to grab. My clutch is a bit more forgiving. You can slip y clutch more to give you some room as to when to engage. The 6 puck wants to engage as soon as it touches, but again, I was able to drive Chris's car with no issues and the only time it almost died was the first time I let the clutch out but it didn't die. All other instances were smooth.
It's not a bad option at all. It was surprisingly easy to drive after reading a lot of people here complaint that it is so hard to drive.
lbroskee (07-15-2013)
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
