Old 06-07-2013, 01:05 AM   #1
PNW FRS
PNW FRS's Avatar
First Hwy Run... Fuel Economy Report
Finally got around to doing a a highway drive that lasted just over an hour.
Conditions: Dry, temps in mid-70's / 4700 miles on ODO / Only mod is a K&N drop-in air filter and a spoiler for looks.
72 miles / ~60-65 minute drive -- both ways
Average MPG based on car computer
W/O A/C: 37.7
w/ A/C: 34.5
Mostly with cruise control on... leg #2 (w/ air on) had to deal with some traffic... a few roll-ons to 80'ish.
Notable: I really liked how the FRS -- while on flat sections in 6th gear @ about 3.1K on Tach... smoothly (and quickly) got up to 80'ish mph for dealing with traffic. Rig tracks nicely... love the sound coming out of the engine compartment.
As noted in numerous posts... the upper regions of RPM is the place to be... dang hard not to smile...
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 06-07-2013, 02:06 AM   #2
velin86
velin86's Avatar
Drives: 2013 Raven FRS 6MT
cool.
velin86 is offline   Reply With Quote
Old 06-07-2013, 10:01 AM   #3
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
31,000 revs? either a typo or you did some magic.
Freeman is offline   Reply With Quote
Old 06-07-2013, 10:15 AM   #4
Brndn704
Brndn704's Avatar
I'm pretty sure he meant 3,100. You can use common sense for that.
Brndn704 is offline   Reply With Quote
Old 06-07-2013, 10:20 AM   #5
Freeman
Freeman's Avatar
....or i can have a little fun...... dont be a party pooper
The Following User Says Thank You to Freeman For This Useful Post:
hernanBRZ (06-07-2013)
Old 06-07-2013, 10:25 AM   #6
Brndn704
Brndn704's Avatar
The Following 2 Users Say Thank You to Brndn704 For This Useful Post:
Freeman (06-07-2013), zaptorque (06-11-2013)
Old 06-07-2013, 10:27 AM   #7
Freeman
Freeman's Avatar
hahaha i love that cat
Brndn704 (06-07-2013)
Old 06-07-2013, 10:30 AM   #8
gily25
Drives: Silica BRZ 6MT
I recently did a 300 mile round trip all highway (only engine mod, Apexi drop-in), slightly higher speeds than OP 75-80mph w/ ac for the whole duration. I ended up with the same 34 mpg. I'm going on a limb and saying the speed matters less if you're able to keep a consistent rate of speed during the trip.
Honestly this was my one reason for justifying the purchase of a lightweight car (gas savings), it just happened to come in a sports car package with a few extra smiles, "mpg with style" eat that accord and elantra.
gily25 is offline   Reply With Quote
Old 06-07-2013, 12:54 PM   #9
Bt216
Bt216's Avatar
Drives: Scion frs
I average 38 doing 60mph.. the direct fuel injection does save gas. My first tank average was 32mpg
Bt216 is offline   Reply With Quote
Old 06-07-2013, 12:58 PM   #10
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
So using A/C does lower mpg? I thought that was a myth
CAMBAM_6 is offline   Reply With Quote
Old 06-07-2013, 01:04 PM   #11
DeeezNuuuts83
Drives: 2006 Evo IX SE
^ He said that he did a few "roll ons" to 80 mph (which I assume to mean quick, brisk acceleration). On a trip as short as 72 miles (which is about two gallons of fuel, give or take), that may very well have accounted for the difference in fuel economy. That and how the pump at the station is set to shut off.
DeeezNuuuts83 is offline   Reply With Quote
Old 06-07-2013, 01:07 PM   #12
FRyeS
Drives: 2013 FR-S Asphalt 6MT
I'm pretty sure it does lower MPG. But i also think "they say" that it is more efficient at highway speed to be windows up/air on than windows down because of the increased drag.
I could be totally wrong, but I believe I got that from somewhere reliable some time ago, havent done my own research
FRyeS is offline   Reply With Quote
Old 06-07-2013, 01:31 PM   #13
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
Hello everyone, the decrease in MPG with a/c on is correct.
The reason this happens is because iof the added load on the engine .
When the a/c button is pressed the magnetic clutch is engaged to allod power flow from the engine to the compressor and ultimately moving the freeon .
The system a high and low pressure sensors that the a/c control modual monitors to determine if the system needs to be turned off or on. The system is turned off at WOT and when desired cabin temp is achived.
I feel tyota has built a very well designed system that is easy to use and maximizes mpg while not sacrificing performance.
I hope this helps.
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 06-07-2013, 01:43 PM   #14
A/C makes a difference but I don't think it would make that much a difference.
What isn't mentioned (or if it was I missed it) in the OP is whether or not both legs were on the same/similar terrain. That could also account for the difference.
If you go to my Owner's Journal I have all my mileage there documented by tankful. Looking through it I don't see a significant difference between winter months (no A/C) and summer months (A/C all the time).
June/July/August, I averaged 31.76MPG with all A/C all the time. Dec/Jan/Feb I averaged 32.58 with no A/C. 90% of my driving is done on the same roads at the same time of day in both occasions. There would have been a difference in fuel mix (summer vs winter blend).
Why isn't the fuel economy better? White Shadow Scion FR-S / Toyota 86 GT86 General Forum 495 10-28-2019 08:21 AM
Fuel economy ozne99 BRZ First-Gen (2012+) — General Topics 48 12-11-2012 12:55 PM
Canadian fuel economy different rating Oilers99 Scion FR-S / Toyota 86 GT86 General Forum 14 10-04-2012 08:16 AM
Optimistic fuel economy? nubbster927 BRZ First-Gen (2012+) — General Topics 15 07-05-2012 08:50 PM
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 03:50 PM
