First Hwy Run... Fuel Economy Report
Finally got around to doing a a highway drive that lasted just over an hour.
Conditions: Dry, temps in mid-70's / 4700 miles on ODO / Only mod is a K&N drop-in air filter and a spoiler for looks. 72 miles / ~60-65 minute drive -- both ways Average MPG based on car computer W/O A/C: 37.7 w/ A/C: 34.5 Mostly with cruise control on... leg #2 (w/ air on) had to deal with some traffic... a few roll-ons to 80'ish. Notable: I really liked how the FRS -- while on flat sections in 6th gear @ about 3.1K on Tach... smoothly (and quickly) got up to 80'ish mph for dealing with traffic. Rig tracks nicely... love the sound coming out of the engine compartment. As noted in numerous posts... the upper regions of RPM is the place to be... dang hard not to smile...
2013 Asphalt / MT
Olympia, Washington Last edited by PNW FRS; 06-08-2013 at 10:18 AM. |
#2 |
Drives: 2013 Raven FRS 6MT
cool.
#4 |
#6 |
#8 |
Drives: Silica BRZ 6MT
I recently did a 300 mile round trip all highway (only engine mod, Apexi drop-in), slightly higher speeds than OP 75-80mph w/ ac for the whole duration. I ended up with the same 34 mpg. I'm going on a limb and saying the speed matters less if you're able to keep a consistent rate of speed during the trip.
Honestly this was my one reason for justifying the purchase of a lightweight car (gas savings), it just happened to come in a sports car package with a few extra smiles, "mpg with style" eat that accord and elantra. |
#9 |
Drives: Scion frs
I average 38 doing 60mph.. the direct fuel injection does save gas. My first tank average was 32mpg
#11 |
Drives: 2006 Evo IX SE
^ He said that he did a few "roll ons" to 80 mph (which I assume to mean quick, brisk acceleration). On a trip as short as 72 miles (which is about two gallons of fuel, give or take), that may very well have accounted for the difference in fuel economy. That and how the pump at the station is set to shut off.
#12 | |
Drives: 2013 FR-S Asphalt 6MT
I'm pretty sure it does lower MPG. But i also think "they say" that it is more efficient at highway speed to be windows up/air on than windows down because of the increased drag. I could be totally wrong, but I believe I got that from somewhere reliable some time ago, havent done my own research |
#13 |
Keep Calm And Drift On~
Drives: Scion FR-S WhiteOut 6 Speed Manual
Hello everyone, the decrease in MPG with a/c on is correct.
The reason this happens is because iof the added load on the engine . When the a/c button is pressed the magnetic clutch is engaged to allod power flow from the engine to the compressor and ultimately moving the freeon . The system a high and low pressure sensors that the a/c control modual monitors to determine if the system needs to be turned off or on. The system is turned off at WOT and when desired cabin temp is achived. I feel tyota has built a very well designed system that is easy to use and maximizes mpg while not sacrificing performance. I hope this helps. |
#14 |
A/C makes a difference but I don't think it would make that much a difference.
What isn't mentioned (or if it was I missed it) in the OP is whether or not both legs were on the same/similar terrain. That could also account for the difference. If you go to my Owner's Journal I have all my mileage there documented by tankful. Looking through it I don't see a significant difference between winter months (no A/C) and summer months (A/C all the time). June/July/August, I averaged 31.76MPG with all A/C all the time. Dec/Jan/Feb I averaged 32.58 with no A/C. 90% of my driving is done on the same roads at the same time of day in both occasions. There would have been a difference in fuel mix (summer vs winter blend).
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| Why isn't the fuel economy better? | White Shadow | Scion FR-S / Toyota 86 GT86 General Forum | 495 | 10-28-2019 08:21 AM |
| Fuel economy | ozne99 | BRZ First-Gen (2012+) — General Topics | 48 | 12-11-2012 12:55 PM |
| Canadian fuel economy different rating | Oilers99 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-04-2012 08:16 AM |
| Optimistic fuel economy? | nubbster927 | BRZ First-Gen (2012+) — General Topics | 15 | 07-05-2012 08:50 PM |
| Fuel Economy | Lexicon101 | Engine, Exhaust, Transmission | 38 | 02-22-2010 03:50 PM |
