View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 06-05-2013, 08:46 PM   #29
Carwhisperer
Drives: A lot of supercars.
Originally Posted by track_warrior View Post
I know of two other people that might not be on this forum that are Viconti tuned and have had a DI issue, ill try to send them a txt to visit this poll.
Just sent a pm to a moderator.
I have a buddy who's not on the forums who had the issue too. Seems like (obviously) There's more than just us on the forums who have the issue.
Carwhisperer is offline   Reply With Quote
Old 06-05-2013, 09:04 PM   #30
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Could you have them respond to my survey I sent you via pm please?
Thanks!
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
Old 06-05-2013, 09:18 PM   #31
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Do you know if the update from Visconti fixed the issue?
Bg8780 is offline   Reply With Quote
Old 06-05-2013, 09:25 PM   #32
Carwhisperer
I think the AT tunes will be getting it first, if not I'm not mistaken the MT guys will have to wait a little while longer. The latest version is not out to the public yet. @Visconti would you like to chime in?
Old 06-05-2013, 09:53 PM   #33
Ozzman
Drives: old
Where is the I have NOT had a direct injector issue option in the poll?
Ozzman is offline   Reply With Quote
Old 06-05-2013, 09:56 PM   #34
Carwhisperer
don't need to vote if you haven't had the issue. Trying to get an idea of how the dealerships are handling the issue.
Old 06-05-2013, 10:05 PM   #35
Ozzman
Drives: old
Not having that option allows the poll to paint a biased picture in the minds of the viewers.
Having the option of no issues with the DI injectors allows us to figure out how prevalent the issue is.
Old 06-05-2013, 10:18 PM   #36
vgi
Drives: frs
Originally Posted by xjohnx View Post
The heat issue is caused by the ECU mapping resulting in detonation. Fix the ECU, fix the problem (in theory.)
a possibility of some aftermarket direct injectors that could handle the heat better?
vgi is offline   Reply With Quote
Old 06-05-2013, 11:00 PM   #37
xjohnx
Grip>Slip
xjohnx's Avatar
No aftermarket DI's available that I'm aware of. It shouldnt' be necessary once they stop the detonation. I wouldn't be surprised to see some aftermarket seals (or maybe even revised OEM ones made out of a different material) though.
Old 06-05-2013, 11:15 PM   #38
lsxiong
Drives: 92 Integra
You just don't have the issue with the DI injectors, "yet".
lsxiong is offline   Reply With Quote
Old 06-05-2013, 11:55 PM   #39
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Thanks!
Sent you the survey, and i texted them as well.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 06-06-2013, 02:06 AM   #40
robispec
Drives: Black frs project
how about I had a direct injector "Issue" and solved it myself.
robispec is offline   Reply With Quote
Old 06-06-2013, 08:27 AM   #41
Lunks
Drives: bobsled
This is very disheartening. I hope this is fixed for the 2014 MY. I'm planning to purchase one but not if this and the chirp don't get resolved.
Lunks is offline   Reply With Quote
Old 06-07-2013, 02:02 AM   #42
track_warrior
Track Junkie
Unfortunately the whole future of these little sports cars will be based on both manufacturers coming up with a true solution for the DI problem. Enthusiasts want a entry level sports car that not only handles well but is also reliable hint hint (S2K,MX-5). If anybody has connections with a car magazine it might be a good idea to mention this and the other DI threads in hope they will pressure both manufacturers to do something.
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
