#43 |
Drives: FR-S [Hot Lava]
Yeah... I noticed that today...
![]() Sent from my Galaxy Nexus using Tapatalk 2 |
#44 |
I got the rears flipped yesterday when I got my Nvidia Exhaust installed. It's a lot quieter now.
#45 |
Drives: GT86
So perhaps an ET42 wheel would be perfect?
#46 |
+42 would surely have more room between the tire and strut hat, but it would also poke out more past the fenders too. Problem is, 17x9 RPF1's don't come in a 42 that I have seen, unless possibly in a 17x8.
#47 |
I've only seen +45 or +35 in both 17x8 and 17x9 for RPF1's.
#48 |
Drives: 86
Looks good. Is that a straight 8 in the background?
#49 |
Early Adopter
Drives: Admins, please delete this account.
I'm trying to confirm the answer to this question on other threads. But I'm guessing that the ET45 won't clear with a 1" drop using eibach springs and the factory shock?
#50 |
#51 |
Springs won't effect clearance at the spring seat, so to be safe you should count on needing 3-5mm spacers.
#52 |
Great wheel and tire setup!
We will have our car on 17x9 +35 with 245/40/17 RS3's. We've been selling tons of the ZII's here, dying to try them. |
#53 | |
Some coilovers have springs that have smaller diameter springs than stock which allow you to recover space from smaller springs. On spacers - I would try the 3's first because that way you don't need to change your lug spindles. |
#54 |
Drives: Frs
Looks good, I'm digging the black/hot lava!
-Robert
#55 |
Drives: 86 GTS
mine actually scrubs the inside of the rim on the tie rod end, anyone else have this issue?
#56 |
Drives: on cruise control
ENKEI RPF1 17x9 +45 245/40/17 Hankook V12
here they are
![]() ![]() ![]() ![]() ![]() when the wheel is at full lock, the rim does hit the tie rod. just like a very intelligent member pointed out to me earlier. i decided to go with this and just live with it. one other member here has the exact same setup but hes on coil overs and i think he said he has no issues with the tie rod. that will be my next move. BTW, im on eibach springs with a 1" drop Last edited by loogs; 06-05-2013 at 07:49 PM. |
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 06:31 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
| Wheel Directory: Enkei Kojin 17x9.0 +45 | Clipdat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-02-2016 04:18 PM |
