Old 06-05-2013, 11:22 AM   #85
Carwhisperer
Drives: A lot of supercars.
Toyota is about to encounter a Huge pending Problem with this one. This thread does need a sticky.
Carwhisperer is offline   Reply With Quote
The Following 2 Users Say Thank You to Carwhisperer For This Useful Post:
2forme (06-05-2013), TemeCal (06-05-2013)
Old 06-05-2013, 11:27 AM   #86
TemeCal
Drives: 86
We're not the only ones having issues.
http://arrowsdiary.blog.shinobi.jp/Date/20130604/
Looking at these pictures, seems pretty similar to mine. 2 injectors looked quite a bit worse than the other 2. My guess (from my own experience and @Carwhisperer 's comments), is that the driver side injectors are the ones getting fried the most/first.
@CSG Mike -
Do you recall how your 4 injectors looked the first time you had the issue? Did the passenger side look quite a bit better than the driver side?
TemeCal is offline   Reply With Quote
Old 06-05-2013, 11:31 AM   #87
CSG Mike
CSG Mike's Avatar
@CSG Mike -
I've never *actually* seen them, but any soft codes thrown were always cylinder 2, which I believe is the passenger side.
Old 06-05-2013, 11:37 AM   #88
xjohnx
Grip>Slip
xjohnx's Avatar
How were you able to pull the soft codes? Didn't someone mention they clear themselves immediately?
Old 06-05-2013, 11:42 AM   #89
CSG Mike
CSG Mike's Avatar
Ours weren't cleared immediately, but would clear themselves automatically after a short period of driving.
Old 06-05-2013, 11:46 AM   #90
orthojoe
Originally Posted by Dezoris View Post
This is such a disappointing issue. Whether you track your car or not, its something that's just so typical of OEMs. Its things like this where you can see why people go with companies like Porsche and Mazda for spec racing and track. Their American engineering support and involvement exist, you have contacts, support.
This entire issue would have already been addressed. The fact that its not is just another sign how half baked this car is in so many ways.
Don't be too sure about that. IMO, all manufacturers are the same. Ask the GT3 guys how well they think Porsche dealt with catatrophic coolant hose failure, centerlock failure, and variocam adjuster failures. Then there's the 996, 986, 997.1, and 987.1 IMS failures...
I'm hoping Subaru will do right by us soon enough. I've mentioned this in another thread, but I purchased a 2004 STI when they first came out. The factory tune had bad detonation issues. I demonstrated to the dealer the pinging sounds, and they came out with a reflash which fixed the problem. I expressed my concerns about future reliability of the engine since it had already suffered episodes of detonation and they gave me a free 100k extended warranty upgrade. Let's hope they continue to do the right thing.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 06-05-2013, 11:53 AM   #91
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Its summer and im 100% sure we will see tons of cars with blown engines or at least injector seal leaks because the heat will accelerate the process. Hopefully they start to take notice and do something about the stupid direct injection issue.
Yup, when it happened to me my car lost power and threw a code that went away when i regained power after 3 secs. After 2 minutes the car went into limp mode and threw 2 permanent codes.
Cant believe my engine died at 4K miles .
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 06-05-2013, 05:24 PM   #92
enderr
enderr's Avatar
Drives: 2013 Toyobaru FT-86
Questions
(I'm kinda new here so be gentile)
So...
> Does anybody know if this has happened with an automatic transmission?
I drive to red line and shift down to 5500 - 5800 A LOT. I drive aggressively enough where I'm thinking about installing a shift light that i can mount on the A-pillar because I'm constantly hitting the fuel cutoff. I've never tracked the car and this thread is making me wonder if I should.
enderr is offline   Reply With Quote
Old 06-05-2013, 05:59 PM   #93
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
So...
We have shift light came with car
Sent from my Galaxy Nexus using Tapatalk 2
Old 06-05-2013, 09:28 PM   #94
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
While I agree that the way this has been handled so far is disappointing, calling it half baked seems a bit much. It's at least 3/4 baked.
On another note, my dealership claimed that when they installed my new ECU for the cam sensor issue that they updated the ROM to prevent me having the injector issue. They may have just updated to whatever the latest is and told me that because the injectors is what I asked about, but it's possible it's out there and just not in an official TSB yet as they go case by case. They did have @TemeCal's car in at the same time for the injector issue. Gary, did they tell you that they did the ECU update or not?
This was at Scion btw. I feel that one of the biggest issues with getting the kinks worked out of this car is having a separation between the service and engineering departments at each manufacturer's dealerships so disconnected from one another. There is trickle over/down both ways as we've seen with some of the other TSB's, but there seems to be a delay one way or the other on the manufacturers recognizing, understanding, and issuing fixes for the issues we've run into.
The biggest problem with their handling of this issue is telling people that a CEL is necessary. If something is obviously wrong with the way the engine is running (Hello, it's not supposed to sound like firecrackers going off), they should find out what's going on, CEL or not. Going solely on the computer's output when something is obviously audibly wrong is completely asinine, and in the case of @CSG Mike's car resulted in a blown motor. From my understanding this would never have happened if they had fixed the issue when Mike tried to first take it in. But until his blew, we didn't really know that this issue could cause such a catastrophic failure.
Nathan
SubieNate is offline   Reply With Quote
Old 06-05-2013, 09:54 PM   #95
Carwhisperer
Well said. I would ask my dealer about the updated flash, but im fed up with them.
Old 06-05-2013, 10:31 PM   #96
TemeCal
Drives: 86
Prior to picking up my car, I asked about an ECU update. I asked if there was an updated flash that addresses this issue. The SA's response was "your ECU has the latest flash". I asked if it contains a fix for this DI issue, and he wasn't sure. I seemed to know more about a possible fix coming, than he did.
So I'm 99% sure the flash they performed on my car, does NOT have the fix. Nowhere in my invoice does it state anything about an updated flash. Just the way he responded to my questions, made it sound like a fix wasn't in the flash.
I may try contacting the Manager tomorrow. He's been really cool to work with, and always researches and looks into things. He's constantly on the phone with Toyota and other dealerships. If I have time tomorrow, I'll ask him if he can contact whoever to try and get some answers about a possible ECU fix.
The Following User Says Thank You to TemeCal For This Useful Post:
SubieNate (06-06-2013)
Old 06-06-2013, 01:41 AM   #97
enderr
enderr's Avatar
yeah i know (and i use it) but i wanted something a little brighter and mounted further up in my field of vision. that's not really the point anyways...
this dosen't seem to be the same magnitude of a problem the cam gear thing was for us earlier. but I wonder non the less.
I drive the car VERY hard a couple of times each day but for short stints (3-10) minutes at a time. that whole time the engine never gets the opportunity to operate below 5000rpm and these are daily occurrences so...
> has this happened to street driven only vehicles?
> has anyone with an automatic transmission reported this problem?
Old 06-06-2013, 01:55 AM   #98
FT_Monk
Drives: Over the hill WRX
If the code clear itself then $10 say this problems is known to Subaru/Toyota engineer.
FT_Monk is offline   Reply With Quote
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 09:31 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
