#393 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#394 |
#395 |
Drives: 2013 Firestorm FR-S
I'm not clear from the various injector issue threads if the ECU fix (be it your tuner or the factory flash) has any material impact on performance of the car. My interpretation is that it doesn't but I wanted to confirm.
2013 Firestorm FR-S, MTX, build date 1/13.
#396 |
Drives: Honda Fit
#397 | |
Drives: SSM LT MT BRZ
wow...just wow What are you even trying to talk about? at what point does your car draw air (enough to clear an entire header tube like a bong)thru the exhaust valve? let me answer that....NEVER there is no EGR "valve" on this motor like there have been problems with in the past (QR25de's) allowing catalyst to endup back in the intake (where things enter the cylinders, usually air and fuel) Subaru uses the valve timing to create internal EGR. To answer the next question, no catalyst cannot slide up the header tube next to the valve and wait for an EGR cycle to get sucked in, how do I know??? let's just say i got upclose and personal with the cat in a FA20 header and there is a fibrous material similar to motorcycle exhaust packing just prior to the cat in the collector area, a sufficient amount to prevent broken catalyst from migrating that direction. Please people there are alot of folks that don't know the difference in poorly constructed guesses and info, let's not start a mass panic where half the members gut their cats because someone with no idea what happens in an engine declared the cats are meowing their way into the combustion chamber and killing motors...FFS people seriously |
| The Following 10 Users Say Thank You to SkullWorks For This Useful Post: | ATL BRZ (06-05-2013), CSG Mike (06-05-2013), JoeBoxer (06-06-2013), Lonewolf (06-05-2013), Marchy (06-06-2013), P@ul (06-05-2013), RAN94A (06-06-2013), Sportsguy83 (06-05-2013), strat61caster (06-05-2013), SubieNate (06-05-2013) |
#398 |
Drives: 2013 FR-S Ultramarine
Also, this isn't a turbo motor with a cat before the turbo to cause damage like some of the early WRX's. Definitely a side effect of what happened and in no way part of the cause.
| The Following User Says Thank You to SubieNate For This Useful Post: | CSG Mike (06-05-2013) |
#399 |
As much as I hate to pick sides I have to side with you here assuming everything you said is true, but what we think doesn't matter:
1) I did not know companies today searched cars up on the internet to find out how they are being used, but it is not an invasion of privacy as you publicly posted those videos up there for everyone to see. 2)Subaru/Toyota/Scion HAVE ALL marketed this car for track use and being modified, you can use this in your defense. 3) There are very few other options the only option now that will have the most effect is to lawyer up and take some serious legal action. Most likely I think you got one of the bad batches of FA20 and honestly the way that they are reacting to it makes me want to you payed for this car, they tear it down, then immediately can't explain the damage so they blame it on track use. Frustrating I know . But It really is time to get a lawyer get your money back and hopefully either get a new FR-S or have everything rebuilt by an outside company.
#400 | |
In fact, the Willow Springs International Raceway video is so casual that I'm having a conversation with my passenger as I'm driving. I sincerely hope that's not what they're referring to when they say that the car was raced at WSIR. |
#401 | |
Drives: Honda Fit
Maybe. Maybe not. Again, let's not confuse the non-binding statements of advertising copy with the legally binding statements of warranty copy. Welcome to the fray. :happy0180: |
#402 |
Drives: First SWP BRZ-L
ah crap. I started noticing the detonation last year after we put the first set of headers on the car... made it loud enough to hear pretty easily. I hope no long term damage is done. Argh. I just figured that it was light detonation that Subaru knew about and was OK with, meaning it wasn't doing any harm since it wasn't under load when it det'd. Thanks to @PERRIN_Jeff for pointing out the detonation to me last year... hmm.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#403 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
I think I got through most of this thread but a few points stand out:
1. That cat failure is likely HEAT, not so much knock. The DI seals maybe knock, but the cat is usually a heat issue or manufacturing defect (i.e. qr25). EGR is built in to the valve overlap, unlikely to suck in cat parts, but possible if the tune had too much exhaust cam with a stock header. 2. The car absolutely 100% definitely knocks on gearchange on the stock tune. We tried back in january to iron this out by reducing down low timing thinking it was the cause, but turned out it was just when we were getting on the throttle. Scratching my head until #3.... 3. The transient timing has been changed with the A01X (the X being region/trans type). This has been available on the EcuTek platform and we've been copying the newer transient tables into the older tunes that were not available until a few days ago (the AT). 4. This has shown a reduction in the on throttle knock counts, but it is not entirely eliminated, knock sensors always generate a bit of noise. It does not seem to be as patterned though after the update. But your failure screams heat to me. Which makes little sense since the stock tune is so rich up top. DI sprays above 5000 and it sprays late in the combustion cycle, so it ends up having an additional cooling effect. So it definitely seems like an oddball and subaru should be taking care of it based on the information presented. I can see them denying a warranty claim on the cat if it was put to track use, but not warrantying the whole motor is another story. If I had to guess I'd say the knock blew the seals out, causing you to run lean, and then destroy the cat in the process. If you pop that header off and look at the valves, see if any are melted, and what color they are. While the sodium filled valves are pretty damn hard to melt, at these temps you may find some other evidence there as to what may have happened. When I look back at the stock tune we had multiple instances of 4+ KR with stock timings. On the flashed tunes with the latest revisions, I'm seeing fewer and less severe (1-2) events from the logs here and sent in so far. |
| The Following 5 Users Say Thank You to Xero-Limit For This Useful Post: | Bristecom (06-06-2013), Carwhisperer (06-05-2013), Marrk (06-05-2013), strat61caster (06-06-2013), WolfpackS2k (08-21-2013) |
#404 |
Drives: A lot of supercars.
Hope it all gets thrown into the MT sooner than later. Thanks for the info Mike.
#405 |
Drives: Honda Fit
@moto-mike: Is he ECU revision that Toyota-Subaru is offering likely to address the transient timing? Or are they looking at something else for this problem?
Just want to be clear. |
#406 | |
| The Following User Says Thank You to Xero-Limit For This Useful Post: | Marrk (06-05-2013) |
| We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 94 | 09-15-2013 08:55 PM |
| Denied service... | Chen | Northwest | 37 | 09-13-2013 08:37 PM |
| HELP with diminished value claim! | zohare | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 04-03-2013 11:17 AM |
| Hit and Run Insurance Claim | CharlieChaos | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 12-26-2012 08:54 PM |
| Japan loses its claim to "Creepiest Asian Country" | reni | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 05-07-2012 11:57 PM |
