Old 06-04-2013, 07:08 PM   #71
Carwhisperer
Drives: A lot of supercars.
Originally Posted by mx5apex View Post
What's the point of having a 7400 rpm redline if the engine can't take it...
Going to ask Toyota that myself shortly.
Carwhisperer is offline   Reply With Quote
Old 06-04-2013, 07:21 PM   #72
Scrappy Jack
Drives: Miata + M3
Given that there are a half dozen threads for every time an issue comes up, those of you involved ( @Carwhisperer @CSG Mike et al) need to copy and paste this link in to each thread it comes up in:
https://www-odi.nhtsa.dot.gov/ivoq/
After you yourself have filed a notice, of course. Phone calls are likely not going to be sufficient documentation on their own and contacting the manufacturer or dealer without getting their regulator involved is likely to be less efficient.
Best of luck. I was very close to selling my E92 M3 and "downgrading" to an FR-S after seeing Jon Miller's success, but this kind of stuff has given me more than second thoughts.
Scrappy Jack is offline   Reply With Quote
The Following User Says Thank You to Scrappy Jack For This Useful Post:
Carwhisperer (06-04-2013)
Old 06-05-2013, 12:31 AM   #73
Dezoris
Dezoris's Avatar
This is such a disappointing issue. Whether you track your car or not, its something that's just so typical of OEMs. Its things like this where you can see why people go with companies like Porsche and Mazda for spec racing and track. Their American engineering support and involvement exist, you have contacts, support.
This entire issue would have already been addressed. The fact that its not is just another sign how half baked this car is in so many ways.
Old 06-05-2013, 12:35 AM   #74
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
I'm hearing weird squicky noises when i'm driving, I thought it was the injectors, but after seeing that videos it doesn't sound like that.
Scalzo is offline   Reply With Quote
Old 06-05-2013, 01:11 AM   #75
s2d4
s2d4's Avatar
Originally Posted by 2forme View Post
Right, but once the seal is blown, the ECU flash won't fix it. The seal will need to be replaced at that point.
So this is established on the stock ecu, what about tunes?
Surely the tuner should not have let it knock excessively?
Old 06-05-2013, 08:10 AM   #76
vgi
Drives: frs
can someone add this thread to OUR BELOVED FRS/BRZ LISTS OF ISSUES / PROBLEMS HERE!! or better yet make it sticky?
vgi is offline   Reply With Quote
Old 06-05-2013, 09:45 AM   #77
andrew20195
Drives: 2013 Subaru BRZ
Originally Posted by Porsche View Post
I have to wonder if my BRZ is safe even if I do not track the car. It just may take longer.
If it blows up, Subaru/Toyota will replace your engine.
Once.
To me, as I read things, they currently cannot assure owners that the engine will not destruct yet again. But next time = NO WARRANTY.
I think you're being a little melodramatic here.
The reason Subaru is giving for denying the "second" CSG engine replacement is that the vehicle has been extensively tracked. Furthermore, the first engine in his car hadn't failed, they took it to perform engineering tests to find out why the injector seal failed. If his most recent engine failure is a result of this defect, it should be replaced under warranty, track use or no.
If you don't track your car, your warranty is unaffected. If your engine suffers damage due to high rpm shifting on the street, it will be replaced under warranty. If you start to have misfires and popping noises, don't clear the codes, bring it in to the dealer. The more data Subaru has on this issue, the more quickly a fix will be developed for it. As the SA Toyota service bulletin shows, there may already be a fix, but these things take time to filter through the bureaucracy of a multinational joint venture.
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
Marrk (06-05-2013)
Old 06-05-2013, 10:00 AM   #78
CSG Mike
CSG Mike's Avatar
One of the problems is that the issue dosn't throw hard codes. It (the code) clears itself really quickly.
Old 06-05-2013, 10:03 AM   #79
TemeCal
Drives: 86
+1
On my car, I saw the CEL pop up for 1-3secs while I was driving on the freeway. After that, everything was cleared/gone. I was unable to view anything in my OBDII scanner.
On a side note, Toyota just finished fixing my car. They replaced the driver side injectors. No ECU flash yet...
TemeCal is offline   Reply With Quote
The Following User Says Thank You to TemeCal For This Useful Post:
whitefrs (06-05-2013)
Old 06-05-2013, 10:06 AM   #80
Carwhisperer
Originally Posted by TemeCal View Post
+1
That's True Mike, only got P0351 for me one time and that was it. Dealer couldn't replicate it themselves under the normal driving I was doing at the time of the code popping up.
Not what I wanted to hear.. I honestly would take it easy, unless if you want it back in the shop within 2 weeks like what happened with me.
Old 06-05-2013, 11:02 AM   #81
Scrappy Jack
Drives: Miata + M3
Question
Any idea if they visually inspected the rest of the injectors?
Old 06-05-2013, 11:11 AM   #82
TemeCal
Drives: 86
Yes, all 4 injectors were inspected. The 2 passenger side injectors looked great, 1 driver side injector was badly burnt and missing a collar, and the other driver side injector was partially burnt but still had the collar in tact. They went ahead and replaced both drivers side injectors.
Old 06-05-2013, 11:16 AM   #83
Carwhisperer
Wow, exact same with me.. Literally. They replaced all 4 of mine.
Old 06-05-2013, 11:20 AM   #84
CSG Mike
CSG Mike's Avatar
We're not the only ones having issues.
http://arrowsdiary.blog.shinobi.jp/Date/20130604/
Carwhisperer (06-05-2013), TemeCal (06-05-2013)
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 09:31 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
