Old 06-04-2013, 02:37 PM   #43
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
people can do 1.5G sustainable on A6s, spikes can easily get into the 2.0 category
in your picture the bolt bends nearly 45 degrees at 2.0 side load
thats... kind of catostrophic, is it not?
Old 06-04-2013, 02:51 PM   #44
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
The visual deflections shown in FEA analysis programs are exaggerated to make it easier to visualize what's going on. If you were to adjust the program to show the actual deflection it would be quite a boring image.
What you're looking for in those pics is for peaks in the stress/strain the part is being put under. blue usually represents a very low stress level, yellow is higher, orange higher, and red is usually bad. That is, if the material properties and unit scaling are setup properly. The pics show that according to that analysis, everything is well within acceptable stress/strain levels.
Cheers
Nathan
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
7thgear (06-04-2013)
Old 06-04-2013, 02:57 PM   #45
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
excellent, thank you.
Old 06-04-2013, 05:53 PM   #46
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
Thanks Nathan! Correct, the images are exaggerated, the actual deflection will be fractions of a mm, almost impossible to spot with the naked eye so the program automatically exaggerates it for visualization. We've also increased the adjuster size from 5/8's in the prototype model to 3/4's in the production version. It will add a good amount of stiffness and strength. The final OTS arm will look like this to remove debris build up and allow for bottom mounted adjusters to be reached:
Hancha Group is offline   Reply With Quote
Old 06-04-2013, 11:22 PM   #47
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
ETA?
JackSmiley is offline   Reply With Quote
Old 06-04-2013, 11:30 PM   #48
Hancha Group
Drives: Subarus
There is one prototype version available. The revised version will take roughly four weeks to receive from date of build order
Old 06-04-2013, 11:35 PM   #49
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
How much camber adjustment will this allow for the rear?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 06-04-2013, 11:41 PM   #50
Hancha Group
Drives: Subarus
It depends on your ride height and which side it's on. We haven't had a chance to rack it with a car at stock ride height, but you should be able to get over -3 degrees at stock ride height. More when lowered.
Old 06-05-2013, 12:03 AM   #51
Tansey86
Tansey86's Avatar
What about dialing back in? If you want less camber and you are dropped around 2 inches and have -3*, could you dial it back to around -1.5*?
Old 06-05-2013, 02:05 AM   #52
Hancha Group
Drives: Subarus
Yeah, that shouldn't be an issue, the arm shortens about 15mm vs. stock.
Old 08-11-2013, 02:57 AM   #53
eckoflyte
Drives: Toyota 86 GTS
Out of curiosity, have you considered lowering the mounting point of the shock to decrease ride height while maintaining bump travel. For e.g., Stance and GTSpec have this sort of design. If not, what were your reasons? Would a lower point have an adverse effect on the geometry?
eckoflyte is offline   Reply With Quote
The Following User Says Thank You to eckoflyte For This Useful Post:
ML (08-13-2013)
Old 08-11-2013, 06:45 AM   #54
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
has anyone fitted these yet?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 08-11-2013, 07:25 AM   #55
ft_sjo
Drives: GT86
The thing that worries me about these (and no doubt similar design items) is as is shown on the first page, with just 2G force (on multiple planes), the arm fails. what about when you lose the rear end a bit and tap the rear wheel against a curb? That's a LOT more than 2G!
Old 08-11-2013, 07:30 AM   #56
DriftEightSix
Pegasus White
Drives: 86
Even a stock arm wouldn't survive that kind of impact.
hancha, rear lower control arm
Rear lower control arm part # BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-15-2013 12:33 AM
Hancha Rear Toe Link Hancha Group Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-05-2013 08:18 PM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 01:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 05:28 PM
