Old 06-04-2013, 01:23 PM   #15
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Originally Posted by BlueDubbinTDI View Post
Link?
[ame="http://www.amazon.com/Shorai-LFX14L2-BS12-Extreme-Lithium-Powersports/dp/B005FIUJ0S/ref=sr_1_1?ie=UTF8&qid=1370362993&sr=8-1&keywords=lfx14l2-bs12"]Amazon.com: Shorai LFX14L2-BS12 Extreme Rate Lithium Iron Powersports Battery: Automotive[/ame]
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 06-04-2013, 02:34 PM   #16
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
i always ran 0 or 2 gauge when i do relocation's in VW's. anything smaller and i had slow cranking issues. granted i am also turning over 6 cylinder engines, and im sure the cable length is a bit longer than it would be on this car.
Old 06-04-2013, 02:39 PM   #17
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
That little thing can crank this car? Lol
Old 06-04-2013, 02:51 PM   #18
xwd
A lot of guys use these, they are super cheap (like $30).
http://www.apexbattery.com/deka-etx-...batteries.html
The Following User Says Thank You to xwd For This Useful Post:
ProjectD (06-05-2013)
Old 06-04-2013, 03:00 PM   #19
cf6mech
Drives: FRS Silver LS1 swapped.
My battery relocate and why, planning on some wire re-routes and building a box for intake.http://www.summitracing.com/parts/TAY-48103/ . I'm not to concerned about trunk space, as I'm building a track car, but it does take up a lot of space if your concerned about that. Sorry about photo size.
cf6mech is offline   Reply With Quote
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
GhostOp86 (02-05-2016), ML (06-04-2013)
Old 06-04-2013, 03:36 PM   #20
infanterene
Drives: White BRZ
Do those motorcycle and lipo batteries really work for our cars? Do they offer enough cca?
infanterene is offline   Reply With Quote
Old 06-04-2013, 03:49 PM   #21
BlueDubbinTDI
Im wondering the same thing. I'm waiting to remove my spare and tools until I can get a light weight battery. Shedding 55lbs for $40 seems too good to be true lol
Old 06-04-2013, 04:33 PM   #22
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Subbed as I want to run a WMI kit (reservoir where the stock battery is) but want to keep a full sized battery.
pheoxs is offline   Reply With Quote
Old 06-04-2013, 04:45 PM   #23
ML
ML's Avatar
Drives: 13 White MT FR-S
correct me if I'm wrong, but aren't our stock batteries (and most new/modern batteries) already sealed type?
Old 06-04-2013, 05:02 PM   #24
Xdragonxb0i
Drives: ex500r
The only reason to keep the full size battery is to save money. some of the small light weigth batterys have more cranking amps then the stock.
Xdragonxb0i is offline   Reply With Quote
Old 06-04-2013, 05:10 PM   #25
pheoxs
How are they in the winter though ...? I need my car to start perfectly everytime in -30C
Old 06-04-2013, 05:12 PM   #26
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
The stock won't do that....
My wrx would slow crank and such at -15F
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 06-04-2013, 05:22 PM   #27
pheoxs
Every car I've had up until now is fine. Usually I plug it in at that temperature but sometimes you have no choice (outside at events or not near a plugin). Obviously they aren't happy about it and crank slowly, but it does start fine.
Old 06-04-2013, 05:48 PM   #28
Captain Insano
You should at a minimum if you live in cold climates and plan to DD the car compare the CCA of the target battery to the CCA of the OEM battery. If it is comparable you should have no worries. Another thing to pay attention to with some of the smaller batteries in cold weather is they lose charge more quickly if they sit for long periods of time (multiple days or weeks). I'm not saying you cannot run a smaller batter (I have on four previous cars without issue), just saying if you DD try to get close to matching the CC and be wary of letting your car sit for weeks (not good anyway in cold weather even wiht the OEM battery).
Captain Insano is offline   Reply With Quote
Relocating from Hawaii BrzRacer Northwest 48 04-14-2013 05:15 AM
relocating the 3rd brake light Basti Cosmetic Modification (Interior/Exterior/Lighting) 6 03-06-2013 07:08 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
Battery in the trunk scottman Electronics | Audio | NAV | Infotainment 14 10-06-2012 08:26 PM
Relocating battery to trunk Ess Vee Engine, Exhaust, Transmission 17 10-02-2012 05:32 PM
