CANADA Canada
Old 04-26-2013, 01:52 PM   #1
DacoFRS
DacoFRS's Avatar
Drives: 2013 whiteout frs
Window issues
This morning it was cold so I just noticed right now. The passenger window button on the driver side doesn't work at all. And the drive window isn't auto anymore??? Anyone had any ideas.
DacoFRS is offline   Reply With Quote
Old 04-26-2013, 01:57 PM   #2
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Quoted from another post
To reset auto mode for windows
1) lower window all the way, keep holding switch down for 5 seconds.
2) Raise window all the way, and hold switch up for 5 seconds.
Myv is offline   Reply With Quote
The Following User Says Thank You to Myv For This Useful Post:
SkAsphalt (04-26-2013)
Old 04-26-2013, 02:00 PM   #3
DacoFRS
DacoFRS's Avatar
Wow nvm it just started working. Odd
Old 04-26-2013, 04:38 PM   #4
wparsons
wparsons's Avatar
It's the lock out button, it stops the passenger window from working from either door switch.
flickr
Old 04-26-2013, 04:58 PM   #5
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
It is not the log button, it is what this man said. The switches freak out when the window is frozen to the seal and you open the door or use the window. You have to reset the windows controllers.
Has happened to me 3 times now.
Old 06-03-2013, 01:01 PM   #6
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
So I had my door panel completely off yesterday along with the battery disconnected. I can't seem to reset the passenger side switch. I tried rolling it down and holding that for 5 seconds and back up for 5 seconds with no luck. Same for the fix suggested in the owner manual. Any ideas?
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-03-2013, 01:41 PM   #7
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
Dealership. ;-)
thorlius is offline   Reply With Quote
Old 06-03-2013, 02:37 PM   #8
wheelhaus
wheelhaus's Avatar
What was the reason for taking the door panel off? It's possible you mushed a pin in the connector, or something is jammed when the panel went back on.
Old 06-03-2013, 03:14 PM   #9
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
We were installing puddle lights. You could be right. I'll take a better look today with the panel off
Window issues Oilers99 CANADA 84 11-23-2015 11:10 AM
Window tint issues... Normal? Moshpit37 Cosmetic Modification (Interior/Exterior/Lighting) 35 09-11-2013 06:51 AM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 08:15 PM
Auto up and down window Issues? CzRceCar Issues | Warranty | Recalls / TSB 3 08-07-2012 07:44 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 03:41 PM
