#1569 |
Drives: '13 Ultramarine
I'll cruise up for a bit. What time do you plan on getting there?
#1570 |
Drives: FR-S Firestorm 6MT
I would try to keep it under -2, maybe 1.8 or 1.9?
The other thing I did not mention is that I kinda cheated a bit on the camber bolts, as I dremeled (sp?) the hole by another 2mm to give me more camber. So you may be very close to the ideal camber once those two are installed. What are you aiming at for toe settings? Last edited by Slick; 06-04-2014 at 09:42 AM. |
#1571 |
((•||=(86)=||•))
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Sorry I had to go at 10:00 last night - I went to see F&F6 at the Collesium.
I was worried about the parking but I found a nicely-lot corner spot and my buddy backed me up on the other side ![]() Lots of action in the movie pretty much just like the trailers pretty wild and you have to leave reality at the door lol Interesting that they filmed a lot in London Gina Careno is in it - she can't act but she's easy on the eyes and has some wicked fight scenes ![]() We paid the $14 AVX (?) to see it - I hadn't been to a movie for years so I guess it was worth it but I wouldn't want to do that too often ($$$$) So I'll simply give it a 'thumbs up' it was a fun 2hours
#1572 | |
1/8" toe OUT on front (total, not per side) (roughly 0.20 in degrees) Some recommend zero toe all the way around but I like a bit of toe-out on the front as it helps with turn-in. Plus it will be a bit more stable and not too darty. Zero toe on rear You could also go with 1/16" of toe-in on the rear to make it more stable as well. Just make sure there is no toe-out on the rear. Phil will do a great job for you at CTC Carling (& Ralf too of course but request Phil to do the work). Oh, and Phil would probably know this, but make sure you go to Maximum Caster as well. Last edited by Slick; 06-04-2014 at 09:42 AM. |
#1573 |
Drives: 2013 Subaru BRZ
Drove through a little rain outside of Casselman tonight.
[ame="http://youtu.be/Wu5j12nvkho"]http://youtu.be/Wu5j12nvkho[/ame] Rain was so hard that the HVAC developed a leak on the passenger side. Filled a large McD's cup in about a half hour.
#1574 |
Canadian FR-S Member
Drives: FR-S '10 Series'
Forgive me if this noob question, is this a reoccuring issue? [Looking to purchase FR-S] I searched forum and found nothing relating to HVAC leaks. I've had leaks before in my HVAC on a previous vehicle but it was due to a clog in the AC drainage line and it backed up and caused leak into the passenger footwell area.
#1575 |
#1576 | |
#1578 |
Engineer
Drives: WRB 2022 Subaru Brz
Any reason why the borla headers much cheaper than other headers on the market
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4 Beta
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE |
#1579 |
Drives: 2013 wrb brz
Didn't know they were.... But I'm happy with them and borla generally makes a quality product.....may be cheaper because they are cattless
#1581 |
Drives: Black Subaru BRZ
#1582 | |
brz filter and pump ready for e85 from factory |
